		naumuk(at)alltel.net Guest
				 Posted: Wed Mar 22, 2006 3:24 pm    Post subject: Aileron stiffness and force - XL |
				Bill-
     The owner of the HDS had a pretty good response to the passenger angle.
 90% of the time, he flew solo. 9.999% of the remaining time, he flew with
 his wife. My wife has to weigh 60 lbs less than I do, so there will still be
 more weight in the left seat and I should still come out ahead. The less
 trim you have to use, the less wind resistance. The less wind resistance,
 yada yada yada. It all depends on your projected usage, and it's not like I
 put both tanks on one side or anything outrageous.
     Of course, this "Fix" wouldn't work for Jack Spratt.
 Bill
                                                 Hey, at least it's not
 Darryl and Darryl!
        Do not
 archive
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		JAPhillipsGA(at)aol.com Guest
				 Posted: Wed Mar 22, 2006 6:57 pm    Post subject: Aileron stiffness and force - XL |
				Bill, to tell you the truth I can't tell any difference in speed alone with
 aileron trim up. Never have pushed it to see max speed (beyond 3K rpm) so the
 difference must be very slight. Have noticed a slight decrease with elevator
 trim though, but to balance the plane hands off for ease of flying the minor
 speed loss is negligible. I usually worry more about fighting head winds. Flew
 the other day, doing 140 plus, looked at the GPS, said ground speed was 67 !
 Yugos going up hill were passing me. Best regards, Bill of Georgia
		lgingell
  Joined: 10 Jan 2006 Posts: 50 Location: Lake California Airpark 68CA
				 Posted: Mon Mar 27, 2006 12:24 pm    Post subject: Re: Aileron stiffness and force - XL |
				Andrew,
 My flaps were a little off too. I removed the flap made a new end rib, with a new hole, re-rivted the bushing on and put it back on. My glide is much better, and the handling is MUCH better.
  	  | AndrewC wrote: | 	 		  | It looks as though the source of the problem is that my right wing is generating slightly more lift than the left one.  There are two possible cuplrits: one flap appears to be a couple of millimetres lower than the other |
 Cheers,
 ..lance
 http://lancegingell.com/plane.asp
  _________________ Zodiac XL/Jab 3300
http://lancegingell.com |
