billschlatterer(at)sbcglo Guest
Posted: Mon Jan 09, 2006 6:04 pm Post subject: E-Bus Avionics Switch ? |
Just thinking? On any of the Endurance Bus drawings. Other than the "don't
really need it" discussion and parts count issue, what would the downsides
be of adding a S704 contactor between the D25 and E-Bus so that you
effectively used the whole E-bus as an Avionics bus. This would assume that
the E-bus load can be easily carried by the S704 which I think is rated at
20 amps and has low continuous draw. It would actually save several
switches for EFIS systems like the GRT which are not internally switched.
Comments appreciated.
Thanks Bill S
7a Ark
Wiring as we speak
lhelming(at)sigecom.net Guest
Posted: Sat Jan 14, 2006 5:12 am Post subject: E-Bus Avionics Switch ? |
sportav8r(at)aol.com Guest
Posted: Sat Jan 14, 2006 8:44 am Post subject: E-Bus Avionics Switch ? |
Exactly what I'm planning, and for the same reasons (keeping GRT EFIS off during cranking, etc.) I will / should have my Excel file finished by tonight, showing this architecture with relay feed for both the primart and backup e-bus feed paths, as well as a way to share one OVP crowbar module automatically between two alternators (main and SD- .
-Bill B
