				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| fklein(at)orcasonline.com Guest
				|  Posted: Mon Apr 13, 2009 4:22 pm    Post subject: pitot tube connectors |   |
				| Guys...
 I have carelessly allowed the barb on the pitot tube connector used at
 the wing root to be snapped off...these are those cute little white
 nylon male/female connectors. I need a replacement. I note in the
 Acft. Spruce catalog an item which APPEARS to be the right part; a  P/
 N 05-01036 which is listed as a fuel line connector for 1/4" tubing.
 Inasmuch as the actual hole in the barb and tubing supplied w/ the kit
 is only about 1/16" diameter, I question whether this size would be
 appropriate for use as part of a fuel system.
 Before I order the replacement part, is there anyone who can verify
 that the P/N above is the correct size for the pitot system?
 Thankx,
 Fred
 A194
 believed to be clean.
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| paul.the.aviator(at)gmail Guest
				|  Posted: Mon Apr 13, 2009 5:51 pm    Post subject: pitot tube connectors |   |
				| Hi Fred,
 I can't confirm that it is the correct part or not, but if it turns out that it isn't then I think you can find what you need at McMaster Carr.  Take a look at:
 http://www.mcmaster.com/#catalog/115/184/=1fnqwu
 Which should be (if I haven't messed it up) page 183 of their catalog.
 Also, when you get to plumbing up pitot static system I see that Stenair have some really neat connector systems.  See http://www.steinair.com/pitot.htm
 Regards,  Paul
		| Back to top |  |
				|  Posted: Mon Apr 13, 2009 6:32 pm    Post subject: pitot tube connectors |   |
				| On Apr 13, 2009, at 6:49 PM, Paul McAllister wrote:
 Thanks Paul...right on the money!
 Fred
 --  This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean.   [quote][b]
		| Back to top |  |
		| budyerly(at)msn.com Guest
				|  Posted: Mon Apr 13, 2009 7:20 pm    Post subject: pitot tube connectors |   |
				| Fred C
The part is made by Colder Products Company (PC1701 and 1201 I believe) and I stock them in sets as I go through them like water and use them many more places.  Some additional uses are: the manifold line C alternate static sources C Dynon pitot tubes where I build them on to a panel for convenient access C altitude encoder for testing C etc.
 Everybody should have a spare set and a spare static end for the pitot.  Good insurance.
 They are about $5.00 a set.
 email me off line and I can get you some.
 Bud
 Custom Flight Creations (813) 653-4989
 Subject: Re: pitot tube connectors
 Date: Mon C 13 Apr 2009 19:31:13 -0700
 Fred
 dangerous content by MailScanner C and is
  	  | Quote: |  	  | http://www.matronics.com/Navigator?Europa-List ronics.com
 ww.matronics.com/contribution
		| Back to top |  |
		| rampil
				|  Posted: Wed Apr 15, 2009 6:50 am    Post subject: Re: pitot tube connectors |   |
				| If you would something really nice for the panel connection and the wing root, check out the Winter 9005 5x quick-disconnect at
 http://www.cumulus-soaring.com/winter.htm#Tubing,_Connectors,_and_Miscellaneous
 Ira N224XS
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
