		AirMike
				 Posted: Sun Mar 22, 2009 9:32 am    Post subject: Exhaust system torque values - etc - Vetterman 2 stack |
				The info is pretty slim on the installation of the Vetterman dual stack system.
 Vans plans say to torque the exhaust nuts to 100-140 in/lbs
 Vetterman's sheet says to torque the nuts to 140-180 in/lbs
 Any idea which is preferred?????
 Also Vans says to use anti-seize on the nuts. Any suggestions for what this product is ..........???????
  _________________ See you OSH '18
Q/B - sold. |
		Jim Berry
				 Posted: Sun Mar 22, 2009 2:07 pm    Post subject: Re: Exhaust system torque values - etc - Vetterman 2 stack |
				Antiseize keeps the nuts from becoming permanently corroded to the exhaust studs. Look at Permatex 133A and similar products.
 Jim Berry
 40482
 N15JB
		AV8ORJWC
				 Posted: Sun Mar 22, 2009 4:05 pm    Post subject: Exhaust system torque values - etc - Vetterman 2 stack |
				Two Loctite products that we use are C5-A which is Loctite #51005, Copper based Anti-Seize Lubricant (good to 980 C / 1800F) and then for our turbine hot sections we resort to overkill with Loctite #51102, Nickel Anti-Seize (good to 1315C / 2400F).  If you like to look for cheaper Milspec alternatives it is MIL-PRF-907-E.
  It is always a good call to use nuts rated to the additional heat of a head flange or collector attachment.  I vote for the second and higher torques listed cause I seem to remember a hardware improvement over stock configuration.
   John Cox
  Do not Archive
   From: owner-rv10-list-server(at)matronics.com on behalf of Jim Berry
 Sent: Sun 3/22/2009 3:07 PM
 Subject: Re: Exhaust system torque values - etc - Vetterman 2 stack
 --> RV10-List message posted by: "Jim Berry" <jimberry(at)qwest.net>
 Jim Berry
 40482
 N15JB
 http://forums.matronics.com/viewtopic.php?p=235712#235712
 http://www.matronic--> http://forums.matronics.com
 p;         - List Contribution bsp;                    -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
		AirMike
				 Posted: Tue Mar 24, 2009 8:41 am    Post subject: Exhaust system torque values - etc - Vetterman 2 stack |
				Larry at Vetterman informed me that the bolt that he supplies with the exhaust kit are stainless steel and have a higher torque value than the Vans bolts. He said torque to about 150# is fine. With the SS bolts he said the anti seize is not needed
Q/B - sold. |
