		815TL
				 Posted: Thu Apr 09, 2009 4:25 pm    Post subject: Warp Drive Prop pitch on 582. |
				Hi Guys,
 Dave Patrick was nice enough to come out to my area to give me some serious training over the next few days.  We flew over 3 hours today.
 Anyway he said that we are not turning high enough RPMs, and we are loosing a lot of power.  We should be climbing at close to 1000fpm, and we are doing maybe 400fpm.  The RPMs at take off are only about 5700, and should be closer to 6500.  He wants to adjust the prop pitch, but we are not sure of what the degree should be.  Can anyone tell us what you are running, or point us in the right direction to see what the degrees should be?
 Andrew,
 Kitfox II, 815TL, Rotax 582 C.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dave
				 Posted: Fri Apr 10, 2009 2:38 am    Post subject: Re: Warp Drive Prop pitch on 582. |
				Andrew,
 Check  tach  -- do you use a tiny tach ?  Many others have found to be un-reliable and inconsistent.   But you  climb rate does say something it not right.  I had a tach once that read 600 rpm low .....  and on a two stroke your max power it the last 400 to 1000 rpm of the rpm range.   eg --  5600 to 6200 is where the most power is.
 For prop. just make the pitch finer 1/4 degree at a time and run up till you  get 6200 static.  You do have a prop gauge?
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
