Center of Gravity - CG
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
thexporter
PostPosted: Sat Mar 21, 2009 3:49 pm    Post subject: Center of Gravity - CG Reply with quote
Afternoon Everyone:
We are at a point on our restoration efforts of an L-29 to weight it and calculate the CG.
I have a major problem, I can not find in any of my manuals a CG chart or datum.
Any advise or info would be very appreciated.
Dennis Mitchell
Houston Texas
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
delfin(at)mail.pf
PostPosted: Sat Mar 21, 2009 5:35 pm    Post subject: Center of Gravity - CG Reply with quote
You have something in L29 Maintenance Handbook, weighting procedures ([url=http://www.l-29.org/6.htm)]http://www.l-29.org/6.htm)[/url]I have also this documents if it can help
Jean de Roubin
[img]cid:DA1C7150-A69F-4D89-A90E-95391A077DAC[/img][img]cid:D8206D7D-0723-416E-B071-E090D0381230[/img]
Le 21 mars 09 à 13:49, thexporter a écrit :
--> L29-List message posted by: "thexporter" <thexporter(at)earthlink.net (thexporter(at)earthlink.net)>
Afternoon Everyone:
Dennis Mitchell
Houston Texas
http://forums.matronics.com/viewtopic.php?p=235557#235557
- The L29-List --> &n========================<b -   &nbs --> ========================
 Filesize:  389.04 KB
 Viewed:  21656 Time(s)
 Filesize:  278.39 KB
thexporter
PostPosted: Sun Mar 22, 2009 4:22 am    Post subject: Re: Center of Gravity - CG Reply with quote
Dear Mr. Jean de Roubin
Thank you very much for the diagram, my French is very lacking but with the Internet I can translate what I need very easily and solve the mystery.
I really appreciate you taking the time to post this information for me.
Respectfully,
Dennis
delfin(at)mail.pf
PostPosted: Sun Mar 22, 2009 12:02 pm    Post subject: Center of Gravity - CG Reply with quote
My pleasure !
So long !
Jean
Le 22 mars 09 à 02:22, thexporter a écrit :
<thexporter(at)earthlink.net>
the mystery.
me.
Respectfully,
Dennis
http://forums.matronics.com/viewtopic.php?p 35608#235608
SD737(at)aol.com
PostPosted: Sun Mar 22, 2009 3:47 pm    Post subject: Center of Gravity - CG Reply with quote
Anyone out there need a complete set of L-29 Manuals? Aircraft and flight....
If so contact me directly (offline)
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
thexporter
PostPosted: Tue Mar 31, 2009 4:43 pm    Post subject: Re: Center of Gravity - CG Reply with quote
Everyone can get a free copy of the manuals via;
http://www.l-29.org/6.html
Thanks to there efforts to support the L-29 group.
BUT, if your offering a better quality English version of the manuals in a .PDF format or paper I'm interested.
My Engine manual (M701) is very difficult to read.
ershire
PostPosted: Thu Jan 16, 2014 1:54 pm    Post subject: Re: Center of Gravity - CG Reply with quote
What is the typical ballast required if any in the nose?
delfin29(at)me.com
PostPosted: Thu Jan 16, 2014 2:07 pm    Post subject: Center of Gravity - CG Reply with quote
If you means weight in the nose, typically nothing. Maybe, if the IFF in out, same weight as the IFF.
I have a air compressor at place of IFF on my L29, so it have the same weight, plus or minus.
Jean de Roubin
http://forums.matronics.com/viewtopic.php?p=417032#417032
Dawg
PostPosted: Thu Jan 16, 2014 2:45 pm    Post subject: Center of Gravity - CG Reply with quote
What have you removed from the airplane? I removed 400+ pounds of junk so I added 103 pounds in the nose.
Jean de Roubin
Dawg
ershire
PostPosted: Thu Jan 16, 2014 3:02 pm    Post subject: Center of Gravity - CG Reply with quote
Exactly, I too have 103lbs in the nose. My empty weight is 5193. How does that compare? On Jan 16, 2014 5:46 PM, "Bill Geipel" <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:[quote] --> L29-List message posted by: Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
On Jan 16, 2014, at 16:07, delfin29(at)me.com (delfin29(at)me.com) wrote:
> --> L29-List message posted by: delfin29(at)me.com (delfin29(at)me.com)
> Jean de Roubin
> Le 16 janv. 2014 à 21:54, ershire <jonairway(at)gmail.com (jonairway(at)gmail.com)> a écrit :
>> --> L29-List message posted by: "ershire" <jonairway(at)gmail.com (jonairway(at)gmail.com)>
rget="_blank">http://www.matronics.com/Navigator?L29-List
le, List Admin.
tr.9(at)westnet.com.au
PostPosted: Thu Jan 16, 2014 3:07 pm    Post subject: Center of Gravity - CG Reply with quote
There are some weights in the tail too isn't there Bill?
BTW, have you had your tail section off lately?
Frank
> Jean de Roubin
ershire
PostPosted: Thu Jan 16, 2014 3:14 pm    Post subject: Center of Gravity - CG Reply with quote
The weights are out of the tail and the tail was off in September for annual. On Jan 16, 2014 6:08 PM, "Frank Deeth" <tr.9(at)westnet.com.au (tr.9(at)westnet.com.au)> wrote:[quote] --> L29-List message posted by: Frank Deeth <tr.9(at)westnet.com.au (tr.9(at)westnet.com.au)>
Frank
On Jan 16, 2014, at 2:48 PM, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
>> Jean de Roubin
>>> Read this topic online here:
le, List Admin.
PostPosted: Thu Jan 16, 2014 3:48 pm    Post subject: Center of Gravity - CG Reply with quote
About how much weight was in the tail?
Frank
On 16 Jan 2014, at 3:02 pm, Jon S <jonairway(at)gmail.com (jonairway(at)gmail.com)> wrote:
> Jean de Roubin
le, List Admin.
ist"">http://www.matronics.com/Navigator?L29-List
delfin29(at)me.com
PostPosted: Thu Jan 16, 2014 4:53 pm    Post subject: Center of Gravity - CG Reply with quote
All radios and nav (radiocompass) were removed. Modern ones instead. As most is in the middle, it does not affect much center of gravity. As I have an air compressor in the nose right, place of IFF, my plane was weighted and is well balanced without any weight in the nose or in the the tail.
My empty weight is 5193 lbs with 28,85 % MAC.
Center of gravity should be beetween 20,5% and 25,5% MAC in flight (flight manual 5.Cool
It flies like this from many years and goes out of stalls and spins without any problems.
Jean de Roubin
> Jean de Roubin
Dawg
PostPosted: Thu Jan 16, 2014 5:24 pm    Post subject: Center of Gravity - CG Reply with quote
4995 empty weight.
On Jan 16, 2014, at 17:02, Jon S <jonairway(at)gmail.com (jonairway(at)gmail.com)> wrote:
> Jean de Roubin
le, List Admin.
cs.com
Dawg
Dawg
PostPosted: Thu Jan 16, 2014 5:25 pm    Post subject: Center of Gravity - CG Reply with quote
17 pounds in the tail. Steel plates.
Actually haven't even seen my jet since July and then only in passing.
Hang in there.
Frank
>> Jean de Roubin
Dawg
jorgen.nielsen(at)mweb.co
PostPosted: Thu Jan 16, 2014 10:24 pm    Post subject: Center of Gravity - CG Reply with quote
Hi Bill
Does yours not have the viper motor?
Hang in there.
> Cheers,
> Frank
> Sent from my iPad
>>> Jean de Roubin
Dawg
PostPosted: Fri Jan 17, 2014 5:23 pm    Post subject: Center of Gravity - CG Reply with quote
It does. Before I put the viper in, I removed 453 pounds and put in the 105 of weight in the nose.
The viper weights the same but sits about 15" aft of the 501. But since I've gained weight in my old age it still flys nice.
On Jan 17, 2014, at 0:23, Jorgen Nielsen <jorgen.nielsen(at)mweb.co.za> wrote:
Hi Bill
> Hang in there.
> Bill
>> Cheers,
>> Frank
>> Sent from my iPad
>>>> Jean de Roubin
Dawg
ershire
PostPosted: Fri Jan 17, 2014 5:37 pm    Post subject: Center of Gravity - CG Reply with quote
My jet is not slow, just overweight. On Jan 17, 2014 8:24 PM, "Bill Geipel" <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:[quote] --> L29-List message posted by: Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)>
On Jan 17, 2014, at 0:23, Jorgen Nielsen <jorgen.nielsen(at)mweb.co.za (jorgen.nielsen(at)mweb.co.za)> wrote:
> --> L29-List message posted by: Jorgen Nielsen <jorgen.nielsen(at)mweb.co.za (jorgen.nielsen(at)mweb.co.za)>
> Hi Bill
> Sent from my iPad
>> On 17 Jan 2014, at 3:28, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
>> Hang in there.
>> Bill
>>> On Jan 16, 2014, at 17:07, Frank Deeth <tr.9(at)westnet.com.au (tr.9(at)westnet.com.au)> wrote:
>>> Cheers,
>>> Frank
>>> Sent from my iPad
>>>>> Jean de Roubin
le, List Admin.
Dawg
PostPosted: Fri Jan 17, 2014 5:55 pm    Post subject: Center of Gravity - CG Reply with quote
But still fun.
On Jan 17, 2014, at 19:36, Jon S <jonairway(at)gmail.com (jonairway(at)gmail.com)> wrote:
> Hi Bill
> Sent from my iPad
>> Hang in there.
>> Bill
>>> Cheers,
>>> Frank
>>> Sent from my iPad
>>>>> Jean de Roubin
le, List Admin.
cs.com
Dawg
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
