Posted: Fri Mar 20, 2009 11:48 am Post subject: Warp Drive bolt torque |
Does anybody know the torque on the bolts that hold a Warp Drive prop to the hub flange on a 447? I called Warp Drive, and they are closed this week. Thanks.
Bill Sullivan
Windsor Locks, Ct
lcottrell
Posted: Fri Mar 20, 2009 12:04 pm Post subject: Warp Drive bolt torque |
175 inch pounds for the hub, 120 for the blades.
Larry C
Posted: Fri Mar 20, 2009 12:47 pm Post subject: Warp Drive bolt torque |
Thanks, Larry.
Bill Sullivan
by0ung(at)brigham.net Guest
Posted: Sat Mar 21, 2009 7:17 am Post subject: Warp Drive bolt torque |
Bill Sullivan
Windsor Locks, Ct.
FS 447
I am not sure if there is different torque values for different engines,,,,,
My instructions say to torque the ¼ inch bolts to 120 inch pounds or 10 foot pounds,,, in increments of 20 inch pounds up to the full recommended torque.
Torque the 8 mm or 5/16 mounting bolts to 175 inch pounds or 15 ft pounds
Torque the 3/8 mounting bolts to 35 ft pounds
Re torque after 1 hour of operation then every 5 to 10 hours as a part of regular maintenance.
I am just guessing here,,, I think the difference between the 5/16 / 8mm and the 3/8 mounting bolts will depend on what hub you have.
Boyd
jlsk1(at)frontiernet.net Guest
Posted: Sat Mar 21, 2009 12:27 pm Post subject: Warp Drive bolt torque |
Warps website has a page that has this info.
Jim
