		zenith-list(at)steensland Guest
				 Posted: Tue Mar 17, 2009 8:33 am    Post subject: horizontal stab question |
				Nutters, er Netters!
 I have been trying to get my horizontal stab skeleton put together so I
 can get it skinned. I noticed something on a few of my ribs and was
 curious to see if any other builders have seen this with their tails.
 Where the ribs (6T1-2) meet the rear spar (6T1-4) there should be a
 tangent transition from the rib to the spar. When I align the rib on the
 spar as best I can there is no way to make the top curve of the rib
 gracefully transition to the spar. There is something on the order of
 6mm height difference between the rib and spar. Has anyone seen this? I
 have a picture that would better describe the issue but it's a little
 fuzzy. http://www.steensland.net/pics/far.png
 If so, how did you deal with it?
 Lee Steensland
 601XL/Corvair (7637L reserved) Kit/Scratch builder 0.0% complete!
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		carlossa52(at)gmail.com Guest
				 Posted: Tue Mar 17, 2009 8:50 am    Post subject: horizontal stab question |
				Lee, I'm afraid your picture is fuzzier than your words...
 If you are talking about a *horizontal* gap, that's not an issue (this seems to be the case, I see a ruler in the horizontal position). If it is vertical, then it is another story...
 Good luck
 Carlos
 CH601-HD, plans
 Montreal, Canada
 2009/3/17 Lee Steensland <zenith-list(at)steensland.net (zenith-list(at)steensland.net)>
  [quote]--> Zenith601-List message posted by: Lee Steensland <zenith-list(at)steensland.net (zenith-list(at)steensland.net)>
  I have been trying to get my horizontal stab skeleton put together so I can get it skinned. I noticed something on a few of my ribs and was curious to see if any other builders have seen this with their tails.
  Where the ribs (6T1-2) meet the rear spar (6T1-4) there should be a tangent transition from the rib to the spar. When I align the rib on the spar as best I can there is no way to make the top curve of the rib gracefully transition to the spar. There is something on the order of 6mm height difference between the rib and spar. Has anyone seen this? I have a picture that would better describe the issue but it's a little fuzzy. http://www.steensland.net/pics/far.png
  Lee Steensland
				 Posted: Tue Mar 17, 2009 9:16 am    Post subject: horizontal stab question |
				I just uploaded a better picture (I took it from the zenith construction
 guidelines). The huge black line shows that the top surface of the rib
 should be flush with the top of the spar.  I get about a 6mm height
 difference on 3 of my ribs.
 www.steensland.net/pics/edge.jpg
 Carlos Sa wrote:
  	  | Quote: | 	 		   Lee, I'm afraid your picture is fuzzier than your words...
  Good luck
  Carlos
  CH601-HD, plans
  Montreal, Canada
  <mailto:zenith-list(at)steensland.net>>
      <zenith-list(at)steensland.net <mailto:zenith-list(at)steensland.net>>
      their tails.
      Lee Steensland
 Lee Steensland
		jaybannist(at)cs.com Guest
				 Posted: Tue Mar 17, 2009 9:37 am    Post subject: horizontal stab question |
				Lee,
   Unless I am seeing things wrong, I see your problem. If this photo shows the top of the stabilizer, you have the rear spar upside down.  The upper flange of the rear spar should project rearward to provide a fastening for the elevator hinge.  The lower spar flange projects forward.
  Jay Bannister
		Ron Lendon
