		icrashrc
  Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
				 Posted: Sun Apr 05, 2009 11:39 pm    Post subject: 912 ULS starter |
				Has anyone measured the current draw of the Rotax 912 HD starter? I'm researching battery options and i wasn't smart enough to check mine before we started disassembly. Thanks,
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Scott
www.ill-EagleAviation.com
do not archive |
		JetPilot
				 Posted: Mon Apr 06, 2009 8:30 am    Post subject: Re: 912 ULS starter |
				I have an 18 Amp Hour battery in my Kolb that has been starting my 912-S for 3 years without a problem.  I live in Florida, so I cant tell you weather it would work in cold weather or not.
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		by0ung(at)brigham.net Guest
				 Posted: Mon Apr 06, 2009 10:09 am    Post subject: 912 ULS starter |
 I have a 18 amp hour that starts the 912 in 20 deg temps.
 Boyd
		icrashrc
				 Posted: Tue Apr 07, 2009 6:03 pm    Post subject: 912 ULS starter |
				> Thanks for the info on the size battery you're using. I was hoping
 someone had actually tested the amp draw of the starter while cranking. Not
 something one would normally check but I've never been called 'normal'!
 [Laughing]
 Scott:
 This is the battery I use in my mkIII and 912ULS:
 http://www.odysseybatteries.com/battery/pc545.htm
  _________________ John Hauck
Titus, Alabama |
		Thom Riddle
				 Posted: Wed Apr 08, 2009 4:25 am    Post subject: Re: 912 ULS starter |
				I believe the typical draw while cranking the 912ul is about 75 amps. I'm going to check mine today and will report back. 912ULS may be different.
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		Thom Riddle
				 Posted: Wed Apr 08, 2009 1:38 pm    Post subject: Re: 912 ULS starter |
				I don't know where I got the "typical draw while cranking the 912ul is about 75 amps." from but it was way off for our 912UL per testing this morning.
 Using clamp on ammeter I got ~13 amps current during cranking our 912UL at about 45-50F OAT.
 I hope this figure helps with at least a ballpark guestimate.
Buffalo, NY (9G0)
- Anonymous |
				 Posted: Wed Apr 08, 2009 8:10 pm    Post subject: 912 ULS starter |
 about 45-50F OAT.
 I have never seen a clamp on dc amp meter.
 Boyd
		icrashrc
				 Posted: Thu Apr 09, 2009 2:21 am    Post subject: Re: 912 ULS starter |
				DC clamp-on meters may not be a dime a dozen but they are easy to find. I have one as well. I just don't have the entire system to use it on at the moment...
 Thanks for checking your 912ul. You may want to check the calibration and/or settings on your meter. Somehow i think your estimate of 75 amps is closer to reality. I would hate to think i ran 6 ga cable to the starter when 18 ga would have worked just fine!
do not archive |
		Thom Riddle
				 Posted: Thu Apr 09, 2009 4:26 am    Post subject: Re: 912 ULS starter |
				Scott,
 The Rotax 912 Installation manual states that the regulator is rated for 75 Amps continuous and that is where my aging memory got the 75 A number. The #6GA wire is what the installation manual calls for too, I believe. The manual also states that the battery required is 18AH.
 My clamp on meter is nearly new. Compared to two other meters I've tested it against recently, it is accurate, so 13 Amps cranking current is what I'm getting. I suspect it would be a bit higher in colder weather and a little less in the summer.
Buffalo, NY (9G0)
- Anonymous |
		herbgh(at)nctc.com Guest
				 Posted: Thu Apr 09, 2009 5:06 am    Post subject: 912 ULS starter |
				Unless the meter had a peak and hold ability...it did no read the
 initial in rush current to the essentially stalled motor.. To get the
 motor turning takes a multiple of 15 amps for a fraction of a
 second..maybe longer... Marginal wire side coupled with necessary
 long runs and a marginal battery ...is always a problem... Herb
 At 05:21 AM 4/9/2009, you wrote:
 Scott
 http://forums.matronics.com/viewtopic.php?p 38454#238454
		Thom Riddle
				 Posted: Thu Apr 09, 2009 5:35 am    Post subject: Re: 912 ULS starter |
				The 912 installation manual also shows a 300A peak (1 second max) for the regulator.
 I was reading continuous cranking amps, not peak starting current.
Buffalo, NY (9G0)
- Anonymous |
		ElleryWeld(at)aol.com Guest
				 Posted: Thu Apr 09, 2009 3:52 pm    Post subject: 912 ULS starter |
				You can buy one from a Snap-on tool dealer you just  lay the meter on the wire  if the wire is the right size it will snap on to  it and you can also get one to test your charging system  from snap-on I  have both of these meters in my Tool box that I have been using for years and  they are a great rig to have
  Ellery in Maine
   In a message dated 4/9/2009 12:10:42 A.M. Eastern Daylight Time,  by0ung(at)brigham.net writes:
   	  | Quote: | 	 		  -->    Kolb-List message posted by: "b young"    <by0ung(at)brigham.net>
 about 45-50F    OAT.
 Boyd  ======================== the  ties  Day  ================================================               - MATRONICS WEB FORUMS  ================================================             - List Contribution Web Site  sp;                             ===================================================
  New Deals on Dell Netbooks - Now starting at $299
