		herbgh(at)nctc.com Guest
				 Posted: Wed Apr 08, 2009 6:59 pm    Post subject: Mixture control... |
				Jack
    See your post and am reminded...how is the mixture control
 coming...?   IMHO...not only does it promise a bit better fuel burn
 through better mixture control...but also may allow us to dial out
 the egt peak as we drop below 5k rpms?  Perhaps make the engine less
 susceptible to seizures...?  Herb
				 Posted: Thu Apr 09, 2009 5:42 am    Post subject: Mixture control... |
				At 09:57 PM 4/8/09 -0500, you wrote:
 Jack
 Herb,
 For flying this winter and spring, so far, have been mean weather wise.
 Most of the time my cold weather gear was used to blow snow.  Spent most of
 the winter in my basement shop working on stuff to try this spring.  Most of
 it is weight reduction stuff.
 I flew for the first time in March with the new filter cover (ram scoop)
 positioned at about sixty degrees up from horizontal.  But I took no
 pressure measurements.  I was not able influence EGT with the cover in this
 position.  This got me to thinking about what to do to increase the positive
 pressure over the float bowl. I realized that it would be better to
 reference this pressure off something in the carburetor.  I removed the
 carburetor and put a static pressure tap plus a positive dynamic pressure
 tap into the carburetor inlet.  If the static tap does not do the job, I
 will move to the positive dynamic tap.  Since this will produce much more
 pressure than needed, I will run the line to simple liquid bubble pressure
 regulator to obtain constant but ground adjustable pressure.  By adding the
 filter air scoop to recover filter pressure loss, I have complicated things,
 and so I will have to run quite a few flight tests to record air filter
 pressure drops at various engine speeds and scoop positions.  Then I will be
 able to get back to working with the mixture control.
 I remain very excited about the mixture control.  The ability to adjust EGT
 in flight lets one dial in the same burn rate for a given engine rpm.  One
 does not have sweat "should I have added fuel" thoughts.  I have wondered
 how it would work on a Rotax 447, but for me it is too late for that.  I am
 running this engine at much higher EGT than I did the Rotax.
 The Victor had the same problem as you described for below 5,000 rpm.  At
 first I thought it was a leaky exhaust coupler.  I modified the system and
 changed clamps.  Still the same problem.  Out of frustration, I started
 looking at the Bing.  I noticed how the slide was polishing and concluded
 the throttle return spring was too weak, and the slide needle assembly was
 bouncing.  Went to a heavier spring and things looked better.  Then I
 decided to modify the carb needle.  It was an eye opener.  I was able get a
 flat EGT across the whole cruise rpm range.  This proves to me that no
 engine manufacturer can tell you what needle jet combination is correct for
 every given application and it is unfair expectation.  What they recommend
 may work on the test bench, but one must consider this is just a starting
 point.
 Rambling.  The snow blower is off and the mower is ready to go.
 Jack B. Hart FF004
 Winchester, IN
				 Posted: Thu Apr 09, 2009 6:17 am    Post subject: Mixture control... |
				Good info Jack...much appreciated...
        you may be the only engineer in the world working to improve 2
 strokes...
       I haven't experimented but I suspect that the egt peak in the
 high 4k range occurs when the needle/needle jet drops in influence
 and we begin to go fully onto the main ... a transition point at
 abt   3/4 throttle..
       I think I have also noticed that some props tend to load/unload
 at certain rpm ranges and effect egts...Herb
  	  | Quote: | 	 		   >
 Herb,
 point.
 Jack B. Hart FF004
 Winchester, IN
				 Posted: Thu Apr 09, 2009 1:21 pm    Post subject: Mixture control... |
				At 09:15 AM 4/9/09 -0500, you wrote:
 strokes...
 abt   3/4 throttle..
 Herb,
 If I had not been forced into using a two stroke, I would be flying a four
 stroke.  In the past I was influenced by what has been written about two
 strokes.  I have found that there is a lot of misinformation out there.  A
 lot of it came directly from the EAA by picking an expert that was not a
 flyer but was a two cycle motorcycle man.  When the two cycle engine is
 placed on an airframe, one does not have to worry about quick throttle
 response time.  Most of the time the engine is run at constant speed with
 short bursts of max output for take off and climb out.
 As for 4k rpm EGT peaking, I do not believe it has anything to do with the
 main jet.  After mounting throttle slide position indicator,  I found that
 both the Rotax 447 and the Victor will develop max engine speed at around
 40% of the throttle opening. This is just where the main jet starts to pick
 up.  Checking my flight notes I had recorded 5,000 rpm at 25% and 4,500 rpm
 at 20% carb opening. In this range the Bing is under the influence of the
 pilot(idle) jet, slide cutaway and the needle position.  This gives a couple
 of things that can be done to adjust the carburetor.  One cannot adjust the
 cutaway but you can lean and richen the mixture about 50 degrees EGT with
 the idle mixture control. The other and I consider the best choice was to
 modify the needle between the 20% to 40% region.  This has worked out very
 well. All of this indicates the carb size is much too large, but one just use
 what is available and fit or refit the needle to your specific application.
 My disappointment is that I had to figure this out.  But it has made me much
 more excited about flying a two stroke engine.  It has moved me from a
 piston port to reed valve engine.  I have discovered I can run this engine
 at higher EGT than the Rotax 447.  The reason for this is advanced
 technology and design.  With ceramic cylinder coating lets you run a tighter
 fitting piston due to both being made of aluminum alloys with a common
 temperature expansion ratio.  Liquid cooling is a pain, but it helps get more
 heat away from the cylinder as apposed to a steel liner in aluminum
 interfacing directly with air.  Running a tuned exhaust helps with engine
 breathing and the reduction of unburnt fuel in the exhaust.  This type of
 engine design is supposed to be less prone to cold seizure.  Before I added
 the fuel mixture control, I had problems of the engine quitting on final
 after a long low throttle decent.  Idle jet adjustments did not seem to
 help.  After adding the mixture control, I can fly the FireFly down at
 cruise speed, close the throttle and land without the engine quitting.  This
 technique keeps the carburetor throat warmer and less prone to icing.
 Best of all, the Victor is running at half the fuel flow rate of my Rotax
 447.  Could I have gotten to this point with the Rotax 447?  I don't know.
 The next question is why doesn't Bing added this mechanism in or to the
 carburetor and make it a true aircraft carburetor?
 Not flying enough - Rambling #2
 Jack B. Hart FF004
 Winchester, IN
