LarryRosen
Posted: Wed Apr 15, 2009 7:49 am Post subject: Cabin Top to Tailcone Forward Top Skin |
I have finally attached the Tailcone Forward Top Skin (F-1074) and now I
need to fill in the gap between the cabin top the aluminum skin. This
is the method I was going to use to fill in the gap. I am also going to
use the same method to fill the side of the cabin top the the fuselage
skin. I am looking for comments.
First I will scuff the fiberglass and aluminum with 80 grit sandpaper.
Thoroughly clean the surfaces with acetone.
Apply a blend of west epoxy, cabosil and flox to fill in the low spots.
I will keep this fill about 1/8" low
Allow the epoxy mix to set up, but while still tacky then apply 2 strips
of fiberglass cloth cut on a 45.
Allow to cure over night.
Apply superfil to fair and fill any low spots
Sand and refill until smooth and fair.
Larry Rosen
#356
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Deems Davis
Posted: Wed Apr 15, 2009 8:07 am Post subject: Cabin Top to Tailcone Forward Top Skin |
Larry, That's exactly what I did, EXCEPT I did NOT apply the fiberglass
strips to these joints (I DID apply to all of the window joints). My
opinion is that I've yet to hear/see/witness any cracking along the pop
riveted seams, and the application of the fiberglass cloth is only to
help hide/minimize this potential. It also adds to the buildup and makes
fairing/blending a little more difficult. with the windows, your
basically blending /fairing only in one direction - away from the window.
Deems Davis # 406
'Its all done....
http://deemsrv10.com/
Larry Rosen wrote:
I need to fill in the gap between the cabin top the aluminum skin.
This is the method I was going to use to fill in the gap. I am also
going to use the same method to fill the side of the cabin top the the
fuselage skin. I am looking for comments.
spots. I will keep this fill about 1/8" low
strips of fiberglass cloth cut on a 45.
Larry Rosen
#356
pascal(at)rv10builder.net Guest
Posted: Wed Apr 15, 2009 8:26 am Post subject: Cabin Top to Tailcone Forward Top Skin |
Looks good, I did the same thing except skipped the cloth as I have my ideas
of cloth on aluminum causing cracks in the paint later.
I just filled with epoxy and flox/cabosil, sanded and final coat epoxy
cabosil, probably no different than the cloth in regards to cracking the
paint later but that's what I did.
Sent: Wednesday, April 15, 2009 7:45 AM
Subject: Cabin Top to Tailcone Forward Top Skin
need to fill in the gap between the cabin top the aluminum skin. This is
the method I was going to use to fill in the gap. I am also going to use
the same method to fill the side of the cabin top the the fuselage skin.
Apply a blend of west epoxy, cabosil and flox to fill in the low spots. I
Larry Rosen
#356
LarryRosen
Posted: Wed Apr 15, 2009 8:34 am Post subject: Cabin Top to Tailcone Forward Top Skin |
Deems,
Did you cover up both rivet lines (the pop rivets to the cabin top and
the solid rivets to the bulk head?
Larry
Deems Davis wrote:
fiberglass strips to these joints (I DID apply to all of the window
joints). My opinion is that I've yet to hear/see/witness any cracking
along the pop riveted seams, and the application of the fiberglass
cloth is only to help hide/minimize this potential. It also adds to
the buildup and makes fairing/blending a little more difficult. with
the windows, your basically blending /fairing only in one direction -
Deems Davis # 406
'Its all done....
> now I need to fill in the gap between the cabin top the aluminum
> skin. This is the method I was going to use to fill in the gap. I
> am also going to use the same method to fill the side of the cabin
> top the the fuselage skin. I am looking for comments.
> Larry Rosen
> #356
#40356
N205EN (reserved)
<http> |
Deems Davis
Posted: Wed Apr 15, 2009 3:12 pm Post subject: Cabin Top to Tailcone Forward Top Skin |
Yes
Deems
Larry Rosen wrote:
Deems,
Larry
> cracking along the pop riveted seams, and the application of the
> fiberglass cloth is only to help hide/minimize this potential. It
> also adds to the buildup and makes fairing/blending a little more
> difficult. with the windows, your basically blending /fairing only
> Deems Davis # 406
> 'Its all done....
>> Larry Rosen
>> #356
