janderson412(at)hotmail.c Guest
Posted: Tue Mar 21, 2006 3:21 pm Post subject: It Flew! Cooling. |
Thanks Rick, yes you MUST miss your toy. I'm so impressed how well my bird
flies, smooth and controls feel as good as a Beaver... I've only done 6
circs so far so not tested much in the cruise yet. About to have another fly
today. Oil temp seems good, the engine is pulling around 5psi of boost, is
that compatable with what yours used to do? John
Subject: RE: It Flew! Cooling.
Date: Tue, 21 Mar 2006 09:24:03 -0800
Posted: Tue Mar 21, 2006 3:23 pm Post subject: It Flew! Cooling. |
Thanks Kurt, no where would I get one of those... big rad. If you could give
me the dimensions I could look at getting one made as big cost to get one
sent all this way from State side. John
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Subject: Re: It Flew! Cooling.
Date: Tue, 21 Mar 2006 08:23:56 -0800 (PST)
Hi John,
With those temps and OAT, you might get what you want
from just changing to the big alum radiator. That
should be an easy change for you if you can get your
hands on one.
Your pics show a lot of great work and invention by
you. You deserve to see that plane fly embarrassingly
well. Sorry if your friends with store bought
planes won't talk to you after riding in your's later.
Ha ha
If you take a side picture of your complete plane and
turn it upside down as in inverted flight, you can
suddenly see where the front of the cowl is a high
lift (low pressure) area. We are used to seeing this
on our wings, but the air doesn't know right side up
from inverted, so we miss seeing what the air is doing
here because of our point of view. We tend to think
of lift only going up, but it doesn't.
Bugs show you dynamic pressure, but not static
pressure. In this place on the cowl the 2 are in
conflict.
VG's would net you a little more dynamic pressure, but
the bigger radiator might take care of it all.
I also have my radiator air and cowl air seperated and
agree that is the best route for cooling.
Got to go to work now. Hope you can get an alum
radiator and fly it in confidence from then on.
Kurt S.
--- John Anderson <janderson412(at)hotmail.com> wrote:
> Sorry Kurt, I wrote this below in a rush but I think
> you'll get my gist. I uploaded so shots at
http://www.sportflight.com/cgi-bin/uploader.pl?action=view&epoch=1142915948.
> John
> Hmm Kurt, I thought that area is still pretty high
> pressure still where I
> have the inlet and where the radiator is is low
> pressure. If you look at the
> cowel around that area, thats were all the bugs hit
> and that's usually high
> pressure. The plenum area to the radiator is
> seperate from the engine air
> except for the lower part of the sump (cooling piped
> and finned) and this
> sees the radiator air also. My temps are oil, around
> 190 F approx (we all
> C here) and water water 210F approx 110C. I also
> have an Earls heater
> cooler also in the heater circ which is hooked to
> the water/oli cooler and
> turbo. I've opened the exit area to the main cowl a
> bit so hope this will
> enhance the airflow to this radiator and help the
> intercooler as it exhausts
> into this area. The OAT is around 23c. John
Read the latest Hollywood gossip (at) http://xtramsn.co.nz/entertainment
trebla(at)directinter.net Guest
Posted: Tue Mar 21, 2006 5:52 pm Post subject: It Flew! Cooling. |
I looked at the pics. Nice setup. How is the cowl seal to the radiator? I
also had to put cowl behind the radiator to keep the air from boiling up
behind it and reducing flow through it. Also had to manage the airflow over
the engine through the cowl to help as much as possible.
Albert Smith
wingsdown(at)comcast.net Guest
Posted: Tue Mar 21, 2006 6:42 pm Post subject: It Flew! Cooling. |
I am not sure what altitude you are stating from, but if you are using
stock turbo pistons you should be at about 7PSI boost at sea level. The
stock pot is set to that. Again depends on RPM for gas flow to spin the
turbine. If your RPM is at 5200 or higher you should be showing 7PSI.
What turbo are you using? Infact with the fuel injection and intercooler
I would expect you could easily adjust up to 12PSI with no problems. But
if your not getting red of the heat your making, little sense in that. I
found the larger turbo model aluminum radiator provided by NSI to be
adequate for cooling, but its placement was critical for getting enough
air flow on the ground and at high AOA on full power climbs. I think you
have an excellent start with the design you have. May need more aft
radiator cowl work and design, possibly a ground or climb cooling fan.
Let me know if you have any specific questions. So many ways to skin a
cat.
Do you have a way to measure your intake temps or the delta across the
intercooler?
Rick
Posted: Tue Mar 21, 2006 10:03 pm Post subject: It Flew! Cooling. |
Hi John,
Right now I am on your side of the equator and a long
way from my Fox, so I am sorry I cant measure it just
yet. That I remember, the face is 6 inches high by 20
wide and 4 inches thick. This does not include the
closed ends that are about 2 inches wide on both
sides.
Rick or another turbo driver might be able to get the
actual dimensions for you sooner.
I think it is the same frontal area as yours and
should slip right in so you can keep the cowl the
same. It is just thicker. You could just design a
replacement like that. Same front, but twice as
thick. The aluminum rad was hardly any heavier than
the brass one too, even though it was bigger.
Hope this helps.
Kurt S.
Posted: Tue Mar 21, 2006 10:27 pm Post subject: It Flew! Cooling. |
Rick,
Oh wise turbo man.... I have about a 10 degree rise
from OAT across my oil cooler in cruise. (As measured
by a temp bulb behind the cooler) I expected more.
Is this normal, or am I sized wrong for the airflow?
Kurt S.
Quote: | ...Do you have a way to measure your intake temps or
the delta across the intercooler?
Rick
Posted: Wed Mar 22, 2006 12:16 am Post subject: It Flew! Cooling. |
Thanks for that Kurt. Well, I think I found the problem as suggested. After
running the engine until the temp was right up, I left it idling and got out
and fely the radiator and - bingo- the botom was STONE cold!! So all I can
say is the the small heater one is working reall well to keep the temps
where they were! So I'll get the feed end tank removed and so what goes but
it certainly is not flowing!! I'll let you know, do you have any data on the
other reported defective unit? John
Date: Tue, 21 Mar 2006 21:59:12 -0800 (PST)
Hi John,
sides.
Hope this helps.
Kurt S.
Check out the latest video (at) http://xtra.co.nz/streaming
Posted: Wed Mar 22, 2006 12:22 am Post subject: It Flew! Cooling. |
My plan to measure the delta T once I get cooling sorted, you'll see my note
to Kurt re the rad. Sea level and I have an EA82 turbo, the idea being it
would not be getting it neck rung out at the higher revs compared the
automotive use. But from how the engine is going and power available, I
thing I'd prob be cruising around 4k or a little higher, not 5 like the
normall aspirated chaps seem to be. John
Date: Tue, 21 Mar 2006 18:40:14 -0800
cat.
intercooler?
Rick
Posted: Wed Mar 22, 2006 12:25 am Post subject: It Flew! Cooling. |
Cowl seal is good Abert, what shape etc is you exit cowl? Does it reduce to
speed up the air again? John
Date: Tue, 21 Mar 2006 18:50:43 -0700
Albert Smith
Discover fun and games at (at) http://xtramsn.co.nz/kids
Posted: Wed Mar 22, 2006 7:04 am Post subject: It Flew! Cooling. |
I am not sure then John. The EA-82 is a bit different. Depending on
turbo size the 5 PSI boost may be right for the RPMs your turning. The
Turbo EA-81 torque band is between 3800 and 4200. So in cruise I would
suspect you should be fine. I wouldn't lug the engine on take off 5200
for best not most power, but also no need with that engine to run 6200
for most power either. AS you know there are a lot of variables to
consider when you have a turbo. Do you have an in-flight adjustable
prop? Just am aside you should be able to run LOP with that injector set
up which will save you some fuel, besides the Subaru likes lean anyway.
Another aside. Should for some reason you engine quite suddenly and it
didn't blow up. I would pull the fuel immediately then try restart. If
you don't there is a good chance the turbo will continue to spool and
pull fuel into the cylinders and wet them severely enough that a restart
might not happen. OK, old here, never mind you are hi teck injected
engine not crab or Ellison.
Rick
Posted: Wed Mar 22, 2006 7:15 am Post subject: It Flew! Cooling. |
Humm, you mean from the inlet not OAT? The OAT is not the starting
point. It would be the oil temperature drop from the oil inlet to outlet
side. The air is being heated by the oil but has no relation to what the
drop in oil temp is across the cooler. No doubt there is a rise on both
ends. One thing I would recommend in an oil thermostat like the one I
installed from Mocal. But like all things open to another's perspective.
Mine worked very well and regulated oil temp great. I think more
important than the size of the cooler is its placement for air flow.
Going back, I am not saying the OAT is not relative but for what your
looking for not so much now. What is you full power climb peak oil temp
and cruise oil temp?
Rick
Posted: Wed Mar 22, 2006 3:33 pm Post subject: It Flew! Cooling. |
No, just ground adjusable Rick. You wrote? (Just am aside you should be able
to run LOP with that injector set up which will save you some fuel, besides
the Subaru likes lean anyway.)?? Not sure what you mean here? And with EFI,
if the engine quits the fuel will stop as the signal wil be gone, right?
John A.
Date: Wed, 22 Mar 2006 07:01:53 -0800
Rick
Posted: Wed Mar 22, 2006 6:30 pm Post subject: It Flew! Cooling. |
Yep, I think if had had a EFI I would still be flying. LOP is lean of
peak. If your not familiar with it you might want to do your own
research and come to your on opinion. There is much controversy. But if
it was good enough for war time when it all counted on getting there and
home I think it has many advantages even beyond fuel savings.
Rick
Posted: Wed Mar 22, 2006 7:42 pm Post subject: It Flew! Cooling. |
My EFI is lap top reprogramable with an LED readout in the c/pit so I have
it all set to read green, nice for dummys...
Date: Wed, 22 Mar 2006 18:28:07 -0800
Rick
shaun-s(at)sbcglobal.net Guest
Posted: Wed Mar 22, 2006 9:50 pm Post subject: It Flew! Cooling. |
take me off your list
To:
Rick
