flysrv10(at)gmail.com Guest
Posted: Mon Apr 06, 2009 1:22 pm Post subject: Battery Service report |
I wanted to report that I have a Sears Wheel Chair battery that I
purchased a few months prior to my RV10's first flight. I used this
battery on my RV6 for about 13 years and had good luck with it.
Yesterday, after three years of service, I finally replaced it with a
new one.
The original battery cost $59 and the replacement was $89.
This battery will crack nicely with the Sky-Tec NL model starter.
pascal(at)rv10builder.net Guest
Posted: Tue Apr 07, 2009 6:19 am Post subject: Battery Service report |
Have the Sears model number for the battery?
Thx
Sent: Monday, April 06, 2009 1:21 PM
Subject: Battery Service report
new one.
dlm46007(at)cox.net Guest
Posted: Tue Apr 07, 2009 3:04 pm Post subject: Battery Service report |
I am away from home and don't have access to the aprt no. but they
only carry one model in the stores. It starts with 27. It looks like
a garden tractor battery and fits the Rv10's battery tray perfect.
This used to be a gel-cel (dry cel) battery and it might still be. It
is not a wet lead acid battery.
Mine is not the same as the link David has sent. If you can wait
until Thursday, I will be home and will send you the model No. Just
let me know off line.
On Tue, Apr 7, 2009 at 11:18 AM, pascal <pascal(at)rv10builder.net> wrote:
Thx
> Yesterday, after three years of service, I finally replaced it with a new
> one.
> do not archive
Rob Kermanj
AirMike
Posted: Tue Apr 07, 2009 9:32 pm Post subject: Battery Service report |
Is it gas recombinant or standard lead-acid with caps?
After having acid spill in a Piper Archer a few years ago, I would not use anything except a sealed unit. With the elevator push-rod under the battery in the RV10 I would never use a std lead-acid-capped unit.
_________________ See you OSH '18
Q/B - sold. |
bkbrown(at)minetfiber.com Guest
Posted: Wed Apr 08, 2009 5:19 am Post subject: Battery Service report |
I agree with that observation 100%. I also have had acid spills in previous
airplanes. Not something I want to repeat.
Posted: Wed Apr 08, 2009 2:00 pm Post subject: Battery Service report |
Ther is no acid to spill. This is a wheel chair battery used for indoors.
On Wed, Apr 8, 2009 at 1:32 AM, AirMike <Mikeabel(at)pacbell.net> wrote:
OSH '08 or Bust (busted) be there in "09
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p 38271#238271
Rob Kermanj
