John Bickham
Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
Posted: Thu Apr 16, 2009 7:29 pm Post subject: Dumb short short landing technique question |
I have a what may seem like a dumb question regarding really short landings. I've been pushing myself to try to land as short as I can. I find it a challenge to control the speed at minimum and achieve a decent landing with minimum ground roll. I consider myself barely an average aviator and have the history to prove it.
I'm down to landing in less than 600 ft over a +80 foot obstacle on grass. One of the problems is the steep approach at minimum speed and timing the flare. Gusting winds don't help. I think what is happening is the wing and flaps are blocking the air at the abrupt flare and robbing some elevator authority making things kinda ugly at times. My next move is to try a little shot of power to put some air on the elevator for authority.
I liken this to a bird landing on a wire and missing the wire. Interested in learning others techniques and suggestions. Don't want to insult anyone, but would like to avoid VG's being the answer. Technique should be the same to achieve best result with or without VG's. Sorry bout that.
Again, this is pushing my abilities. I may have reached my personal limits based on my limited ability.
_________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. |
rlaird
Posted: Thu Apr 16, 2009 7:53 pm Post subject: Dumb short short landing technique question |
What's your configuration for landing? I.e., what flaps, if any, are you using?
-- Robert
MkIIIC/912ULS
On Thu, Apr 16, 2009 at 10:29 PM, John Bickham <gearbender(at)bellsouth.net (gearbender(at)bellsouth.net)> wrote:
[quote]--> Kolb-List message posted by: "John Bickham" <gearbender(at)bellsouth.net (gearbender(at)bellsouth.net)>
Thanks too much,
John Bickham
Mark III-C w/ 912UL
Landing a plane and being married - a few smooth moments mixed with a lot of rough ones.
http://forums.matronics.com/viewtopic.php?p=239655#239655
le, List Admin.
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
lucien
Posted: Thu Apr 16, 2009 8:00 pm Post subject: Re: Dumb short short landing technique question |
| John Bickham wrote: | I have a what may seem like a dumb question regarding really short landings. I've been pushing myself to try to land as short as I can. I find it a challenge to control the speed at minimum and achieve a decent landing with minimum ground roll. I consider myself barely an average aviator and have the history to prove it.
Again, this is pushing my abilities. I may have reached my personal limits based on my limited ability. |
What I do is keep at the ready with the throttle when slow with a high sink rate - throttle becomes the 4th control surface when slow. When you're near stall like this, the altitude for airspeed trade involves more cost in altitude than otherwise if you get into some sudden sink. So you have to be able to add energy back into the equation in those cases to arrest the sink rate but without having to make large reductions in AoA.
So, I'd configure for the short field in the normal way, but adjust the sink rate with the power a little more than you otherwise would to keep from having to speed up. Maintain the low airspeed with the elevator like usual.
Pusher planes have an advantage here in that we can instantly restore elevator/rudder authority by applying power and getting the wind going back over those control surfaces. But it still works in any airplane (even in trikes).
Carrying a little power into the flare will slow down the energy bleed-off too and thus slow the flare down. This really helped a whole bunch in my FSII, which normally had a pretty quick flare anyway like with any low-intertia plane design. I could still come in slow, but adding a little power right at roundout slowed the flare down enough to make the timing a lot less critical.
It may add a little length to your landing, but you could still get down in something you'd only be able to trailer out of anyway
LS
_________________ LS
Titan II SS |
rowedenny
Posted: Fri Apr 17, 2009 2:49 am Post subject: Dumb short short landing technique question |
Clearing an 80 foot obstacle and stoping in less than 600 foot sounds pretty
damn good to me!
I have a 600 foot strip with one open end, and I never consider coming in
from the end with the trees.
Denny Rowe, Mk-3, N616DR
Ralph B
Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
Posted: Fri Apr 17, 2009 3:38 am Post subject: Re: Dumb short short landing technique question |
rowedenny | Quote: | Clearing an 80 foot obstacle and stoping in less than 600 foot sounds pretty damn good to me! I have a 600 foot strip with one open end, and I never consider coming in from the end with the trees.
I agree. Anyone that can land inside 600 feet over an 80' obstacle is doing pretty good. You are doing very well John! I have found the shortest landings are power off landings coming in at best glide speed. Anything less than that can ruin a set of landing gear if the flare timing is off.
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
JetPilot
Posted: Fri Apr 17, 2009 6:12 am Post subject: Re: Dumb short short landing technique question |
John, Your technique sounds good, if you are coming in 80 feet over the trees and stopping in 600 feet, you are doing very well. You are correct to worry about gusty winds when doing this, a gust that puts you below stall or even right near stall in the flare could result in an accident or very hard landing with damage to your plane. In commercial aviation we approach at higher speeds when the wind is gusty.
You knew the obvious answer to this question, so I have to ask you why do you want to avoid using VG's ? You must think there is some downside to them if you want to avoid something that could improve your short field and landing performance so much. Given the short fields you fly out of, VG's would be a huge help, not just on the wings, but also on the horizontal tail will keep your elevator working during the minimum speed flare you are talking about. Everything you are talking about, your plane will do much better with VG's. If you think you might not like them, put them on with double sided auto trim tape and try them, that way if you don't like the results some mineral spirits and time will get them right off. For just over 100 bucks, and a half a days work, you can do something that has the potential to increase your planes performance by a huge margin, and if you don't like it, you can easily get them off. Bargains like that don't come along often.
Short field operations without VG's is kind of like a NASCAR driver wanting to race with cheap economy tires, all the driving technique in the world will not be able to make up for the lack of proper equipment.
Mike
Kolb MK-III Xtra, 912-S |
John Bickham
Posted: Sat Apr 18, 2009 12:12 am Post subject: Re: Dumb short short landing technique question |
Thanks for the replies.
Mike - Maybe one day I'll try the VG's. I'm sure they would improve the low speed performance. I'm satisfied enough right now with Homer's design.
Sounds like I'm doing better than I thought. Might be pushing the limit already. There is little doubt in my mind that I would have bent the original aluminum gear legs already with some of these landings. The chrome-moly, heat treated, big tire gear I have now absorbs a lot of the energy. Makes things a little springy at times. Hard not to bounce a little on hard surfaces, kinda like a citabria.
Next round, will ease in some power just before the flare. Off-weekend and its raining again. Arty took the CAVU weather with her!
John Bickham
Mark III-C w/ 912UL
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Sat Apr 18, 2009 3:52 pm Post subject: Re: Dumb short short landing technique question |
John,
Denny Rowe took the words right out my mouth ! 600 feet over 80' obstacle.....That is pretty dang good pal ! .....are you just trying to show us up???? lol
chris ambrose
m3x-jab
lucien
Posted: Sat Apr 18, 2009 5:27 pm Post subject: Re: Dumb short short landing technique question |
| ces308 wrote: | John,
chris ambrose
m3x-jab |
Oh yeah, I left that out of my response too - that's pretty phenomenal performance already and your technique sounds just fine as-is if you're shoehorning into 600'.
Only in my quicksilver would that have been relatively easy to do. I doubt I could do that in my titan for sure. My FSII maybe.....
LS
Titan II SS |
Posted: Tue Apr 21, 2009 11:17 am Post subject: Dumb short short landing technique question |
John,
You may want to consider changing your technique.
One can practice steep descents and then apply it to landing. My problem
was selecting an alternative landing site and then not being able to get the
FireFly down in time and thereby over flying the site. It took a little
practice but finally I managed it.
I took the FireFly up to about 3,000 feet agl, and applied flaperons,
reduced power, and pushed the nose over to see how quickly I was falling out
of the sky. I never let the ias get below 50 mph. Then I did the same
thing again with a forward slip. It is truly amazing how quickly you can
get down and one can vary the rate by pushing the stick forward and
increasing the air speed.
Once I got used to this, I went back to the airport and practiced flaring at
given spot on the runway. The advantage of this method is that you are
never anywhere close to stall speed. It lets you change slope with stick
for and backwards motion and to clear an obstacles with out fear of stalling.
Just before flaring, you back off the rudder and all power and you are down.
FWIW
Jack B. Hart FF004
Winchester, IN
Posted: Wed Apr 22, 2009 3:24 am Post subject: Dumb short short landing technique question |
The advantage of this method is that you are never anywhere close to stall
speed. >>
Hi
How do you know?. If you are slipping your ASI is probably useless as the
airflow will be across the pitot. The airflow will be sideways along the
wing as well and therefore not giving as much lift as you perhaps expect.
With so little side area is it worth sideslipping anyway? In my Challenger
she would slip like a banshee and fall out of the sky, but I always kept the
speed up but with the Kolb it doesn`t seem to make mush difference.
Maybe I should do some serious measurements >The vario should work correctly
Pat
zeprep251(at)aol.com Guest
Posted: Wed Apr 22, 2009 4:24 am Post subject: Dumb short short landing technique question |
Pat,
Am I assuming correctly,that a vario is a rate of climb or descent instrument?
Thanks G Aman
lucien
Posted: Wed Apr 22, 2009 5:22 am Post subject: Re: Dumb short short landing technique question |
| pj.ladd(at)btinternet.com wrote: | The advantage of this method is that you are never anywhere close to stall
speed. >>
Hi
Pat |
Well remember, stall is determined by angle of attack, not airspeed. This is why we can still fly an airplane in a slip or without an working ASI - you still have to practice AoA maintenance to avoid a stall in a slip also just like at other times.
So I'd say Jack is right. The forward slip is a good way to add drag for steepening a descent without building up too much airspeed (a poor man's flaps).
But I will agree that slips in the Kolb don't add a whole bunch more drag like they do in some other planes. I slipped my FS II a bunch but didn't find it to really steepen the descent that much. But it did work so I used it in the rare event I was actually too high on final.
If you really want drag, install a C box and the rk-400 clutch. Talk about flaps..... the windmilling prop when you back down to idle is like deploying the BRS, you come down and steep too......
LS
Titan II SS |
cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Wed Apr 22, 2009 5:34 am Post subject: Re: Dumb short short landing technique question |
| jbhart(at)onlyinternet.ne wrote: | The idea is to dirty up the plane. That is why you add flaperon and forward
slip. Adding flaperon increases both the lift and drag coefficients and
reduces stall speed. The forward slip increases drag and decreases lift.
The trick is to find the flaperon setting that gives you the highest rate of
controllable descent.
There is no way to stall the FireFly at 50 mphi unless you intentionally
stall it by jerking the stick back. In a forward slip, the airspeed
indicator will read slow so if it indicates 50 mph you are actually going
faster and so it increases the margin of safety. The important thing is to
keep the power off so that one can steepen the descent.
Jack B. Hart FF004
Winchester, IN |
Jack,
I was mostly trained in a Cessna 150 but my instructor would slap my hand if I did a slip with the flaps down. Do one or the other, but not both.
I don't have flaps in my Kolb Mark II, so that's not an option for me anyways.
If we're having an emergency, well we're probably in danger anyways so it may be worth the potential danger that the combination brings, but if it's just because our approach is off, then go around and do the right approach. May be well worth the extra gas and time it takes!
If one insists on trying it or being familiar with it in case of an emergency, then get with an instructor first and make sure you are performing it as safely as possible.
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
Posted: Wed Apr 22, 2009 11:07 am Post subject: Dumb short short landing technique question |
Let me add one thing to this thread.
The most effective change I made to effect shorter landings was to decrease engine idle speed to less than 1800 rpm( that was with a 3 blade IVO ),on the 503 with a b box,2.58/1.
G Aman Former FS 2 driver
ces308
Posted: Wed Apr 22, 2009 12:55 pm Post subject: Re: Dumb short short landing technique question |
Remember...an airplane will fly slower under power than without power....
chris ambrose
m3x-jab
Posted: Wed Apr 22, 2009 1:47 pm Post subject: Dumb short short landing technique question |
| Quote: | chris ambrose
m3x-jab
Chris C
While that point may be true in flight C it ceases to work once you've touched down.
I faster spinning prop will not help to slow down quicker than a slow spinning prop. (unless C of course C you have beta mode)
Mike Welch
MkIII
Rediscover Hotmail®: Now available on your iPhone or BlackBerry Check it out.
ces308
Posted: Wed Apr 22, 2009 4:18 pm Post subject: Re: Dumb short short landing technique question |
....I'm sorry...I thought we were slowing the plane down in the air to land...yes ..when you are on the ground,pull the throtle back..
chris ambrose
Posted: Thu Apr 23, 2009 3:34 am Post subject: Dumb short short landing technique question |
| Quote: | keep the power off so that one can steepen the descent. >>
If you haven`t got the throttle closed what is the point of slipping? The
easiest way to lose height is close the throttle.Slipping, Falling leaves
etc come next.
Who ever made the comment about long controlled approaches was dead right.
If you lose the engine in that position you have no options. Fly to the
point ,and height, where you have the field made with no power and then
close the throttle to idle. If you are too close then slip.
Pat
Posted: Thu Apr 23, 2009 3:40 am Post subject: Dumb short short landing technique question |
also just like at other times.>>
Hi Lucien,
quite right of course but part of my comment was that you are not generating
the lift which you might expect because the air is not flowing straight from
the leading to trailing edge but is taking a diagonal path across the wing.
Of course it can be done but it just needs watching, and practicing.
Pat
