undoctor
Joined: 21 Oct 2008 Posts: 212 Location: Bethelhem, PA
Posted: Tue Apr 07, 2009 2:47 pm Post subject: Back to gascolators |
Folks,
I bought a nice used gascolator a few months back and it has what
appears to be a vacuum fitting on the top. Before I install it I need
to know the options/requirements re: the vacuum line? I.e., can it be
plugged or is it's use necessary for the gascolator to function properly?
Dave Kulp
Bethlehem, PA
Firefly 098
Dana
Posted: Tue Apr 07, 2009 3:02 pm Post subject: Back to gascolators |
At 06:45 PM 4/7/2009, Dave Kulp wrote:
| Quote: | I bought a nice used gascolator a few months back and it has what appears
to be a vacuum fitting on the top. Before I install it I need to know the
options/requirements re: the vacuum line? I.e., can it be plugged or is
Vacuum doesn't seem likely... are you sure it's not a primer connection?
-Dana
Okay, who put a "stop payment" on my reality check?
undoctor
Posted: Wed Apr 08, 2009 2:59 pm Post subject: Back to gascolators |
| Quote: | [b] >to be a vacuum fitting on the top. Before I install it I need to know the
-Dana
I guarantee you I'm not sure of anything. Following is a web address and the second entry down has
a picture of the same setup. Maybe that would give you a hint. I asked the mechanic at Queen City,
where I've been flying out of and he didn't know. He's worked on military jets for years and
now is the first he's worked GA, so the setup may be peculiar to home builts...
[/b] | http://www.vansairforce.com/community/showthread.php?t=5513
Dave
Posted: Wed Apr 08, 2009 4:36 pm Post subject: Back to gascolators |
Dave C
That port you refer to a 1/8" NPT hole C isn't it? If it is C it is the primer port. If you do not need a primer C you don't need the port. Plug it.
Gascolaters have such a wide range of engines they're expected to work with. It's easier to machine the hole C and thread it C than try to create two types of gascolators C those with the hole C and those without.
If you go to www.aircraftspruce.com C and read the descriptions of the gascolators they offer C you'll see the primer port mentioned.
Mike Welch
MkIII
Date: Wed C 8 Apr 2009 18:58:28 -0400
Subject: Re: Back to gascolators
>options/requirements re: the vacuum line? I.e. C can it be plugged or is
-Dana
a picture of the same setup. Maybe that would give you a hint. I asked the mechanic at Queen City C
now is the first he's worked GA C so the setup may be peculiar to home builts...
Dave
Windows Live™: Keep your life in sync. Check it out. [quote][b]
JetPilot
Posted: Wed Apr 08, 2009 5:56 pm Post subject: Re: Back to gascolators |
Mine also has the thrid port on top, its the primer port.. Plug it !!!
Mike
Kolb MK-III Xtra, 912-S |
Posted: Wed Apr 08, 2009 6:34 pm Post subject: Back to gascolators |
Date: Wed, 08 Apr 2009 18:58:28 -0400
Dave,
It is a primer tap. See:
http://www.andair.co.uk/pdfs/GAS01.pdf
Jack B. Hart FF004
Winchester, IN
undoctor
Posted: Fri Apr 10, 2009 7:47 am Post subject: Back to gascolators |
Dave,
Jack B. Hart FF004
Winchester, IN
Thanks Dana, Mike, Mike and Jack. KNOWING makes all the difference! Now I can proceed. I had my
Cuyuna shut off inexplicably on my US. Never could find out why, although I think a rebuilt fuel
pump had something to do with it. But the experience kind of makes you sensitive to "unknowns"...
and to the "sound of silence."
Dave Kulp
Bethlehem, PA
FireFly 11DMK
[/b][b]
