		GrummanDude
				 Posted: Thu Mar 12, 2009 9:08 am    Post subject: Horizontal braces |
				I found bent vertical braces in the area in contact with the stub spar that goes through the fuselage on a Tiger with no other noted damage to anything.  I cannot imaging how that vertical brace can be bent unless the horizontal twisted so much that it deformed the vertical braces.
   Just a heads up
   A Good Credit Score is 700 or Above.  See yours in just 2 easy steps!
  |  | - The Matronics TeamGrumman-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Gary
AuCountry Aviation
Home of Team Grumman |
		az_gila
				 Posted: Thu Mar 12, 2009 9:53 am    Post subject: Horizontal braces |
				Could it be a "tail skid touch" landing that
 forced the aft fuselage up a little, and the mass
 of the horizontal resists it and causes the buckle in the vertical angles?
 The damage to mine was similar to your
 description - previous owner landings though...:^)
 gil A
 PS  ..can we attach pictures now?
 At 10:06 AM 3/12/2009, you wrote:
  	  | Quote: | 	 		  I found bent vertical braces in the area in
 to anything. Â I cannot imaging how that
 twisted so much that it deformed the vertical braces. Â
 Just a heads up
		grumpyparts
				 Posted: Thu Mar 12, 2009 2:05 pm    Post subject: Re: Horizontal braces |
				Yes you can put pictures up on the  Matronics Email Lists Forum Index -> TeamGrumman-List  under the same topic name.
		Discover
				 Posted: Thu Mar 12, 2009 3:33 pm    Post subject: Horizontal braces |
				Not the vertical but I saw the horizontal  brace cracked.
  A fellow Tiger owner on my field was pushing  his Tiger into the T-hangar and struck the hangar with the elevator. He came and  got me to see the damage. The right stabilizer was seperated from the fuselage  about an inch leaving a gap at the leading edge root where the plastic root  fillet usually is up against the fuselage. I held the right stabilizer at the  tip and put a little forward pressure on it and heard a big pop. The gap was now  gone. Further inspection by the A&P found the top lip of the spar cracked  and that is where you could locate the popping sound...
  [quote]   ---
