				 Posted: Thu Apr 09, 2009 4:19 am    Post subject: Eliminating harmonics |
				Ted C
    I have a couple of suggestions to try out C if you haven't already tried these.
    First C get a few lengths of plastic tubing C and tape the ends securely near where you think harmonics are coming from C like the exhaust tip C near the prop hub C the motor mounts C etc.  Place the other end inside the cabin C so you can listen to each one during a test.
  Whatever it is that is generating the harmonic vibration C it will be loudest at the source.
    Once you have the tubes secured C do a run up to the worst harmonic level C and listen to each hose.  Usually (!) C the noise source is much louder in one hose.  Just a thought.....
    Next C to help identify the source C change something (very slight).  If you think the prop is likely the culprit C try taping the entire leading edge of each blade with duct tape.  It'll only be on for a few seconds C so I don't think it should hurt a thing!!
    With three exact lengths of duct tape C place them on the leading edge of the blades C splitting the middle of the tape down the sharp edge of the blade.  Do a worst case harmonic run-up C and see if things change (harmonics are better or worse).  It's a good chance that the duct tape will change the prop blades enough to alter their effect at creating a harmonic resonance.  The tape will change the blade's profile C balance (very slight!!) C and performance.
    A quick run-up should give you an idea about whether or not the blades are the cause.  Remove the tape.
  Mike Welch
  MkIII
 Internet Explorer 8 – Get your Hotmail Accelerated. '>Download free!  [quote][b]
