		WurlyBird
  Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
				 Posted: Sat Mar 21, 2009 3:13 pm    Post subject: leaking fuel inside the wing |
				So after a month of being grounded, mostly due to waiting on a new windshield, I finally got everything back together and went flying today.  I soloed the Kitfox by the way.  As I was taking the plane apart I noticed some streaking emanating from the leading edge spar.  After the plane had sat in the garage for an hour I noticed a small puddle of fuel under the lower mount for the wing support.  It seems that fuel is leaking inside the wing and going down hill along the front spar, toward the fuselage in flight and toward the jury strut mount while folded.  There is about a gallon and a half in this tank so it could have sloshed, but there is no evidence that it came out any where near the gas tank cap.
 Is there any possibility that there is a problem that can be fixed with out replacing the fuel tank?  It seems like the only real possibility is that there is a small leak some where near the front of the tank.  Any other thoughts?
 Incidentally, I can not believe how absolutely awesome the KF3 handles solo with low fuel.  She is a completely different animal then when almost at gross.  I can see I am gonna get my ticket and then not want anyone to fly with me
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
		matronics(at)bob.brennan. Guest
				 Posted: Sat Mar 21, 2009 3:36 pm    Post subject: leaking fuel inside the wing |
				What kind of tank is it? The aluminum tank in my Model 2 is famous for
 leaking at the leading edge seam, most pronounced if the wing is folded.
 Sloshing with Kreem fixed it for me, although the proper fix is to replace
 it with a ethanol-resistant poly tank, which is on my to-do list.
 Bob Brennan - N717GB
 ELSA Repairman, inspection rated
 1991 UK Model 2 ELSA Kitfox taildragger
 Rotax 582 with 3 blade prop
 Wrightsville Pa
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sat Mar 21, 2009 3:59 pm    Post subject: leaking fuel inside the wing |
				James,
 Sounds like a bit of time with a wing off and sloshing with Kreem.  But
 first you will want to carefully examine the fuel system before that chore
 is started to make sure it is necessary.   When re-sloshing, remember to
 pre-rinse with acetone, keeping in mind that this process tends to produce a
 bit of out gassing and you will want to vent periodically.
 To close the filler neck while sloshing use a different cap that seals well
 so you won't Kreem the one you intend to fly with.  Also cover and tape up
 all exposed surfaces on the wing so any spilling won't kill your paint job.
 A couple of helpers is a good idea as well.
 Lowell
		dave
				 Posted: Sun Mar 22, 2009 4:25 am    Post subject: Re: leaking fuel inside the wing |
				James,
 If your tank is leaking then replace it . Sloshing is not the answer.
 Mc bean sells new tanks but i not sure what is involved in replacing with them.
 I have a Kitfox 2 to do soon and I pretty sure I will be using the wingtanks.com tanks    http://rotaxaircraft.com/forum/viewtopic.php?f=32&t=88
 This 2 Kitfox has no wing tanks now so i not  sure what i have to do yet.
 If you have existing tank it looks easy --jut fits inside of existing tank ( you know the one that leaks now. )  looks like a fast solution  that will work though.
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		WurlyBird
				 Posted: Sun Mar 22, 2009 7:47 am    Post subject: Re: leaking fuel inside the wing |
				They are fiberglass tanks, 2 x 6 gal.  I have pretty much come to the conclusion that replacing them is the thing to do, especially since the new tanks are ethanol resistant so that opens up more fueling options.  My primary concern is the fabric repair that will accompany the tank replacement.  Will I still need to take off the wings?  Am I just better off getting an A&P to do it?  I don't really feel like purchasing all the stuff to start spraying paint right now, especially not if I have to dish out about a grand for new tanks.
		WurlyBird
				 Posted: Sun Mar 22, 2009 5:32 pm    Post subject: Re: leaking fuel inside the wing |
				I checked out the Wingtank.com site and I like what I see. But I as well would like to hear some first hand experiences.  It claims that the tanks are installed inside the existing tanks but it the installation photos it shows the tanks being installed in just the wing.  I fear it sounds to good to be true.  Any one used these yet?
		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
				 Posted: Mon Mar 23, 2009 5:57 am    Post subject: Re: leaking fuel inside the wing |
				 	  | Quote: | 	 		  | They are fiberglass tanks, 2 x 6 gal. I have pretty much come to the conclusion that replacing them is the thing to do, especially since the new tanks are ethanol resistant so that opens up more fueling options. My primary concern is the fabric repair that will accompany the tank replacement. Will I still need to take off the wings? Am I just better off getting an A&P to do it? I don't really feel like purchasing all the stuff to start spraying paint right now, especially not if I have to dish out about a grand for new tanks. |
 If you determine that the tanks need to be replaced, the original tank style would be the easiest.  The wings would need to come off.  two people can easily take the wings off.
 I use a board padded on one end to prop up the wing tip, my wife holds on to the wing tip while I take the strut off and remove the wing to fuselage attach bolts from the spars.  Then we slide the wing off the attach lugs and set it on a sawhorse rack.  I guess the wings weigh about 50 pounds each.
 Cut the fabric next to the tank top edges, and bottom edges if the fabric is attached to the tank bottom.  Use fishing line to cut the RTV between the tank and spars and out the tank comes.
 You could then install the new tank and take the wing to someone who can replace the fabric over the tank bay.
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		Kfyellowbird(at)cs.com Guest
				 Posted: Fri Mar 27, 2009 7:34 am    Post subject: leaking fuel inside the wing |
				James
   I had a similar problem with a leak inside the wing with fuel running out the trailing edge.  Discover it was leaking from the lower site gauge fitting.  Removed fitting, applied some plumbers thread sealer.  ( find sealer that is resistant to petroleum products) End of leak.
  Lowell Schaper
  Kitfox Lite2 912S
  Installing Groves gear  [quote][b]
		akflyer
				 Posted: Fri Mar 27, 2009 8:39 am    Post subject: Re: leaking fuel inside the wing |
				Fuel Lube is made just for sealing the fittings on fuel systems.  Works great and does not get hard over time.
  _________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
		Fox5flyer Guest
				 Posted: Fri Mar 27, 2009 9:07 am    Post subject: leaking fuel inside the wing |
				Where do you find Fuel Lube anymore?  I bought a tube of EZ Seal (or Lube,
 can't remember which) from ACC.  Comes in a pretty big tube that will last
 about 4 lifetimes.
 Great stuff and exactly like Fuel Lube.
 Deke
 Please archive
		Dick Maddux
				 Posted: Sat Mar 28, 2009 3:48 am    Post subject: leaking fuel inside the wing |
				Tite Seal also works great for that type of sealing. I used to use Fuel Lube in my Pacer fuel valve to lube the action. I supose it would also work as a sealant.
                                                              Dick Maddux
                                                              Pensacola,Fl
  Feeling the pinch at the grocery store?  Make dinner for $10 or less.
