BobCollins
Joined: 12 Aug 2008 Posts: 19 Location: Sunnyvale CA USA
Posted: Tue Apr 14, 2009 6:54 pm Post subject: NTSB recommends grounding of 601XLs in US |
This is an interesting discussion to watch. Bryan, you are probably
correct that the FAA would not be able to ground all the E-ABs out there
but the FAA (and Zenith) would be well advised to "encourage" them to
not fly if the FAA grounds the S-LSAs.
I read the NTSB recommendation and it seems to raise some valid concerns
about the design of the ailerons. If I were to put my life on the line,
I would want a well researched rebuttal to the NTSB letter before I
would fly it again. It is also not a case of the quality of the home
builder that is being discussed here, assuming (s)he followed the plans.
The NTSB is talking about a design issue which I really doubt any of the
builders made significant changes to.
The NTSB identifies two possible issues here. First, which Zenith agrees
with, is maintaining the proper tension in the control cables. This is
apparently critical to the design and Zenith should have identified it
as such from the beginning. As a design, requiring the owner to inspect
and measure the tension in the cables regularly seems like a poor choice
if there is a low or no maintenance option such as mass-balancing.
Second, the NTSB raises doubt whether the design is dynamically stable
even with the cables in proper tension. They don't cite much to support
this but I would want to see more investigation on this before my butt
is on the line.
I was also very surprised to read about the apparently non-standard (and
inconsistent) techniques used to measure airspeeds for the design.
I agree with George that this could turn into a circus which would not
be good for anyone. We need reasonable follow-through without either
hysteria or head-in-the-sand.
I have a question to the 601 cognoscenti, how are the XL ailerons
designed differently then the HD(S) ones? The NTSB letter was quite
specific to the 601XL.
Bob Collins
Sunnyvale CA USA
Bryan Martin wrote:
Quote: |
<bryanmmartin(at)comcast.net>
The FAA may be able to ground the S-LSAs, but there would be a real
problem grounding the E-ABs. There is no type certificate to take
action against. Each airplane is considered one of a kind. Many of the
E-ABs out there don't even have Zenith or Zodiac on the airworthiness
certificate. A person could build one and call it a Jones Gee-Whizz
Special on the certificate, then how could the FAA track it down? I
don't think there has been a single time in the history of the E-AB
category that the FAA has ever even considered grounding an
experimental design.
Another thing is that the FAA doesn't have to pay any attention to
recommendations from the NTSB, and they often don't.
F**k 'em, if I get the chance to fly mine to Sun'N'Fun this year, I
will. I'm not worried in the least about getting grounded by this BS.
I'm getting pretty tired of the government trying to protect me from
me. That's not the freaking job I'm paying them to do.
On Apr 14, 2009, at 6:37 PM, DaveG601XL wrote:
> <david.m.gallagher(at)ge.com>
> Well the timing of this puts one heck of a bind on anybody's plans to
> fly to Sun-N-Fun next week in a 601XL. Myself in particular. I have
> confidence in my airplane making the trip, but I cannot afford to get
> grounded in Florida. I too, hope that this motivates action for
> whatever the proposed modifications. I do not want to spend all
> summer being grounded!!
> David Gallagher
> 601 XL/Jabiru 3300
> First flight 7/24/08
> 70 hours and climbing!
psm(at)att.net Guest
Posted: Tue Apr 14, 2009 7:10 pm Post subject: NTSB recommends grounding of 601XLs in US |
Hi Bob,
I am not familiar with any design except the XL (with which I have
spent every day for the last 4 years). I believe the basic design of
the ailerons is similar on all models, but the wing shape and general
design is quite different on the XL.
The XL has a tapered wing. The other models (forgetting the 650
which is really an XL with a different name) have Hershey bar wings
(I think). Also the center section of the other models extends a
considerable way out the wing while the XL is straight from the
fuselage to the wing tip. I believe these major differences in the
wing shape will be more significant than the actual aileron shape or design.
The XL can be built with either hinge-less or piano hinged
ailerons. I suspect this doesn't make much difference with regard to
the NTSB paper on flutter.
Paul
XL on hold
At 07:52 PM 4/14/2009, you wrote:
Quote: | I have a question to the 601 cognoscenti, how are the XL ailerons
hills(at)sunflower.com Guest
Posted: Tue Apr 14, 2009 7:14 pm Post subject: NTSB recommends grounding of 601XLs in US |
Bob;
Well, I for one have push rods on my 601 HDS, so that's one difference (no
cables to go slack). Also, I have a big fat wing that probably resist
flapping and/or breaking to a greater degree than the 601XL wing, even if a
flutter does occur.
Roger
JAPhillipsGA(at)aol.com Guest
Posted: Tue Apr 14, 2009 7:29 pm Post subject: NTSB recommends grounding of 601XLs in US |
Anybody notice the date of the NTSB letter to the FAA?
In a message dated 4/14/2009 11:14:31 P.M. Eastern Daylight Time, hills(at)sunflower.com writes:
Quote: | --> Zenith-List message posted by: "Roger & Lina Hill" <hills(at)sunflower.com>
Bob;
flutter does occur.
Roger
-----Original Message-----
[mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bob Collins
Sent: Tuesday, April 14, 2009 9:52 PM
Subject: Re: Re: NTSB recommends grounding of 601XLs in US
--> Zenith-List message posted by: Bob Collins <bobcollins42(at)gmail.com>
is on the line.
Bob Collins
Sunnyvale CA USA
> --> Zenith-List message posted by: "DaveG601XL"
> David Gallagher
> 601 XL/Jabiru 3300
> 70 hours and ================================================ the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; � ===================================================
Access 350+ FREE radio stations anytime from anywhere on the web. Get the Radio Toolbar!
ggower_99(at)yahoo.com Guest
Posted: Tue Apr 14, 2009 8:14 pm Post subject: NTSB recommends grounding of 601XLs in US |
Could it be the date April 1st (April fool) Joke for you guys in USA?
Saludos
Gary Gower...
--- On Tue, 4/14/09, JAPhillipsGA(at)aol.com <JAPhillipsGA(at)aol.com> wrote:
[quote]From: JAPhillipsGA(at)aol.com <JAPhillipsGA(at)aol.com>
Date: Tuesday, April 14, 2009, 11:25 PM
[quote]--> Zenith-List message posted by: "Roger & Lina Hill" <hills(at)sunflower.com>
Bob;
flutter does occur.
Roger
grs-pms(at)comcast.net Guest
Posted: Tue Apr 14, 2009 8:32 pm Post subject: NTSB recommends grounding of 601XLs in US |
It was dated today, the 14th.
George
pchap(at)primus.ca Guest
Posted: Tue Apr 14, 2009 9:14 pm Post subject: NTSB recommends grounding of 601XLs in US |
While the NTSB presumably doesn't have to give anyone a heads-up on anything, it is disappointing that Zenith "wasn't ahead of the story" on this at all, even if it may not have been their fault.
It seems ironic to have received an emailed newsletter from Zenith that is "all sunshine", on the same day of the NTSB letters, April 14.
I haven't been keeping close track, but the last I heard from Zenith was that they'd participate in the European load tests, but weren't really expecting to spend the money to test to the US standards too. That was late in February. Also, in a Chris Heintz letter responding to the British LAA restrictions the same month, he basically wrote that everything was rosy with the NTSB. Correct me if I'm wrong.
Sorry to say but Zenith were either blind, blindsided, or keeping us in the blind.
Peter Chapman
Toronto, ON [quote][b]
Matt Ronics
Posted: Tue Apr 14, 2009 10:32 pm Post subject: Re: NTSB recommends grounding of 601XLs in US |
"While the NTSB presumably doesn't have to give anyone a heads-up on anything, it is disappointing that Zenith "wasn't ahead of the story" on this at all, even if it may not have been their fault.....
...Sorry to say but Zenith were either blind, blindsided, or keeping us in the blind."
"Let me assure everyone that Zenair is in close contact with the NTSB on this matter, and that if anything is discovered that could affect the safety of the Zodiac fleet, we will be notified immediately." (from Chris Heintz's letter April 24, 2008)
This whole issue stinks, no matter how you look at it.
I wish they would produce a match-hole drilled 601HD/S kit.
aerobat
Posted: Tue Apr 14, 2009 11:32 pm Post subject: Re: NTSB recommends grounding of 601XLs in US |
This is pretty much in line with what the LAA in the UK have said. One aircraft is currently being modified with aileron mass balances and a beefing up of the wing spar carry through so they can then evaluate it.
bryanmmartin
Posted: Wed Apr 15, 2009 3:38 am Post subject: NTSB recommends grounding of 601XLs in US |
The original plane for the XL, like the HD, had the "hingeless"
ailerons. The original prototype has this design, it has been flown
for hundreds of hours to airshows all over the country for over nine
years now with no trouble. Many builders changed the design to piano
hinge ailerons and the AMD S-LSA has piano hinge ailerons because
"real airplanes have hinges". As far as I know, all of the accident
aircraft had the piano hinge ailerons. It stands to reason that the
dynamic response of the two different aileron designs are going to be
different due to the elastic properties of the "hingeless" design that
is missing on the piano hinge design. I suspect that the elasticity of
the hingeless design makes the resonant frequency fall farther outside
of the flight envelope of the airplane. Mine has the hingeless
ailerons. I have 265 hours on mine and have flown it to the far edges
of the flight envelope and slightly beyond during phase one testing
with no hint of flutter. I'm convinced that my airplane is safe
enough for the type of flying I do.
Bob Collins
Sunnyvale CA USA
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Juan Vega Jr
Posted: Wed Apr 15, 2009 12:04 pm Post subject: NTSB recommends grounding of 601XLs in US |
in reading this faa letter, it seems that someone has been lobbying the safety board to ground the plane and that this report was done based on someones lobbying efforts copying the safety on the emails on this site. I would love to know who is the S%#(at)thead that was hell bent on pushing this.
Juan
ashontz
Posted: Wed Apr 15, 2009 12:26 pm Post subject: Re: NTSB recommends grounding of 601XLs in US |
There were copied e-mails from Matronics in the recommendation? Honestly, I'm kind of up in the air personally about seeing this getting a once over from the FAA. Be nice to know for sure, certainly sounds like aileron flutter. Certainly never wanted to see any publicity about it though. Any publicity there is though I'd say probably has more to do with foreign safety boards grounding the XL. Doubt there was anyone actively lobbying for it here.
Juan Vega Jr wrote: | in reading this faa letter, it seems that someone has been lobbying the safety board to ground the plane and that this report was done based on someones lobbying efforts copying the safety on the emails on this site. I would love to know who is the S%#(at)thead that was hell bent on pushing this.
Juan
Gig Giacona
Posted: Wed Apr 15, 2009 12:30 pm Post subject: Re: NTSB recommends grounding of 601XLs in US |
ashontz wrote: | Doubt there was anyone actively lobbying for it here.
Andy, please don't take this the wrong way. But you are being terribly naive. It is quite obvious who was lobbying for. It is in the report.
601XL Under Construction
ashontz
Posted: Wed Apr 15, 2009 12:41 pm Post subject: Re: NTSB recommends grounding of 601XLs in US |
Sorry, didn't register with me the first time I read the report. I went back and checked, I guess you're talking about the ZBAG engineer reference on page
First off, I was just a guess on the ZBAG list, had never paid, and had backed out simply because I didn't want to see any of this crap go down soon as I heard someone mention lawyer.
Anyway, what's it's any business of the hired engineer to report anything to the NTSB. Wasn't he supposed to be reporting to ZBAG?
Hopefully the FAA will tell him to go sh$t in his flat hat and pull it down over his ears. It's pretty obvious what's wrong with the plane, aileron flutter. Fix it however you want, personally I'm going with counter balance weights.
But, at the same time, I can see the FAA getting involved now because after all, everyone had to have their sport pilot rated airplanes, we'll here they are in all their certification glory.
Gig Giacona wrote: | ashontz wrote: | Doubt there was anyone actively lobbying for it here.
Andy, please don't take this the wrong way. But you are being terribly naive. It is quite obvious who was lobbying for. It is in the report. |
jeffrey_davidson(at)earth Guest
Posted: Wed Apr 15, 2009 1:06 pm Post subject: NTSB recommends grounding of 601XLs in US |
On the HD, the ailerons are full length and the belcrank is in the gap between the center wing seciton and the outboard wing sections. Same for the HDS. Both have three part wings center section and two outborad sections. The HD wing has a constant chord and is longer than the tapered HDS wings. On the XL/650, the ailerons are roughly half the length of the wing. The inner half length is used for the flaps. The HD and HDS do not have flaps. On the XL, the aileron bellcranks are further out in the wing which means that the control cables have a longer run.
Jeff Davidson
Bob Collins
Sunnyvale CA USA
ashontz
Posted: Wed Apr 15, 2009 1:21 pm Post subject: Re: NTSB recommends grounding of 601XLs in US |
Who has the plane that experienced flutter over the power plant? Did that badboy have hinged or hingless ailerons?
Also, in this Zenair newsletter, did this plance have hinged or hingeless.
http://www.zenair.org/nuke/modules.php?name=News&file=article&sid=17
jeffrey_davidson(at)earth wrote: |
Bob Collins
Sunnyvale CA USA
hansriet
Posted: Wed Apr 15, 2009 1:23 pm Post subject: Re: NTSB recommends grounding of 601XLs in US |
[quote="bryanmmartin"]Many builders changed the design to piano
hinge ailerons
[/quote]
Well that's not entirely correct. The builders didn't change the plans, they merely opted for this factory option.
ashontz
Posted: Wed Apr 15, 2009 1:25 pm Post subject: Re: NTSB recommends grounding of 601XLs in US |
True, I remember watching the video years ago and they spent all kinds of time talking about the hingeless aileron, then said that hinged is optional. Personally, I thought, "Hhhhhmmmm, hinged sounds better."
hansriet wrote: | bryanmmartin wrote: | Many builders changed the design to piano
hinge ailerons
Well that's not entirely correct. The builders didn't change the plans, they merely opted for this factory option. |
sperry50(at)comcast.net Guest
Posted: Wed Apr 15, 2009 1:41 pm Post subject: NTSB recommends grounding of 601XLs in US |
I got no choice when I purchased the quick-build kit. It came with piano
hinges!
DO NOT ARCHIVE
bryanmmartin
Posted: Wed Apr 15, 2009 2:05 pm Post subject: NTSB recommends grounding of 601XLs in US |
Some builders were putting in piano hinges before they were offered as
a factory option. They were eventually offered as an option due to
popular demand.
On Apr 15, 2009, at 5:23 PM, hansriet wrote:
hinge ailerons
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
