Carburetor
imap8ntr(at)cox.net
PostPosted: Sat Feb 14, 2009 5:57 pm    Post subject: Carburetor Reply with quote
Paul
Now that you have been using the economy tuning kit for awhile, what kind
of EGT/RPM are you seeing upon climbout and in flight cruise. Also what is
your field elevation which may affect these numbers?
Ivan
wypaul
PostPosted: Sun Feb 22, 2009 8:05 am    Post subject: Re: Carburetor Reply with quote
Ivan,
Not sure if I am the Paul you posted to but, I have been using the original economy tuning since it came out. To be honest I will have to take another look to give you a good answer but my field elevation is at 5300 and I do most of my flying at 8,000 14,000 feet. If I remember right climb-out is at 100kts, 1900 RPM and EGT's run 1275-1375 with the cruise numbers about the same but the speed running 150-160 kts and at full throttle 3150-3250 with the EGT's running 1025-1025.
Paul
Paul Spackman
Q-2 Jabiru 3300
wypaul
PostPosted: Sun Feb 22, 2009 8:09 am    Post subject: Re: Carburetor Reply with quote
Should have been 1025-1125 not 1025-1025.
Paul
Paul Spackman
Q-2 Jabiru 3300
Lynn Matteson
PostPosted: Sun Feb 22, 2009 8:37 am    Post subject: Carburetor Reply with quote
Your climb-out is 100 kts at 1900 rpm? Is that right? Seems too low
for rpm, especially at 5300 ft MSL...must be one fast/slippery
airframe. I'd sooner think 2900 rpm, eh?
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
Status: flying
On Feb 22, 2009, at 11:05 AM, wypaul wrote:
<loadout(at)bresnan.net>
Ivan,
Paul
Paul Spackman
Q-2 Jabiru 3300
http://forums.matronics.com/viewtopic.php?p 31494#231494
Lynn
Kitfox IV-Jabiru 2200
N369LM
wypaul
PostPosted: Sun Feb 22, 2009 1:51 pm    Post subject: Re: Carburetor Reply with quote
You are right Lynn it should have been 2900 RPM. The Q-2 is slippery but not that slippery. Embarassed
Paul Spackman
Q-2 Jabiru 3300
Lynn Matteson
PostPosted: Sun Feb 22, 2009 2:16 pm    Post subject: Carburetor Reply with quote
No problem, Paul....I'm just glad that I don't have to re-prop my
plane to try to get it to climb at this rpm. : )
Lynn Matteson
Sensenich 62x46
Status: flying
slippery but not that slippery. [Embarassed]
Paul Spackman
Q-2 Jabiru 3300
http://forums.matronics.com/viewtopic.php?p 31546#231546
Lynn
N369LM
selwyn
PostPosted: Thu Mar 12, 2009 5:00 pm    Post subject: Re: Carburetor Reply with quote
Does anyone have the manifold pressure readings to go with climb and cruise numbers?
Cheers, Selwyn
Kit 66 VH-ELZ
checkpoint2(at)COMCAST.NE
PostPosted: Sat Mar 14, 2009 4:25 am    Post subject: Carburetor Reply with quote
Bravo! I would like to see the numbers with the prop and RPM Bob Haas N330BH
