		DAquaNut(at)aol.com Guest
				 Posted: Sun Apr 19, 2009 11:40 am    Post subject: CHT Probe-Atachment |
				List,
      Has anyone figured out a way to keep from ruining the  CHT attachment ring under the sparkplug? Mine broke and I would like to  keep from replacing it again if at all possible. Any trick to it?
              Ed  Diebel       FF 62
  A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
		lucien
				 Posted: Sun Apr 19, 2009 11:52 am    Post subject: Re: CHT Probe-Atachment |
				[quote="DAquaNut(at)aol.com"]List,
              Ed  Diebel       FF 62
 Form the CHT sender around a spark plug and the socket before installing the plug into the engine.
 Put the plug in the socket and then place the sender ring over it and bend the sender around that by hand.
 Then when you actually install the plug, it's already pre bent and shaped. You don't crunch up the sender as you force the socket over the works and crank the plug down.....
 I spent a whole bunch of money on senders before someone told me about that trick. Helped a bunch....
 LS
  _________________ LS
Titan II SS |
		Dana
				 Posted: Sun Apr 19, 2009 12:42 pm    Post subject: CHT Probe-Atachment |
				At 03:52 PM 4/19/2009, lucien wrote:
  	  | Quote: | 	 		  Form the CHT sender around a spark plug and the socket before installing
 Then when you actually install the plug, it's already pre bent and shaped...
 Also, secure the wire to the engine at some point so the engine's motion on
 the vibration mounts isn't flexing the wire where it attaches to the
 ring.  I slip the wire through a short length of fuel tubing, then tie wrap
 that to a point on the muffler mount bracket.  Wind some of the section
 beyond that around something round, I used some 1/2" rod, to form it into a
 coil (then remove the rod, of course), then attach it beyond the coil to
 the aircraft frame.  The coil allows for more flex as the engine moves.
 If it's a simple self powered CHT gauge and not a fancy EIS sender, and if
 it's just the wire that's broken right at the terminal (usually is, since
 one of the wires is iron which is quite brittle), it's easy to fix instead
 of replacing it.  Pry open the crimp on the terminal, remove the broken
 part, then strip some insulation from the remaining wire, and tightly twist
 them together before crimping it back into the terminal.  The sender is a
 simple thermocouple that generates a voltage by heating the connection
 between the two different wires.
 -Dana
   People are more violently opposed to fur than leather because it's safer
 to pick on rich women than biker gangs.
		HShack(at)aol.com Guest
				 Posted: Sun Apr 19, 2009 2:04 pm    Post subject: CHT Probe-Atachment |
				Get an 8mm ring & put it [them] under a head bolt;  reads some  lower but it will do the job.
  Howard  Shackleford
 FS II
 SC
   In a message dated 4/19/2009 3:41:08 P.M. Eastern Daylight Time,  DAquaNut(at)aol.com writes:
   	  | Quote: | 	 		     Has anyone figured out a way to keep from ruining the CHT attachment ring    under the sparkplug? Mine broke and I would like to keep from replacing    it again if at all possible. Any trick to it?
                Ed    Diebel       FF  62
  Access 350+ FREE radio stations anytime from anywhere on the web. Get the Radio Toolbar!
