frans(at)paardnatuurlijk. Guest
Posted: Fri Apr 17, 2009 9:32 am Post subject: Trike nose wheel castor spindle and yoke failure. Europa |
hi Karl,
| Quote: | Sorry to butt in again, but you say that ACS don't have a matching wall
thickness spindle.
They have exactly the same, I gave you the part number.
The part number you gave has a smaller wall thickness than what I
measured on the original. Maybe Europa changed the tubing size somewhat?
My solution is to order 03-04800 and 03-06600, which will give me a
combined wall thickness of .240
The largest wall thickness of 1" steel tube offered by ACS (your part
number) is .188, and that is smaller than what I measured. I measured an
I.D. of .5
Given the fact that some people experienced problems with a bending
nosewheel spindle, I'd rather stick to the original wall thickness.
Also, an inner I.D. of .5 allso provides a snug fit of the AN8-bolt to
be inserted.
Has anyone else measured the wall thickness and/or inner diameter of the
nosewheel spindle? Maybe there are two versions supplied? Which explains
why some people experience problems and some others not (bad landings
excluded of course! ) Another difference I experienced is that my
nosehweel spindle is not just held by the famous roll pin, but also
"glued" with something (probably locktite).
Of course I can't exclude the possibility that I didn't measure
correctly. In that case, I will just get a stronger nose wheel spindle
than original.
Frans Veldman
