One Thing At A Time
Goto page 1, 2  Next
PostPosted: Sun Apr 19, 2009 11:52 am    Post subject: One Thing At A Time Reply with quote
Something I temporarily forgot. When test making changes and test flying,
make one change at a time, then go fly to see what the results are. I
didn't do that yesterday.
My new Warp Drive Blades had a little edge of black paint left when the
masking tape was pulled off the nickle leading edges. I did my initial
pitch adjustments with this tiny ridge of paint. My rpm at WOT straight and
level indicated I was pitched a little bit light, 5,600 rpm.
I did three things to my airplane before I test flew it again:
1-Sanded and feathered the edge even with the trailing edge of the nickle
leading edge.
2-Cleaned and reoiled the K&N air filters.
3-Adjusted the covers on my conical K&N filters to stand off about an inch
rather than the original stock 1/2 inch.
Was rather surprised on takeoff, my climb rpm was only 5200 rather than
5400. Also surprised when my max rpm had dropped to 5,500 rpm WOT straight
and level flight.
Got an idea cleaning up the ridge of paint on the blades may have increased
their bite.
Don't know if the air filter cleaning/reoiling or the change in air filter
cover standoff pulled power off the engine. Hope that is not the case.
On the other hand, it is hard to believe that tiny ridge of paint would have
that much effect on its performance, but I think it did.
mkIII - Getting ready for Lakeland and Monument Valley.
PostPosted: Sun Apr 19, 2009 11:59 am    Post subject: One Thing At A Time Reply with quote
> Something I temporarily forgot. When making changes and test flying,
The above is how it should have read from my previous.
20,000 xin loi
lucien
PostPosted: Sun Apr 19, 2009 12:31 pm    Post subject: Re: One Thing At A Time Reply with quote
leading edge.
and level flight.
their bite.
I've added and taken off leading edge tape and foil on quit a few props over the years and never noticed any change in the performance. Those were IVOs, wood props and powerfins mostly tho. Could make a difference on the WD, I'm only on my second one.
Oiling K&N's tho, has given me positively scary results Wink. I never developed the trick to what's the right amount of oil, so I oil extremely lightly or not at all to avoid the plugged filter syndrome at that worst possible time.
Dennis Kirby flew out to KSAF this am and we finally shook hands and talked planes, props and flying for a bit. The NM posse is in formation. Dennis is going to invite the Belin trikers to come along too which would be positively neat. I'm going to call the owner of the other Titan on our field this week and see if he wants to go too.
Former partner in my titan may go in his RV-6A, tho he'll be a lone wolf at his speeds....
Still waiting on my vacation grant from work, I'm guardedly optimistic that I'll get it but then again in this economy I may not be in a good position to fight back if I get turned down.
I'm planning to go meanwhile.
The likely gathering spots for the NM posse are either Double Eagle airport or Gallup at this point.
LS
LS
Titan II SS
JetPilot
PostPosted: Sun Apr 19, 2009 12:36 pm    Post subject: Re: One Thing At A Time Reply with quote
I bet removing that ridge could make a huge change on the prop. Going so fast, close to the speed of sound things get very critical. I was looking at a Cirrus the other day, on the tail it had a piece of tape along the leading edge. It took looking closely to see a very small v^v^v^v^ zigzag pattern in the tape, which is acting as a vortex generator. It hardly qualified as a rise in the tape, just something you would feel if you ran your finger along it. I would have never thought that a bump almost to small to see would have made any appreciable difference in the way a cirrus tail flys, but it does !
Kolb MK-III Xtra, 912-S
PostPosted: Sun Apr 19, 2009 1:32 pm    Post subject: One Thing At A Time Reply with quote
LS
My last refuel prior to Monument Valley is Gallup. Easy in and out, if the
wind is not atrocious, like last year.
Also, even if the courtesy car is unavailable, it is an easy walk to a good
restaurant.
Also got fuel and RON at Double Eagle. Got relatives in Rio Rancho.
aoldman(at)xtra.co.nz
PostPosted: Sun Apr 19, 2009 11:35 pm    Post subject: One Thing At A Time Reply with quote
While I can not give any advise on 912 engines I believe I can on 503s. Over
oiling the air filter will reduce RPM.
I wash the filters in warm soapy water or KNL cleaning solution and let dry
in the sun. I do not put any oil on them. When its time to change the plugs
its also time to clean the air filters. .Over oiled filters will leave tell
tail splotchs of oil on the tail plane and shortly after that you may notice
a reluctance to reach full RPM on take off. Removal of the filters at this
stage and it feels like you have been turbo charged.
Tony
Downunder
MK111c
503
David Lucas
PostPosted: Mon Apr 20, 2009 12:32 am    Post subject: Re: One Thing At A Time Reply with quote
Can remember, years ago, where someone dimpled the camber face of his prop blade much like a golf ball has dimples in it and got a slight increase in performance together with about 100 RPM increase at a given power setting. Just dug out the notes I had on it (sorry no photo's);
The dimples were centered on the face of the propeller at the peak of the
camber of the prop blade, 3 rows .5 inches apart. The dimples were
staggered on 3/4 inch center. Diameter and depth of dimple did not not seem too critical. He used a diameter of approximately .200 by .100 deep.
Also; Wicks Aircraft Supply (1-800-221-9425) Part number 259-200 for homebuilt vortelator kit for the prop is one option that allows you to try similar technology without drilling holes in your wood propeller. This modification benefits props that are less than ideally efficient.
This info is a bit old, so part No's etc might have changed.
David.
slyck(at)frontiernet.net
PostPosted: Mon Apr 20, 2009 4:39 am    Post subject: One Thing At A Time Reply with quote
I do have a K&N filter on my solex but consider it to be mostly a bug
screen too.
Probably needs a debugging this spring.
K&N advertises aftermarket intake filter kits in all the car mags.
predicting X amount of increased hp
which is a lot of BS. In most cases the factory big box type filter
has been engineered to get as good as
you will get. Any perceived benefit from the K&N is just that....
perceived, like how you swear your
engine now runs smoother after that oil change. -not.
BB
503s. Over oiling the air filter will reduce RPM.
let dry in the sun. I do not put any oil on them. When its time to
change the plugs its also time to clean the air filters. .Over
oiled filters will leave tell tail splotchs of oil on the tail
plane and shortly after that you may notice a reluctance to reach
full RPM on take off. Removal of the filters at this stage and it
Tony
Downunder
MK111c
503
lucien
PostPosted: Mon Apr 20, 2009 4:59 am    Post subject: Re: One Thing At A Time Reply with quote
screen too.
BB
Don't want to get into a K&N bash fest, but truth is the unoiled filter is perfectly adequate for our needs as we generally don't run our motors on the ground for long periods of time. Mostly we're up in the clean air.
Oiling is a black art the first few times you do it and making a mistake those first couple of times till you get the hang of it can be very expensive and possibly painful.
I practically never oil mine for that reason as I'd rather be assured the fan keeps turning after cleaning and installation. Without the oil they still filter quite well, certainly well enough for our needs.
First annual I did on my plane was with an AnP over at Los Alamos, NM. Anyone who's flown in there knows your only choice for departure involves a 500' or deeper cliff right off the east end of the runway into a giant canyon (with who-knows-what buried down there from activities of LANL). No way I was going to blast off from there with freshly oiled filters so we left em dry (and they stayed that way till I replaced them).....
Finally, do use the K&N solvent for cleaning, tho. A regular solvent will eventually damage the element....
LS
LS
Titan II SS
williamtsullivan(at)att.n
PostPosted: Mon Apr 20, 2009 5:23 am    Post subject: One thing at a time Reply with quote
Lucien- Please correct me if I'm wrong. A friend with extensive 2-stroke knowledge told me that oiling the K&N filter is generally unnecessary because a 2-stroke at idle will "chuff" back into the filter, leaving oil. This would not apply to 2-strokes with a reed valve. If run at low speeds for a while it will become over oiled. If oiled as per spec, and then run at low speed, it can cause noticable loss of power. He said what you said- for our usage, clean and don't oil. Would you agree with this?
      Bill Sullivan
      Windsor Locks, Ct.
      FS 447
PostPosted: Mon Apr 20, 2009 5:34 am    Post subject: One Thing At A Time Reply with quote
Lucien/Gang:
My experience and opinions only.
I don't know where you have been flying, but there isn't any clean air, even
if it looks clean.
I would not consider operating my engine without the K&N filter oiled.
You just think "we're up in the clean air." Short local flights will
probably not give you a real indication of how much dirt that little gold
plated engine is injesting, but do an 8 hour flight day and you will be
amazed at the amount of crude that collects on the leading edges of
everything. What you don't see when flying is what can hurt you.
I'm not an expert at cleaning and oiling K&N air filters, so I usually over
oil. I also clean them with gasoline. I think it does a better job, is
quicker, and a lot less expensive. I have never seen gasoline damage
cotton. I have never had an engine problem because of a K&N oil filter that
was over oiled.
I wouldn't buy an engine if I new it had been operated without an adequate
air filter.
Again, I am not going to gamble on the life of my engine by not oiling the
filter. In addition to the airplane, I also use oiled cotton and oiled foam
rubber air filter elements on my ATV and dirt bike. Without the "correct"
oil, they probably would not last all day.
There is a difference between the oil used for cotton and foam elements.
Best not get them mixed up. Seems the oil for foam elements is quite sticky
and thicker than oil used for cotton.
Again, my own experience and opinions only.
PostPosted: Mon Apr 20, 2009 5:47 am    Post subject: One thing at a time Reply with quote
Bill S:
Far as I know, most two and four stroke engines experience what I call "fuel vapor stand off". That is a little fuel vapor cloud that sits a couple inches off the mouth of the carb. I discovered this when I was a kid experimenting (playing) with the B&S engine on my Dads lawn mower. My 1935 Ford pickup did the same thing. My 447 and my 912 engines do it too. That is where a lot of excess oil is coming from on two strokes that are configured with the air filters/carbs positioned perpendicular to the air stream. Wind blows that little cloud of fuel vapor out of the filter.
My 912 K&N filters are red after oiling, but will be blue the next time I pull them for cleaning and oiling. Why, lots of blue dye in 100LL. How does the air filter get satuarated with this dye when there is constant vacuum pulling air from outside to inside?
If you all think you do not need to oil your K&N filters, that is your business. Personally, I think K&N engineers know a lot more about their filters than the average man on the street.
Most all the sand rails, dune buggies, and atv's I ran into in the dunes of California, Arizona, and Nevada, use oiled cotton air filter elements, either K&N or some of the newer names or air filter producers. Doubt you'll see any of those filters run dry.
      Bill Sullivan
      Windsor Locks, Ct.
      FS 447
lucien
PostPosted: Mon Apr 20, 2009 6:13 am    Post subject: Re: One Thing At A Time Reply with quote
It's not where you go, it's how long you're up.
The acid test is pulling the filter after a period of running time and seeing if anything has collected on the inside. I.e. if you drag a finger along the inner part of the filter and it leaves a little road in some dust, then you have a leak or the element is letting dirt in.
I've run the K&N's for about a decade and many 100's of hours without oiling and have never seen anything other than a completely clean filter on the inside.
Damage to the element due to using the wrong solvent (i.e. any kind of kerosene) will give you telltale little bits of white stuff on the inside of the filter.
was over oiled.
I have had trouble and in the most notable case was extremely lucky that the plane was a slow one and I had plenty of runway left.
Rich running and low power is another common result I've had before I finally decided not to use the oil anymore.
Never again for me.
The hazard from over oiling is far, far greater than not oiling the filter and being assured of good airflow and correct mixture. Again, it has not been my experience that the K&N doesn't work adequately without oiling but it definitely has been my experience that an over oiled filter is extremely dangerous and the greater of two evils.
How well the filter is functioning is easy to verify by pulling it on a regular basis and checking the inside, and I've never observed a problem anywhere I've flown any of my engines.
My experience and opinions only as well,
LS
LS
Titan II SS
wrk2win4u(at)msn.com
PostPosted: Mon Apr 20, 2009 6:13 am    Post subject: One Thing At A Time Reply with quote
Regarding filtering “clean air”; I agree with most everything John has posted. Where I differ from John is; I don’t like to use gasoline for anything except the fuel tank
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I bought my diesel truck new in “96. When it was time to change the air cleaner C I replaced it with a K&N.  The filter has been used for over 120K miles C (12 years) and is in great condition.
Yes C it can be costly to clean and oil filters. All of my vehicles and tractor now have K&N filters. I have used paint thinner as a cleaning solvent for the filters. This breaks down the oil and releases the gathered gunk. It does not appear to harm the filter fibers at all. Use a regular pump bottle you can buy at Wal-Mart to apply the thinner. Then wash the filter in a dish soap/warm water solution. Allow it to dry before applying the oil. I buy the genuine K&N oil from an online auto parts distributor in the 1 gallon container. If you warm the oil before applying it C it will move through the pump easier and will permeate the filter.
Just an opinion of a reader of the list.
I am still looking for MY KOLB.
Kurt
Sandy C Utah
[quote] From: jhauck(at)elmore.rr.com
Subject: Re: Re: One Thing At A Time
Date: Mon C 20 Apr 2009 08:34:21 -0500
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
Lucien/Gang:
I don't know where you have been flying C but there isn't any clean air C even
if it looks clean.
> Don't want to get into a K&N bash fest C but truth is the unoiled filter
plated engine is injesting C but do an 8 hour flight day and you will be
I'm not an expert at cleaning and oiling K&N air filters C so I usually over
oil. I also clean them with gasoline. I think it does a better job C is
quicker C and a lot less expensive. I have never seen gasoline damage
was over oiled.
> still filter quite well C certainly well enough for our needs.
air filter.
Again C I am not going to gamble on the life of my engine by not oiling the
filter. In addition to the airplane C I also use oiled cotton and oiled foam
oil C they probably would not last all day.
> Finally C do use the K&N solvent for cleaning C tho. A regular solvent will
Again C my own experience and opinions only.
john=======================
Rediscover Hotmail®: Get e-mail storage that grows with you. Check it out.
PostPosted: Mon Apr 20, 2009 6:17 am    Post subject: One thing at a time Reply with quote
John- I use the K&N pre oiled filter, and I have not had occassion to clean it. I don't know if it could be run dry, but I wouldn't. Where I have run it, it was dusty- including my yard. I have seen engines (log skidders) destroy their engines in a few hours when somebody ran it without a filter instead of cleaning it. Seems like the K&N might allow excess oil to be pulled through pretty quickly, as opposed to the felt type used on a chain saw.  Either way, I think excessive oil would drip off, or get wiped off.  I don't know if it could retain enough oil to clog. The old oil bath filters never seemed to restrict air flow (farm tractor and old trucks). Could be my friend is full of it- not for the first time, either.
My problem is probably due to the worn out carb parts, not the filter. I ordered the parts from Lockwood- should be here this week.
Have a nice time at S&F, and say hello to Travis and Dennis for me. I am holding an order for them until they get back.
      Bill Sullivan
      Windsor Locks, Ct.
      FS 447
PostPosted: Mon Apr 20, 2009 6:21 am    Post subject: One Thing At A Time Reply with quote
LS
I think one would get a better idea of how much dirt is getting through the
filter by checking the inside of the carb and intake manifold, rather than
Kurt
Sandy C Utah
Lucien/Gang:
if it looks clean.
was over oiled.
air filter.
Rediscover Hotmail®: Now available on your iPhone or BlackBerry Check it out.
PostPosted: Mon Apr 20, 2009 6:26 am    Post subject: One Thing At A Time Reply with quote
If gasoline were going to damage cotton fiber, seems an air filter for gasoline engines would be made of some other material. I can assure you, the filter element is getting saturated with gasoline the entire time the engine is running.
Probably the reason K&N recommends not using gasoline is the danger of fire.
And, of course, liability. Wink
What does the Rotax manual say about oiling K&N cotton filters?
Kurt
lucien
PostPosted: Mon Apr 20, 2009 6:35 am    Post subject: Re: One thing at a time Reply with quote
[quote="williamtsullivan(at)att.n"]Lucien- Please correct me if I'm wrong. A friend with extensive 2-stroke knowledge told me that oiling the K&N filter is generally unnecessary because a 2-stroke at idle will "chuff" back into the filter, leaving oil. This would not apply to 2-strokes with a reed valve. If run at low speeds for a while it will become over oiled. If oiled as per spec, and then run at low speed, it can cause noticable loss of power. He said what you said- for our usage, clean and don't oil. Would you agree with this?
� � � Bill Sullivan
� � � Windsor Locks, Ct.
� � � FS 447
My personal experience with the K&N has been that it doesn't need oiling in an aircraft application. Or putting it another way, I'd only oil if I were skilled in the art of just enough but not too much oil. But I'm not and couldn't afford bending metal in the process of learning how. So I don't.
All the oil really does is decrease the size of the particulates the element can filter. It still works as a filter without the oil, but it's not as effective on smaller particulates. It has not been my experience that this is a problem in the air (John disagrees with me on this and I fully respect that and don't discount it).
Ironically, I don't agree tho that the emissions from the carburettors qualify as proper oiling of the filter tho Wink. Yes, the 2-strokes do spit up a fair bit and will eventually goop up the bottom of the filter over time. Mine always did this and I went ahead and cleaned them soon as it started getting kind of oily there.
My 912 is even clearing little spots in the bottom of my new filters already after only about 20 or 30 hours of operation, so the 4 strokes spit up a little as well.
In a _ground_ application, oiling is IMO necessary. I ran K&N's on my motorcycle for a long time and you really need the extra filtering there. It also so happens to not be hazardous to over oil on a ground-based motor, tho it will make a mess and cause problems for a while unless you pull it, reclean and reoil with less oil.
Reed valve 2-strokes spit up a little less than our piston-skirt induction 2-strokes due to the longer duration timing on the induction on those, but they'll still do it a little bit.
LS
LS
Titan II SS
lucien
PostPosted: Mon Apr 20, 2009 6:42 am    Post subject: Re: One Thing At A Time Reply with quote
I usually drag fingers in the carburettor throat as well as the filter to check for that very thing (i.e. a leak where the filter attaches to the carburettor body. I've seen that happen and didn't catch it until checking the venturis).
In fact, I have enough hours on my 2 new K&N's that it's time to go pull them and check them for that already..... so this is a good reminder (I also need to pull my bowls and check those as you suggested too...)....
LS
LS
Titan II SS
Goto page 1, 2  Next
Page 1 of 2
