		GrummanDude
				 Posted: Thu Apr 16, 2009 9:16 pm    Post subject: strange compression test. |
				I installed a new Lycoming O360 (roller cam) into a Tiger a few months
 ago.  The break-in was normal with one exception.
 The #2 cylinder compression was strange.
 Compression was checked at 10 hrs and 25 hours since new.
 Both times, the compression on #2 fell off dramatically at 20 to 15
 BTDC.  Compression came back up slightly to 60/80 at TDC.  On the other
 side, ATDC, compression fell off slightly and then went back up before
 going back down.
 At 25 hours, the cylinder was pulled, sent to Lycon for inspection.
 Valves/seats were recut, rings were honed, cylinder was rehoned.  The
 plane was flown again for 10 hrs and the compression tested.  The
 compression fall-off wasn't as bad, but, it was still there.  Plane was
 flown for another 15 hours.  At 50 hours, I removed the cylinder and
 replaced it with another new cylinder.
 The owner has about 5 hours on it and I'll be checking it again.
 Note:  when the cylinder was pulled, the piston was removed to the
 point where I could remove the wrist pin.  The top of the piston was
 scuffed in a "V" shape from about 1 inch below the rings to the ring
 grooves.  At the grooves, the scuffing was about 1 inch wide.  I did
 not remove the piston and look inside.  I sent the cylinder to Lycon
 today.
 Has anyone ever heard of this before?
  |  | - The Matronics TeamGrumman-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?TeamGrumman-List |
  _________________ Gary
AuCountry Aviation
Home of Team Grumman |
		flyv35b(at)minetfiber.com Guest
				 Posted: Fri Apr 17, 2009 6:02 am    Post subject: strange compression test. |
				 	  | Quote: | 	 		   Both times, the compression on #2 fell off dramatically at 20 to 15 BTDC.
  Compression came back up slightly to 60/80 at TDC.  On the other side,
  ATDC, compression fell off slightly and then went back up before going
  back down.
 Compression is normally checked at TDC.  Are you saying you held the prop
 stationary at 20 and 15 BTDC or where you moving the piston upwards at the
 time you noticed the drop in compression?  Checking the compression while
 the piston is moving upwards doesn't really tell you much.  You can
 "generate" higher numbers and even see 80/80 or higher depending on how fast
 you are moving the piston.  Also, many times compression will fall off right
 after TDC and then come back up shortly later, especially if there is bore
 wear from the top ring at the top of the stroke and wear in the piston ring
 land.
  	  | Quote: | 	 		   At 25 hours, the cylinder was pulled, sent to Lycon for inspection.
 How do you hone the rings?
  	  | Quote: | 	 		   The owner has about 5 hours on it and I'll be checking it again.
  Note:  when the cylinder was pulled, the piston was removed to the point
  where I could remove the wrist pin.  The top of the piston was scuffed in
  a "V" shape from about 1 inch below the rings to the ring grooves.  At the
  grooves, the scuffing was about 1 inch wide.  I did not remove the piston
  and look inside.  I sent the cylinder to Lycon today.
 Not quite sure what the scuffed area looks like.  I assume you are talking
 about scuffing on the piston skirt at the 12 o'clock position as it is
 installed?  Does the scuffing go all the way to the bottom of the skirt and
 the point of the "V" start there and get wider as it approaches the oil ring
 land?  Was the piston scuffed on the bottom side at the 6 o'clock position?
 Why not just pull the cylinder off the piston when removing it and then
 remove the pin and piston?  That way you can inspect all of the cylinder
 bore and the head area.
 Normally, if scuffing occurs it will be on the skirt at the 12 and 6 o'clock
 positions.  This can be pretty severe on a new engine that has tight
 clearances when takeoff power is applied without the engine being warmed up
 adequately.  The aluminum piston expands faster than the steel cylinder and
 starts to scuff.
 Since it sounds like you didn't change the piston with the new cylinder, I'd
 want to check the cylinder bore diameter vertically and horizontally with a
 dial bore gauge and compare that to the piston skirt diameter in both
 directions.  There might be a clearance issue.  The scuffed area as you
 described it sounds abnormal and might be due to incorrectly made parts.
 Maybe the cylinder is not round near the top and the rings can't conform to
 the bore, resulting in a loss of compression.  Lycon should be able to take
 some measurements and tell you if there is a problem.
 Lastly, what about a dynamic cranking compression test.  Did you do that on
 this engine?  I guess that wouldn't show up the problem if it only occurs at
 20-15 BTDC and not at the very top of the stroke.
 Cliff
		GrummanDude
				 Posted: Fri Apr 17, 2009 10:20 am    Post subject: strange compression test. |
 prop
 the
 while
 fast
 right
 bore
 ring
 land.
 Reply:
 All of the compression measurements were made with the piston static at
 the various cranking positions from 30 BTDC to 30 ATDC in 5 degree
 increments.  I started checking compressions at 30, 20, 10, 0, 10, 20,
 30 cranking degrees many years ago to build a data base of compression
 behavior based on engine time.  Compression at TDC was only 60/80 (or
 thereabouts.  Sometimes as low as 45, sometimes as high as 65).  When I
 checked compressions BTDC I noticed a dramatic change in compression
 that was not expected.  Then I did a compression survey and noticed
 that somewhere in the 20 BTDC range, there was a compression peak
 (75/80) and then a dramatic fall-off to TDC. I had the owner go to
 another shop and have them repeat the test to see if they
  found
 something weird.  Their results were the same as mine.
 Reply:  The rings were lapped into the cylinder.
 talking
 and
 ring
 position?
 cylinder
 Reply:  I didn't remove the piston from the cylinder.  I rarely do
 that.  Lycon does all my engine work.  The scuffed area looks like a
 "V" about 1 inch high and 1 inch wide at the oil ring.
 Note:  This scuffing was not evident when I sent the cylinder assembly
 to Lycon for tear-down and inspection at 25 hours.  Lycon didn't find
 anything specific about the cylinder that would cause a problem.  The
 compressions were better after Lycon worked on the cylinder, but not
 perfect.
 I've removed a lot of cylinders and if there is scuffing (and there
 usually is) it looks like uniform scratches from the rings to the end
 of the piston
 skirt.  This scuffing is confined to a small area just
 below the oil rings.
 o'clock
 warmed up
 and
 starts to scuff.
 Reply:  I always wait until the oil temp is above 100 degrees before
 adding power.  New, used, or abused.
 cylinder, I'd
 with a
 parts.
 conform to
 take
 Reply:
 It may sound like that, but, as far as I'm concerned, the pistons and
 cylinders are a unit.  I never mix or match.  A new cylinder 'assembly'
 was installed.  Ken (Lycon) is going to inspect the cylinder/piston
 assembly just-in-case this shows up again on an
 other cylinder.  The new
 assembly I received from Lycon had been torn down, inspected, and
 measured before they sent it to me to install.
 that on
 occurs at
 Reply:  Like I said in earlier posts, I am doing dynamic testing of
 cranking pressures to build a database of new vs old, roller vs flat
 tappet cams, low compression vs high compression, etc.  For example:
 Compressions on a Lycon overhauled O320 with high compression pistons
 are in the 140-145 range.  Compression on a roller cam are in the 125
 range.  Cranking pressure on the subject cylinder was only a point
 below the other cylinders.  Had the engine felt smooth in flight, and
 reached red line in straight and level flight like it did with the old
 engine and a bad cam, I wouldn't have thought anything about it.  The
 engine just didn't feel right.
 If Lycon finds something I'll post it.  If the new cylinder is better,
 I'll post that too.
AuCountry Aviation
		budzz89
				 Posted: Fri Apr 17, 2009 11:39 am    Post subject: Re: strange compression test. |
 prop
 the
 while
 fast
 right
 bore
 ring
 land.
 Reply:
  found
 talking
 and
 ring
 position?
 cylinder
 perfect.
 of the piston
 o'clock
 warmed up
 and
 starts to scuff.
 cylinder, I'd
 with a
 parts.
 conform to
 take
 Reply:
 that on
 occurs at
 I'll post that too. |
 yeah pretty good you have that kind of cylinder, thanks for the help
 aluminum plate
