		bbradburry(at)allvantage. Guest
				 Posted: Tue Mar 21, 2006 7:09 am    Post subject: Vans type alternator |
				I just bought an ND alternator, Lester #14684.  This is the same
 alternator supplied with Vans kits.  The regulator used in the
 alternator is the IN219.  The terminal identification is D-IG-L.
 I was looking into how to control the field on this alternator and I
 have the following questions which I hope someone can answer.
 The repair circuit is TRI219.  Comments are: Ignition activated.  Load
 Dump protected,  L-Terminal does NOT drive a choke.  Overvoltage detect
 point is 17.0 V.
 Does this mean that the alternator has its own OV protection?
 Does this mean that the B&C OV module wired into the IG will control the
 field?
 Any comments on how to wire this alternator would be greatly
 appreciated.
 Bill Bradburry
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		nuckollsr(at)cox.net Guest
				 Posted: Wed Mar 22, 2006 7:48 am    Post subject: Vans type alternator |
				At 10:08 AM 3/21/2006 -0500, you wrote:
 <bbradburry(at)allvantage.com>
      . . . don't understand this . . . something to do
      with electrically heated choke on carburetor?
  	  | Quote: | 	 		     Overvoltage detect point is 17.0 V.
      Probably not. The upcoming publication of the MC33092 internal
      regulator chip study will show that there is no 'protection"
      offered by this particular chip. The lv, ov sensor circuits
      only drive the warning light.
      From an aviation perspective, 'protection' means active
      override of the effects of a hazardous event. To simply
      light a bulb is 'annunciation' or 'notification' and not
      'protection'.
      Of course, to really know if any particular product truly
      offers what advertisements claim, one must dissect the
      schematics, block diagrams, etc. Which is what I've done
      with the MC33092. Now, the alternator you have may indeed
      offer what it advertises . . . but without seeing the detailed
      data (or testing it on the bench) you cannot know for sure.
      Further, I nor anyone else will be able to advise you from a
      position of knowledge.
  	  | Quote: | 	 		  Does this mean that the B&C OV module wired into the IG will control the
 field?
      Probably not.
  	  | Quote: | 	 		  Any comments on how to wire this alternator would be greatly
 appreciated.
      Wire it per Van's recommendations . . . for now. The next greatest
      thing is in the works. I've finished one of the test tools
      needed to quantify design parameters for achieving absolute,
      any-time, any-conditions, no-hazard control over an internally
      regulated alternator. Folks with an interest in having this
      capability will be able to take advantage of it. Folks not
      interested can wire per Van's suggestions. It will be easy to
      add to a Van's-style installation.
		klehman(at)albedo.net Guest
				 Posted: Wed Mar 22, 2006 6:34 pm    Post subject: Vans type alternator |
				Yup.
 Some carbed vehicles used to feed the electrically heated automatic
 choke from the L terminal of the alternator. This alternator won't
 supply sufficent current on the L lead for that purpose.
 Ken
 Robert L. Nuckolls, III wrote:
				 Posted: Thu Mar 23, 2006 5:32 am    Post subject: Vans Type Alternator |
				Snip...
  	  | Quote: | 	 		  I just bought an ND alternator, Lester #14684.  This is the same
 Snip...
 Now I am really confused.  I assumed that this was a reference to an
 electric device called a choke and was wondering  how that played into
 alternators.
 Bill Bradburry
				 Posted: Thu Mar 23, 2006 5:44 am    Post subject: Vans Type Alternator |
				Whoops!!  I should have read on down the list before replying!!
 Thanks, Ken
 Bill Bradburry
 Yup.
 Ken
				 Posted: Thu Mar 23, 2006 6:25 am    Post subject: Vans Type Alternator |
				At 08:28 AM 3/23/2006 -0500, you wrote:
 Snip...
 Snip...
 alternators.
     Yeah, there is an electrical device called a "choke" or more
     properly, an "inductor". However, there are chokes on carburetors,
     shotguns and no doubt many more in other venues.
     The terminal capable of bringing out the kind of energy necessary
     for heated choke operation was the center tap of a wye-wound
     alternator and was usually labeled 'aux'. One could get 1/2
     system voltage at mucho current from this terminal. Of course
     it was only present when the engine was running and the alternator
     performing normally. It made an ideal power source for gradual
     warming of the bi-metal spring that closed the choke in cold
     weather to keep the engine running reasonably smooth until
     it got warmed up.
     Haven't seen an 'aux' terminal on a new alternator in many
     moons. Since the advent of electronically controlled fuel
     injection, the need for them in cars has faded away.
       < What is so wonderful about scientific truth...is that >
       < the authority which determines whether there can be   >
       < debate or not does not reside in some fraternity of   >
       < scientists; nor is it divine. The authority rests     >
       < with experiment.                                      >
       <                            --Lawrence M. Krauss       >
		brian
  Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
				 Posted: Thu Mar 23, 2006 7:51 am    Post subject: Vans Type Alternator |
				Bill Bradburry wrote:
  Snip...
  Snip...
  alternators.
 Ha, this is funny.
 Many cars have an automatic choke that comes on when the car is cold and
 goes off when it warms up. Some of these are electrical and use the
 stator output of the alternator to drive the heating element in the
 choke on the carb. The logic is, if the alternator is not turning, the
 engine is not running and the choke should not open. When you start the
 car and the alternator comes on-line, the choke starts to open. It works
 pretty well ...
 .. and has absolutely nothing to do with airplanes.
 Brian Lloyd                         361 Catterline Way
 brian-yak at lloyd dot com          Folsom, CA 95630
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 - Antoine de Saint-Exupery
  _________________ Brian Lloyd
- Antoine de Saint-Exupery |
