Lynn Matteson
Posted: Fri Mar 27, 2009 1:02 pm Post subject: Wake Turbulence in a Kitfox |
I had my first encounter with wake turbulence today. I had landed at
KPTK (Pontiac, Mich...class D airspace, with customs service, so that
may give an idea of its' busy-ness) and after a brief stay on the
ground, I taxied to hold short of 27L for takeoff, staring across the
runway into the intakes of a small twin-engine jet that was next to
take off on this runway. The tower gave him the takeoff clearance,
and away he went. I then got the tower clearance for me to go with
the warning that I might encounter wake turbulence, and I could wait
until I was comfortable to go...but "take all the time you want."
After a long minute or so, I told the tower that I could probably
take off, if I could climb out (way) shorter than his rotation point,
and turn left when I wanted to, and got the ok to go. The wind was
pretty much right down the runway, and about 13 knots, so I knew I
could lift pretty good. I started out, and when aloft....very short
rollout....I got a pretty good left-bank roll from his turbulence.
The angle was a good 30+ degree bank, and I was really feeling the
roll caused by his plane. It was pretty brief, and no *big* problem,
but it really got my attention. This airport...the second largest in
Michigan operations to only Detroit's class B...is a very busy 'port,
so I didn't want to waste anybody's time sitting there, so I took off
maybe a little too soon, but it worked out for me...this time. Next
time I'll wait a bit longer and let the rest of the waiting planes
wait. I had about half of a full fuel load (half of 26 gallons), and
the extra weight probably helped stabilize the plane a bit, so I'm
not sure that I'd want to try this procedure with a lighter-loaded
plane.
Lynn Matteson
Jabiru 2200, #2062, 618.4 hrs
Sensenich 62x46
Status: flying
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
matronics(at)bob.brennan. Guest
Posted: Fri Mar 27, 2009 1:28 pm Post subject: Wake Turbulence in a Kitfox |
In case you hadn't calculated it out Lynn - with the wind at 13 knots
straight down the runway his wake turbulence was moving towards you at 1,316
feet per minute, so in that "long minute" the distance between your take-off
roll and his put you right where his turbulence was. I'm open to discussion
here but I think that if you took off immediately after him you would have
been fine, or more than 2 or 3 minutes after when the turbulence had blown
past the end of the runway where you were waiting.
Does that make sense? (sanity check) And also no way I would have thought of
that in the cockpit rather than in front of the 'puter, but I will from now
on!
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade prop
Wrightsville Pa
Lynn Matteson
Posted: Fri Mar 27, 2009 1:51 pm Post subject: Wake Turbulence in a Kitfox |
That makes sense to me, Bob, so that means it must be wrong. : )
Seriously, it sounds like it would do as you describe. I'd like to
hear what others think, also. The clockwise rotation of the
turbulence from the left wing would do to me just what I felt it do.
On the ground while waiting, I couldn't remember which direction the
turbulence rotates, but I found out later that it is clockwise
viewing from the rear of the lead aircraft on the left wing, and
counter-clockwise from the right wing. Because my right wing lifted,
I figured I ran into his clockwise-rotating turbulence coming from
his left wing...he was using the right side of the runway, and I was
using the left side.
All the diagrams that I have seen say to land beyond his touchdown
point, or lift off before his rotation point, which is what I did,
but I guess I didn't wait long enough.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 27, 2009, at 5:27 PM, Bob Brennan wrote:
<matronics(at)bob.brennan.name>
at 1,316
take-off
discussion
would have
had blown
thought of
from now
on!
Wrightsville Pa
N369LM |
Posted: Fri Mar 27, 2009 2:06 pm Post subject: Wake Turbulence in a Kitfox |
All my book learnin' said the same thing to me - "land beyond his touchdown
point, and lift off before his rotation point", but his rotation point is
relative to the runway, while his turbulence will be relative to the air
mass which in this case was moving down the runway towards you. Turbulence
can't sit at a fixed point on a runway, it is a rotation *of* the air mass
at the point the plane took off. If that air mass moves, so does the
turbulence. I think...
Think raindrop in a lake - a radiating pattern of turbulance. Now think
raindrop in a fast-moving stream, does the pattern travel with the water or
stay exactly where the drop hit relative to the earth?
That should be in the AIM someplace...
Wrightsville Pa
Lynn Matteson
Posted: Fri Mar 27, 2009 2:35 pm Post subject: Wake Turbulence in a Kitfox |
I recall reading that if the wind is blowing from left to right,
across the runway, that turbulence might just come from runway xxL to
runway xxR, and bite you if you are on the right-side runway, so if
it's coming down the runway...the wind, that is...it stands to reason
that it will bite you if you are both on the same runway. Just
another case of needing to stay current on ALL phases of flying,
which I try to do. I just hadn't brushed up on my turbulence factors
in a while....I will now!
Lynn Matteson
Sensenich 62x46
Status: flying
touchdown
point is
the air
Turbulence
air mass
think
water or
Wrightsville Pa
N369LM |
MDKitfox(at)aol.com Guest
Posted: Fri Mar 27, 2009 7:17 pm Post subject: Wake Turbulence in a Kitfox |
Lynn,
I'm no expert on wake turbulence, but I've been there. It's real, it's dangerous, and should be given a wide berth. I've been rolled 90 degrees while on approach. This was from a 747 - I was in a CRJ-200. We were going into JFK and were 6 miles behind the 74 at 3000 feet, he was at 4000. The roll was quick and exhilarating. I know the passengers didn't like it, heck, we didn't like it! We also had a similar, but less exciting, experience at Atlanta behind a 757. Bottom line, we were at the legal distance behind the other aircraft and still had the encounter.
Remember, the winds aloft are frequently different than those on the surface, all the calculations on the location of the wake based on the ground winds are estimates and remain suspect. The best defense is to wait out the max time, especially in low wind conditions where the wake can linger (yes, I believe it can be stationary on the runway for quite a while) or be blown across the runway at a leisurely pace. I wouldn't go early unless you're absolutely convinced you know the wind environment.
If the other guys get impatient, that's their problem. Clearing debris off the runway, i.e. the remaining parts of your Fox, is a lot longer delay for them and will likely ruin your day. If they want to go, let them. You may have the basis for some good hangar stories as you watch the ensuing aerobatic show.
Just my two cents.
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Mar 27, 2009, at 6:31 PM, Lynn Matteson wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I recall reading that if the wind is blowing from left to right, across the runway, that turbulence might just come from runway xxL to runway xxR, and bite you if you are on the right-side runway, so if it's coming down the runway...the wind, that is...it stands to reason that it will bite you if you are both on the same runway. Just another case of needing to stay current on ALL phases of flying, which I try to do. I just hadn't brushed up on my turbulence factors in a while....I will now!
Lynn Matteson
Sensenich 62x46
Status: flying
[quote]--> Kitfox-List message posted by: "Bob Brennan" <matronics(at)bob.brennan.name (matronics(at)bob.brennan.name)>
Wrightsville Pa
Lynn Matteson
Posted: Sat Mar 28, 2009 2:19 am Post subject: Wake Turbulence in a Kitfox |
Thanks for the advice, Rick...I think what really drives your message
home is the words "Clearing debris off the runway, i.e. the remaining
parts of your Fox". That'll stick in my memory from here on out.
Lynn Matteson
Sensenich 62x46
Status: flying
Just my two cents.
Rick Weiss
SkyStar S/N 1
Port Orange, FL
N369LM |
Posted: Sat Mar 28, 2009 3:49 am Post subject: Wake Turbulence in a Kitfox |
Lynn,
Those same words stuck with me. A friend of mine is developing a light jet kit and during flight test, the aircraft was cleared for takeoff with the usual admonition of 'caution wake turbulence'. What the test pilot didn't know was a large (compared to his aircraft) DH-8 had taken off about 1 minute prior, yet the tower didn't hold him the required time. We've all been there. The winds were light and the light jet hit the wake, rolled 90 left, knife-edged into the runway and continued down the runway after cartwheeling a few times. The only parts remaining were the cabin and engine. The two guys inside opened the door and walked out unharmed. My buddy had decided early on to build a strong composite cabin, and he was successful. It took hours to clear the debris. BTW - the cabin was on display at Oshkosh a couple of months later. The inside was like new, but the bottom was scrapped up pretty good. The pilot and engineer were at the show talking about the encounter.
Rick Weiss
SkyStar S/N 1
Port Orange, FL
Thanks for the advice, Rick...I think what really drives your message home is the words "Clearing debris off the runway, i.e. the remaining parts of your Fox". That'll stick in my memory from here on out.
Lynn Matteson
Sensenich 62x46
Status: flying
Just my two cents.
Rick Weiss
SkyStar S/N 1
httpp;--> http://forums.matronics.comsp; - List Contributionsp;  href="http://www.matronics.com/contribution">http://www.matronics.com/cont================
= [quote][b]
Dick Maddux
Posted: Sat Mar 28, 2009 4:13 am Post subject: Wake Turbulence in a Kitfox |
Lynn,
I was holding short one time in a B737at Atlanta and saw a small aircraft almost rolled into a ball when he taxied onto a runway for takeoff when just vacated by an airliner. I am sure some seats needed cleaning. It is good no damage occured to your aircraft and realistically the time you waited should have been enough but the Kitfox is such a light aircraft.( a kite with wheels)
I have timed my departure delay for one minute on my watch before departing behind a jumbo jet (irritating the controller sometimes as it is rather long) and still had a lot of wake vortices from the departing aircraft to deal with. A few times full aileron and appropriate rudder were called for. Theoretically, the vortices along the ground are the size of the aircraft wingspan and growing.
Bet you don't do that again!
Dick Maddux
Fox 4
Pensacola,Fl
Feeling the pinch at the grocery store? Make dinner for $10 or less.
Dick Maddux
Posted: Sat Mar 28, 2009 4:47 am Post subject: Wake Turbulence in a Kitfox |
Lynn,
You did exactly what you should have done. The only thing you could have done better is to wait longer. You absolutely should not take off sooner as you have a very good chance of going into the strongest engine thrust and associated turbulence (this stuff stays on the runway for a while)
Every year, before I retired, we had to attend training. Part of that training was wind shear and wake turbulence avoidance. They showed films of various jet aircraft with smoke generators at the wing tips and you could watch the pattern. I believe the flow was counter clockwise as the flow tends to flow toward the wing at the tips. The prevailing wind was a big factor as to were the dual vortices would go. They could stay on the runway or blow to either side. Seeing it visually, with the smoke, really helped. In any case the idea during take off was to climb above the departing aircraft's climb path if you could, or wait longer.
Under different wind conditions you might not have experienced a problem. Waiting longer is always the best option. Using a smaller airport with smaller airplanes is even better!
Santa Anna, Ca is a prime example of mixing big jets and general aviation aircraft. It was always a challenge landing there in an airliner (slam dunk to a short runway) and you really had to watch your engine thrust around the multiple small aircraft. I always saw "the little guys" (I am now one) pull to the side and wait anytime the heavier aircraft departed. They learned quick. Thrust and wing tip vortices will eat your lunch!
Sorry about the long dissertation but I guess early in the morning and too much coffee does it. It's great to be retired! Sure am happy I fly for fun.
Dick Maddux
Fox 4
Pensacola,Fl
Lynn Matteson
Posted: Sat Mar 28, 2009 8:50 am Post subject: Wake Turbulence in a Kitfox |
When I once took off into a known thickness of fog, and got myself in
"no visibility" conditions, I wrote in the logbook "Don't do this
again".....I'll be making another such entry after yesterdays'
encounter. Thanks for the report, Dick.
Lynn Matteson
Sensenich 62x46
Status: flying
growing.
Dick Maddux
Fox 4
Pensacola,Fl
less. _-
www.matronics.com/contribution _-
N369LM |
Lynn Matteson
Posted: Sat Mar 28, 2009 8:54 am Post subject: Wake Turbulence in a Kitfox |
I hope I can always end a tale with "at the show talking about the
encounter". Of course, better yet would be "no problems on today's
flight" !
Lynn Matteson
Sensenich 62x46
Status: flying
Rick Weiss
SkyStar S/N 1
Port Orange, FL
> here on out.
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> Electroair direct-fire ignition system
> Status: flying
>> Lynn,
>> encounter.
>> Just my two cents.
>> Rick Weiss
>> SkyStar S/N 1
N369LM |
peteohms
Posted: Sat Mar 28, 2009 2:57 pm Post subject: Wake Turbulence in a Kitfox |
Even wake turulence behind small planes can get you upset in a light sport. I was with an instructor getting checked out in a Sky Ranger and landing behind a T-34 single engined navy trainer, not really that close. The Sky Ranger banked what seemed like 60 degrees. We were 100'+ on final but recovered ok.
Pete
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Lynn Matteson
Posted: Sun Mar 29, 2009 2:42 am Post subject: Wake Turbulence in a Kitfox |
Yes, now that you mention it, I've felt it behind smaller planes at
altitude, too. I've even run into my own during 360° turns. But this
one at low altitude really got my attention, probably because of the
close proximity to the ground, and because the other plane was so far
away...but not far enough as it turned out.
Lynn Matteson
Jabiru 2200, #2062, 622.1 hrs
Sensenich 62x46
Status: flying
On Mar 28, 2009, at 6:55 PM, Pete Christensen wrote:
Quote: | Even wake turulence behind small planes can get you upset in a
Pete
============================================================ _-
contribution_-
N369LM |
dave
Posted: Mon Mar 30, 2009 3:28 am Post subject: Re: Wake Turbulence in a Kitfox |
Your vortices spiral out and down from your tips.
A cool experiment , in early am with light fog and no wind about 4 to 10 feet thick , fly along a field or grass runway so you are just in the fog at cruise or faster and yank her back. Look out your back window or turn and look at what you just did.
That would make a neat video. Who will be first to post it ?>
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Fox5flyer Guest
Posted: Mon Mar 30, 2009 3:47 am Post subject: Wake Turbulence in a Kitfox |
Quote: | Your vortices spiral out and down from your tips.
Are you pretty sure about that? I've always seen it the opposite.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
dave
Posted: Mon Mar 30, 2009 4:08 am Post subject: Re: Wake Turbulence in a Kitfox |
Deke,
What I meant to say , I will make it clear
they rotate inwards but move outwards from the wingtips and down wards
I can remember during IFR training being behind a heavy in a 182 or 172 under the hood at night and rolling past 90s degrees a few miles behind.
do you needs a pic ?
Dave
dave
Fox5flyer Guest
Posted: Mon Mar 30, 2009 4:40 am Post subject: Wake Turbulence in a Kitfox |
Nope.
Dave
Lynn Matteson
Posted: Mon Mar 30, 2009 4:51 am Post subject: Wake Turbulence in a Kitfox |
"Whenever an airplane generates lift, air spills over the wingtips
from the high pressure areas below the wings to the low pressure
areas above them."
(Private Pilot Manual....Jeppersen/Sanderson)
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 30, 2009, at 7:46 AM, fox5flyer wrote:
Quote: |
<fox5flyer(at)idealwifi.net>
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
N369LM |
