rv10rob(at)gmail.com Guest
Posted: Tue Mar 17, 2009 8:39 am Post subject: Fun with Andair valve and scat tube |
I got creative with my fuel line rounting to leave some space under the valve to run the scat tube. See the picture here:
http://kochman.net/N819K/wp-content/uploads/2009/03/img_5098.jpg
My intent is to run the scat tube by the valve under the valve and rudder cable on the right side (left when looking at the picture). I will likely wrap the scat tube in the heat reflective material to minimize heat around the fuel lines. Note: the fuel line from the valve to filter is not shown in the picture, but goes straight down and thus should not interfere.
Anyone see a problem with this? Thanks...
-Rob
Rob Kochman
RV-10 Wings
Woodinville, WA (near Seattle)
bkbrown(at)minetfiber.com Guest
Posted: Tue Mar 17, 2009 9:04 am Post subject: Fun with Andair valve and scat tube |
Looks like you’ve got more room than I do, I planned to make a fiberglass plenum going from one 2” scat to two 1” scat, then another plenum back into 2” on the aft side of the spar…for sure it would be more work, but I wasn’t smart enough to turn one of the Andair fittings 90 degrees…mine are both vertical so I have less room to work with unless I go back in and totally replumb.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Tuesday, March 17, 2009 9:37 AM
Subject: Fun with Andair valve and scat tube
-Rob
Rob Kochman
RV-10 Wings
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Deems Davis
Posted: Tue Mar 17, 2009 5:43 pm Post subject: Fun with Andair valve and scat tube |
you mean like this? :
http://deemsrv10.com/album/Final%20Assembly/slides/DSC07074.html
http://deemsrv10.com/album/Final%20Assembly/slides/DSC07075.html
http://deemsrv10.com/album/Final%20Assembly/slides/DSC07076.html
Deems Davis # 406
'Its all done....finally!!!!!
Bob and Karen Brown wrote:
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rob Kochman
*Sent:* Tuesday, March 17, 2009 9:37 AM
*To:* rv10-list(at)matronics.com
*Subject:* Fun with Andair valve and scat tube
-Rob
Rob Kochman
RV-10 Wings
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
Posted: Wed Mar 18, 2009 6:47 am Post subject: Fun with Andair valve and scat tube |
That might be what I end up doing Deems...it looks like it'll work. I've
got some upcoming spinal surgery in April...so a little fiberglass project
might just keep my head in the game...
I was thinking more of a one tube to two tube contraption...the idea being
to maintain airflow volume, but still minimize the scat size (sounds like a
wildcat hunting expedition...)...I'll let you fly a little in cold weather
and let me know how much heat you get in the back before I move forward with
my little fiberglass project, that means (you'll have to get those 40 hrs
flown off and) come up here to Oregon this month!!!
I'll buy you and Ed Hayden lunch here in Independence and show you our -10
project...and of course, (it goes without saying here in Independence, 7S5);
you've always got a free place to stay, a car (and/or bicycle or motorcycle)
to drive, and we can find you a hangar for the night.
THANKS for the photolinks. That's exactly what I was looking for...visual
ideas.
jeff(at)westcottpress.com Guest
Posted: Wed Mar 18, 2009 4:51 pm Post subject: Fun with Andair valve and scat tube |
Bob Turner
Posted: Thu Mar 19, 2009 10:52 am Post subject: Re: Fun with Andair valve and scat tube |
Just a quibble: two 1" lines will not "maintain the flow volume" of one 2" line, since the cross sectional area varies as the square of the diameter (e.g., two 1" lines provide half the cross sectional area as a single 2" line).
_________________ Bob Turner
RV-10 QB |
Posted: Thu Mar 19, 2009 11:37 am Post subject: Fun with Andair valve and scat tube |
And a good quibble it is...I know that, but my point was that going from one
2" line to a single 1" line may not provide enough heat...I was just trying
to "fit between" the pieces I have and that's why I proposed the idea. I
haven't started doing anything on it, still scratching my head...
Thanks for the clarity and observation!
Posted: Thu Mar 19, 2009 12:17 pm Post subject: Fun with Andair valve and scat tube |
Posted: Fri Mar 20, 2009 8:10 am Post subject: Fun with Andair valve and scat tube |
Posted: Fri Mar 20, 2009 9:16 am Post subject: Fun with Andair valve and scat tube |
When I open some of these posts...I get nothing but a blank page. What's
up?
Posted: Fri Mar 20, 2009 9:38 am Post subject: Fun with Andair valve and scat tube |
Same here.
