Brake Cable Replacement
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
thexporter
PostPosted: Sat Mar 21, 2009 4:06 pm    Post subject: Brake Cable Replacement Reply with quote
Parts Hunt
I'm looking for a forward cockpit brake cable for an L-29. Does anyone have an extra or has anyone found a compatible replacement for this part.
I have looked in all of the manuals and could not find a "Part Number" to use for ordering a part.
Any advise would be great.
Dennis Mitchell
Houston Texas
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
taylor(at)snowcrest.net
PostPosted: Sat Mar 21, 2009 9:33 pm    Post subject: Brake Cable Replacement Reply with quote
Hi I have a large roll of brake cable or a new stick with cable,contact me
off list,Pete Taylor
thexporter
PostPosted: Sun Mar 22, 2009 4:16 am    Post subject: Re: Brake Cable Replacement Reply with quote
I should add one piece of information,
The "cable" I have is OK, the problem is the cable housing that it runs in has three locations that have a slight separation (kink) in it. If I lay the cable flat there is no trouble but if you have it installed the "Cable" snags the defects in the housing and hangs-up.
I tried locating a suitable replacement housing but so far nothing.
My e-mail address if you want to contact me directly is;
thexporter(at)earthlink.net
Thank you in advance,
Dennis
jorgen.nielsen(at)mweb.co
PostPosted: Sun Mar 22, 2009 12:46 pm    Post subject: Brake Cable Replacement Reply with quote
Hi Dennis
I am sure I have some of the outside sheath (original equipment) but live in
SA so shipping is a bit of a pain.
Let me know if you can't find there in the US and I can send you some- Will
have to let me know exact length, as I have a roll and will have to cut it.
Have you tried looking for "cable" shop? I have had cables made to order
previously : often you can create a superior replacement using e.g. Teflon
lined sheath.
Have you swapped the front / rear brake cable around?
Regards Jorgen
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
