mccarthy(at)jefnet.com Guest
Posted: Tue Apr 07, 2009 7:52 am Post subject: MV-09 Dreaming-Flight planning- maybe just dreaming |
I'm a long time reader of the list, and would love to fly out to MV to meet
the group, and see the area, but have way too many hurdles to jump to be
possible. I live 70 miles south of Oshkosh, WI, have no "real" cross
country time, no mountain experience, and a very unpredictable work
schedule. I have a original Firestar, but just for flying around the area,
and have a Zenith 601HD 912ul for getting around. The Zenith cruises just
fine between 80-100MPH, with a 3 hour duration, but can't land where a Kolb
can.
First off, for flight planning, should I would fly to Albuquerque and then
up to MV to avoid the higher elevations? Secondly, is anyone from the upper
Midwest considering this trip? I believe there is courage, knowledge, and
strength in numbers.
In summary, this will probably just have to stay on my wish list, but I am
one of those who enjoys the planning as much as the trip.
Tom McCarthy
Firestar N441TM
Zenith 601HD N514TM
Posted: Tue Apr 07, 2009 8:28 am Post subject: MV-09 Dreaming-Flight planning- maybe just dreaming |
| Quote: | I'm a long time reader of the list, and would love to fly out to MV to
meet
area,
Kolb
can.
upper
Tom McCarthy
Firestar N441TM
Zenith 601HD N514TM
Tom Mc:
It's about 1200 statute miles from your home to MV, straight line distance.
With good wind and weather, you could make that in two days, 2.5 at the
most.
Looking at the map, I'd fly direct to Denver area. From there either follow
the I-70W over the pass, about 10,000 feet, then south to Moab, UT, and MV.
Or, fly direct to Pueblo, CO, then south to pick up highway 160W to the Four
Corners area, then direct to MV.
Long cross country flights are a lot of short legs combined, one leg at a
time. If you can fly a good 1.5 hour leg, you can fly anywhere you want to
go.
For those that thrive on long cross country flights in very small aircraft,
especially Kolbs, this type flying is addictive. I was lucky to find a
friend that had that same desire, same flying style, and a lot of free time
to accomplish the flights.
_________________ John Hauck
Titus, Alabama |
lucien
Posted: Tue Apr 07, 2009 8:42 am Post subject: Re: MV-09 Dreaming-Flight planning- maybe just dreaming |
| mccarthy(at)jefnet.com wrote: | I'm a long time reader of the list, and would love to fly out to MV to meet
can.
Tom McCarthy
Firestar N441TM
Zenith 601HD N514TM |
Just FYI, I may not be able to make it. The new prop isn't working out as I've expected so I may be down experimenting rather than flying for fun....
There may still be some others from my area going tho....
LS
_________________ LS
Titan II SS |
kirkds(at)dishmail.net Guest
Posted: Tue Apr 07, 2009 10:38 am Post subject: MV-09 Dreaming-Flight planning- maybe just dreaming |
| Quote: | Midwest considering this trip? I believe there is courage, knowledge, and
I considered it but too far for me.
