		dlm46007(at)cox.net Guest
				 Posted: Fri Mar 20, 2009 1:42 pm    Post subject: XM Radio |
				I was using XM for  weather on the trip March 14 to the Midwest. worked fine. ON the return March  19, the system failed to come up after takeoff from the Midwest. I stopped  in TX to refresh and it worked again. Does anyone else have these problems? Why  does the XM sight provide a self refresh transaction on the net? I am  considering cancelling XM and using the Navworx box on the Chelton to get TIS  and FIS info... I told XM that it is a safety of flight issue, in that expecting  NEXRAD data when encountering adverse weather and being surprised, is not funny.  Anybody else have this problem????
		Strasnuts
  Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
				 Posted: Fri Mar 20, 2009 2:27 pm    Post subject: XM Radio |
				Sometimes our citation WSI fails the same way and  then I notice they did an upgrade or modification.  I have to reboot the  system and then it works fine.  Sometimes it needs 15 minutes of run time  and then reboot.  It doesn't start working until the second  flight.
  [quote]   ---
  _________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
				 Posted: Fri Mar 20, 2009 3:03 pm    Post subject: XM Radio |
				The problem seems to be with XM where a reboot does not  solve the problem. ONLY A STOP AT AN FBO WITH INTERNET CONNECTION AND AN XM  REFRESH TRANSACTION WHILE KEYING IN THE RADIO ID.. Is the TIS/FIS going to be  any better? Too bad I did not install a STRIKEFINDER..
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of  Seano
 Sent: Friday, March 20, 2009 3:25 PM
 To:  rv10-list(at)matronics.com
 Subject: Re: XM  Radio
  [quote]   ---
				 Posted: Fri Mar 20, 2009 4:06 pm    Post subject: XM Radio |
				I have had XM weather for 3 years on my 396 and never have had any issues....
 On Mar 20, 2009, at 7:00 PM, "David McNeill" <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
 [quote]  The problem seems to be with XM where a reboot does not  solve the problem. ONLY A STOP AT AN FBO WITH INTERNET CONNECTION AND AN XM  REFRESH TRANSACTION WHILE KEYING IN THE RADIO ID.. Is the TIS/FIS going to be  any better? Too bad I did not install a STRIKEFINDER..
    From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)  [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of  Seano
 To:  [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
  [quote]   ---
		Phil.Perry(at)netapp.com Guest
				 Posted: Fri Mar 20, 2009 5:03 pm    Post subject: XM Radio |
				Had exactly the same problem on exactly the same date. (Afternoon if I recall correctly)
 A reboot fixed it for me though.
 Phil
 Sent: Fri Mar 20 14:39:27 2009
 Subject: RV10-List: XM Radio
		Tim Olson
				 Posted: Fri Mar 20, 2009 7:11 pm    Post subject: XM Radio |
				Is this on the AV-300's, the new receivers that you see these
 problems?  My old AV-100 was fairly spotty, but my AV-300 has
 been flawless.  Also, with WSI, once you're activated you don't have
 to go to any website to refresh.
 Some people may remember that last year I flew the NavWorx system
 on my Chelton.  It worked for both Wx and TIS-B right out of the box.
 The only problem is that FIS-B (ADS-B Weather) doesn't have great
 coverage all over the US yet.  Shortly I will be testing the box
 again to provide only traffic, so that I can maintain my WSI for
 Wx yet get both TIS-A and TIS-B traffic.  If that works, I'll
 be all set and will just use it that way until FIS-B coverage is
 all over the US.  You can cover so many miles in an RV-10 in a
 day that having only scattered regions where Wx is available
 wouldn't be any fun.
 Seano wrote:
 [quote] Sometimes our citation WSI fails the same way and then I notice they did
		msausen
  Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
				 Posted: Sat Mar 21, 2009 4:02 am    Post subject: XM Radio |
				I think the key in all this is it has nothing to do with the transmission but in how the receiving equipment is acting.  If you are going in and essentially sending a reactivation signal, your equipment is probably the issue and not the XM signal.  This is equivalent to blaming a web site provider for not being accessible if your ISP is down.  I believe that Sirius/XM occasionally reauthorizes receives but the receiver shouldn't time out before receives a new authorization assuming it's used with some regularity.  Either way I would complain to your hardware manufacturer first.
 My $0.02
 Michael
		dmaib@me.com
				 Posted: Sat Mar 21, 2009 4:21 am    Post subject: XM Radio |
				When I was flying for a living, we had numerous instances where WSI
 would not refresh and we had to call WSI and have them do some kind
 of reboot. Then we would have to wait a half hour or so. This is NOT
 the case with the WSI I have in my RV with the AV-350. It has been
 flawless since initializing back in October. Don't know what the
 difference is, but I am pleased with the service. I am following
 Tim's work with the NavWorx system. Sounds pretty cool.
 David Maib
 40559
  _________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
				 Posted: Sat Mar 21, 2009 4:35 am    Post subject: XM Radio |
				If that is the case then the XM reauthorization should retry as the aircraft
 hardware is not ON 90+% of the time. Other XM receivers i.e. car radios have
 considerably more ON time than aircraft weather systems even though mine is
 ON whenever I am flying.
		coop85(at)verizon.net Guest
				 Posted: Sat Mar 21, 2009 10:28 am    Post subject: XM Radio |
				Not sure what hardware you have, but I use XM on my 496.  It takes awhile to start tracking the weather, but I occasionally get significant delays in updates (45 minutes plus).  After some guidance from the forum I e-mailed Garmin and they indicated the issue was with XM, not the receiver.  Not much we can do about that I suspect.  Rebooting the 496 has a limited effect for me.  Recently the problem has been less prevalent so I hope that’s a good sign.
 Marcus
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
  Sent: Friday, March 20, 2009 5:39 PM
  Subject: XM Radio
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
		n142ds(at)gmail.com Guest
				 Posted: Sat Mar 21, 2009 6:24 pm    Post subject: XM Radio |
				The problem you describe is an XM chip issue.  If the XM doesn't see a satellite for a while it drops the connection to stop theft.  This was set up long before weather when it was basically a radio only service.  It happens with the cheap XM and the 'certified' XM like I have in my RV.  Real pain in the but ... however the refresh only takes seconds .. especially if you're airborne with you request it.  I've never seen it stop working in flight .. it's always after the aircraft has been hangered for a while.  As I understand it there is really no fix for it, although the weather folks have been talking for some time that there may be a way.
  David W. Schaefer
 RV-6A N142DS  "Nerdgasm"
 TMX-IO360 Dual-LightSpeed Plasma IIIs, Hartzell Blended Airfoil, GRT EFIS
 www.n142ds.com
 On Fri, Mar 20, 2009 at 4:39 PM, David McNeill <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
 [quote]      I was using XM for  weather on the trip March 14 to the Midwest. worked fine. ON the return March  19, the system failed to come up after takeoff from the Midwest. I stopped  in TX to refresh and it worked again. Does anyone else have these problems? Why  does the XM sight provide a self refresh transaction on the net? I am  considering cancelling XM and using the Navworx box on the Chelton to get TIS  and FIS info... I told XM that it is a safety of flight issue, in that expecting  NEXRAD data when encountering adverse weather and being surprised, is not funny.  Anybody else have this problem????
 tp://forums.matronics.com
		billderou(at)yahoo.com Guest
				 Posted: Mon Mar 23, 2009 8:52 am    Post subject: XM Radio |
				I have implemented XM using the Spruce XM receiver and my own software. Early on I had sporatic problems resetting the box when there was an extensive delay in data reception. It made the box appear dead until next boot.
  Another user had problems when stopping and restarting his subscription and getting the timing right for reception of the "refresh". Another significant outage I had was because the whole XM system went down and I needed a "refresh". Once these problems were resolved it has not failed once in the last 12 months and comes up briskly with the first nextrad image within 5 minutes.
  We need to focus problems on the exact piece of equipment talking to the XM receiver and the mfg of the XM receiver, and the software version in the XM receiver. The specification for this communication is a guarded secret that nobody will share (with me) so there is much room for errors with reverse engineering.  If you have a copy please contact me.
  Also, when the network "refresh" is activated it will not begin for approx 30 minutes and times out after 3 hours - so you need to get the timing and antenna reception right.
  None of these comments nor the lack of a clear problem definition surprise me.
  Bill DeRouchey
  N939SB, flying
 --- On Sat, 3/21/09, David Schaefer <n142ds(at)gmail.com> wrote:
 Date: Saturday, March 21, 2009, 7:22 PM
 David W. Schaefer
 www.n142ds.com
   	  | Quote: | 	 		    I was using XM for weather on the trip March 14 to the Midwest. worked fine. ON the return March 19, the system failed to come up after takeoff from the Midwest. I stopped in TX to refresh and it worked again. Does anyone else have these problems? Why does the XM sight provide a self refresh transaction on the net? I am considering cancelling XM and using the Navworx box on the Chelton to get TIS and FIS info... I told XM that it is a safety of flight issue, in that expecting NEXRAD data when encountering adverse weather and being surprised, is not funny. Anybody else have this problem????
 =nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
 et=_blank>http://forums.matronics.com
 llow target=_blank>http://www.matronics.com/contribution
  | 	   [quote][b]
