		peteohms
				 Posted: Sun Mar 15, 2009 11:53 am    Post subject: Tire Question |
				My kitfox III has stock tires on it.  I believe they are 16X6.5X8.  A friend
 gave me a couple new 18X8.5X8 tires which are of course wider.  Will they
 fit the stock wheels?
 Pete
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
				 Posted: Sun Mar 15, 2009 12:01 pm    Post subject: Re: Tire Question |
				 	  | Quote: | 	 		  My kitfox III has stock tires on it. I believe they are 16X6.5X8. A friend
 Pete |
 Pete, 18X8.5X8 tires came with my Kit.  I have the Douglas ATV wheels.  I have also put some clown tires (Kingfox) tires on the same wheels.  They are even bigger.
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		brianm(at)snolab.ca Guest
				 Posted: Sun Mar 15, 2009 5:08 pm    Post subject: Tire Question |
				I think they will work. I have ~100hrs on a set of 21x12x8 with are mounted
 KF IV. I also just bought the same tires for the speedster that I am
 building.
 Brian
		rawheels
  Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
				 Posted: Tue Mar 17, 2009 2:12 am    Post subject: Re: Tire Question |
				So, help me understand this;  The tire numbering system is radiusXwidthXplys, right?  The original wheels were 6" wide, so how do you put a 8.5" or 12" wide tire on a 6" wide rim?  Do you just get a smaller inner tube, or is it ok to use the wider tires because we never put in the full air pressure or something?
  _________________ Kitfox IV-1200
Indianapolis, IN |
		Tom Jones
				 Posted: Tue Mar 17, 2009 6:45 am    Post subject: Re: Tire Question |
				 	  | Quote: | 	 		  | So, help me understand this; The tire numbering system is radiusXwidthXplys, right? The original wheels were 6" wide, so how do you put a 8.5" or 12" wide tire on a 6" wide rim? Do you just get a smaller inner tube, or is it ok to use the wider tires because we never put in the full air pressure or something? |
 Ryan, the original kitfox wheels are Douglas ATV wheels.  ATV tire size is Tire outside diameter X Tire widest section width X wheel diameter.  Tire width is commonly 2 to 4 inches wider than wheel width.
 The Kingfox tires are 21 X 12 X 8.  Yes that is pushing the width limits to put it on a 6 inch wide wheel.  I took my Kingfox tires and Douglas wheels to the tire shop and asked the guy, "Will these tires work on these wheels".  He said yup and mounted them.
 When inflated the widest section of the tire is 9 inches.  This combination of tires and wheels has been used on Kitfoxes for a while now and I haven't heard of any problems.  Experimental has its advantages.
Classic IV
Ellensburg, WA |
