lcfitt(at)sbcglobal.net Guest
Posted: Tue Apr 21, 2009 7:18 am Post subject: Tool Kit |
Deke,
I think if I were looking for a light weight Tool bag, the first place I
would look is my wife's traveling cosmetics bag. Being a flight attendant,
she takes everything and trys to travel light. This might sound funny but
is meant to be serious - at least to the point of big pink flowers on the
"tool" bag.
Lowell
Fox5flyer Guest
Posted: Tue Apr 21, 2009 8:04 am Post subject: Tool Kit |
Thanks Paul. Your input is always welcome. See below:
Rags are a given. Always in the airplane anyway.
Can't see the value of wd40
Clamptite would be a duplication of the pliers/leatherman
Already have the Leatherman and it's very handy to have.
Cell phone is always with me and I charge it every night. On an overnight
trip I have a charger in my ditty bag.
Spark plugs probably are over kill, until you need one.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Been discussed but your new list left off.
2 shop rags
smallest available (4 oz?) can of WD-40
your small clamptite for that safety wire
Watch for unnecessary duplicity. Your Leatherman might have the wire
cutter function
and part of the screw driver collection. Since you are committed to using
a bag for
tools, I don't see the need for an overpriced Leatherman. Select just the
tools you
need. I'm not too fond of combination screwdrivers either. I think you can
make do
with a single phillips and a wedge blade. The wedge blade doubles as a pry
bar which I
find to be needed frequently. I would be easily dissuaded on this if you
have torx,
squares, allen and others on your plane. I have a screwdriver made by
Stanley I got at
Wal-Mart with a set of bits that included all the torx, phillips, allen,
square tip
and wedge tip bits I need in a little hard plastic snap holder. You don't
have to dump
all the bits out in a pile and sort through it until you find the one you
want. You
you can see each tip. The driver is actually 1/4" drive with a coupler for
the bits.
The shop rags are probably the most often used items. Any oil spill you
don't want
streaking the length of your plane, cleaning a giant squashed bug off the
windshield
you got taxiing right at dusk or that nasty glob of grease you picked up
near a fuel
island on a tire or anything you need to wipe to see if you have stopped a
leak.
Make sure you have what it takes to charge your cell phone from your
plane's
electrical system too. Cell phone is especially good for solving those
nagging
'miscellaneous' repair problems. The ones that give you a headache unless
you can fix
them at home.
You really think extra spark plugs are necessary for a 4 stroke engine? I
don't.
> Some sort of combination screwdriver
> Light weight box cutter
> Duct tape, small roll. Could be also be wrapped around box cutter or
> screw driver.
> Silicone Rescue Tape...optional
> 1/4" compact socket set - optional
> Small wire cutters -- optional
> 6" crescent type wrench
> 6" vice grips or equivalent
> 8 feet 18g insulated wire
> Small roll safety wire .032
> Tie wraps of various sizes
> Leatherman or equivalent
> Continuity tester
> Spark plug wrench
> Extra spark plugs
> Canvas or Cordura type bag.
Fox5flyer Guest
Posted: Tue Apr 21, 2009 8:08 am Post subject: Tool Kit |
Thanks, Lowell. I'll see what I can find. Not sure though if a cosmetics
bag would be durable enough, but I'm keeping an open mind. Can I get one in
camo?
Deke
Deke,
attendant, she takes everything and trys to travel light. This might
sound funny but is meant to be serious - at least to the point of big pink
flowers on the "tool" bag.
Lowell
JetPilot
Posted: Tue Apr 21, 2009 8:12 am Post subject: Re: Tool Kit |
The black canvas reusable shopping bags that Wal Mart sells are great ! They are light, strong, durable, and only cost a dollar. Even with a screwdriver, you would have a hard time poking a hole through one, and they are the perfect size to wrap around a portable tool kit.
Mike
Kolb MK-III Xtra, 912-S |
n85ae
Posted: Tue Apr 21, 2009 8:17 am Post subject: Re: Tool Kit |
A ziploc bag with a few bandages, and some handy wipes is always a good
toolkit addition.
Jeff
Fox5flyer Guest
Posted: Tue Apr 21, 2009 8:34 am Post subject: Tool Kit |
That kinda transitions to a "survival" kit, which I intend to research next.
Thanks.
Deke Morisse
Mikado Michigan
- Joseph Joubert
Float Flyr
Posted: Tue Apr 21, 2009 1:39 pm Post subject: Tool Kit |
Scrap the tie wraps and put in a small length of string... nylon would be good.... You will be able to use the string for everything to holding up shelters to tourniquets if necessary. You w0uld even be able to stitch up a wing with it if you had to. Your leatherman could make the holes wax from a candle would make the end of the string stiff enough to push through the holes and the tape would seal the repair until you get home. String can also be used to do just about anything tie wraps can do only more.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Tuesday, April 21, 2009 9:49 AM
To: Kitfox List
Subject: Tool Kit
I've gone through my tool kit list, added a few things and thrown out a few others. The ones labeled optional may or may not be added. I need to start looking around for a tool bag. Maybe Home Depot. Most of the other things I already have on hand.
If anyone has any comments, pro or con, don't hesitate to post them. There was one time when I wish I would have had this tool kit and I suspect that there will be another time one day and I want to be prepared, whether for me or to help out someone I'm flying with.
Deke
Duct tape, small roll. Could be also be wrapped around box cutter or screw driver.
1/4" compact socket set – optional
Continuity tester
Spark plug wrench
Extra spark plugs
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Tue Apr 21, 2009 2:14 pm Post subject: Tool Kit |
Jeez, Deke, I hadn't heard you were switching to Jabiru power. : )
Lynn Matteson
Jabiru 2200, #2062, 632.8 hrs
Sensenich 62x46
Status: flying
On Apr 21, 2009, at 8:18 AM, fox5flyer wrote:
| Quote: | There was one time when I wish I would have had this tool kit and
prepared
Deke
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Tue Apr 21, 2009 2:41 pm Post subject: Tool Kit |
Taking that thought a step further, how about a length of rib lacing
cord? It's already got the wax impregnated in it. I used it to bundle
some of the wires in my plane, so if I forgot to take it along with
me, I could just rob some from the plane and not tell the FAA that
I've now got some wires dangling. : )
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 21, 2009, at 5:38 PM, Noel Loveys wrote:
| Quote: | Scrap the tie wraps and put in a small length of string... nylon
Noel
N369LM |
Float Flyr
Fox5flyer Guest
Posted: Tue Apr 21, 2009 4:13 pm Post subject: Tool Kit |
No, not yet anyway. What happened was shortly after my annual I failed to
completely tighten one of the fittings on the header tank and the fuel smell
made me land at the nearest airport where I had to borrow tools and go to
town for tie wraps because it required removing the seat to get at the
fittings. It didn't start leaking until midway through the second flight.
Not a real big deal, but would have been much easier if I'd had a tool kit
with me. Because of that I plan to have enough tie wraps to replace the
seat should it become necessary. They weight next to nothing and don't take
up much space.
When is that wind going to stop blowing?
Deke
Fox5flyer Guest
Posted: Tue Apr 21, 2009 4:27 pm Post subject: Tool Kit |
To Lynn and Noel. Good one. Already added to my list!
Deke
peteohms
Posted: Tue Apr 21, 2009 4:35 pm Post subject: Tool Kit |
6 pack of Miller Light
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Float Flyr
Posted: Tue Apr 21, 2009 5:21 pm Post subject: Tool Kit |
Why didn't I think of that one???
Noel
Kitfox III-A
peteohms
Posted: Tue Apr 21, 2009 5:42 pm Post subject: Tool Kit |
6 pack was the only tool on my list.
After drinking a 6 pack ya can't fly anyway so you don't need tools.
Pete
Leander, TX
Lynn Matteson
Posted: Tue Apr 21, 2009 5:47 pm Post subject: Tool Kit |
When I attended an Electrical and Avionics weekend workshop, one of
the great things I took away from there was the use of a pair of
really close cutters (available from an electronics store) that
almost eliminate that problem. They also suggested the use of
fingernail clippers to trim the tie wraps close.
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 21, 2009, at 7:28 PM, Noel Loveys wrote:
Great idea. Wax chord could also be used to start a fire or floss
your
teeth. Seriously wax chord was used extensively in aircraft
before the
advent of nylon tie wraps. I have a beef with the tie wraps and
that is
when cropped if not rounded they will gash open hands reaching into an
engine compartment tugging on things to check they are solid.
Noel
N369LM |
Lynn Matteson
Posted: Tue Apr 21, 2009 6:05 pm Post subject: Tool Kit |
Speaking of seat security, mine is held in place by 4 hose
clamps...there used to be 8, but that seemed like overkill, so I
reduced the number.
And also speaking of seat security, I'm glad mine is held in position
so well, as the following incident will attest. I wrote this up the
other day and sent to a few folks, and I'll paste it here:
I had my first "zero gravity" encounter yesterday. I had just left
the Saturday morning fly-in at a close-by field, and came back to
buzz the field. I was crankin' along pretty good....in the yellow
band (108 mph+)....and when I got within a safe distance from the
trees on the north end of the field, I yanked it back, saw nothin'
but sky, then pushed the nose down. At that point, all my charts, a
jacket, and other stuff hit the cabin roof. That was pretty cool, and
when I got it leveled out and was heading for home, I noticed that a
screwdriver that I keep on the floor of the plane was laying between
my legs on the seat. That's a pretty good display of zero gravity in
my book. Good thing I had the belts tight, and shoulder straps.
One of the guys who was at the field said later that I was angled up
at about 45 degrees, but I could have sworn it was straight up or
even over on its back. I don't intend on making a career out of doing
this sort of thing, but it's nice to know the Kitfox will hold up (?)
to such occasional outbursts of exuberance on the part of the pilot.
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 21, 2009, at 8:12 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
failed to completely tighten one of the fittings on the header tank
and the fuel smell made me land at the nearest airport where I had
to borrow tools and go to town for tie wraps because it required
removing the seat to get at the fittings. It didn't start leaking
until midway through the second flight. Not a real big deal, but
would have been much easier if I'd had a tool kit with me. Because
of that I plan to have enough tie wraps to replace the seat should
it become necessary. They weight next to nothing and don't take up
much space.
Deke
N369LM |
Float Flyr
Posted: Tue Apr 21, 2009 6:19 pm Post subject: Tool Kit |
A few swipes with a piece of sandpaper over the cut ends of the tie wrap
works wonders too. Problem is most people just don't take the time to do
it. Helicopter crews do it right. They pretty well go over every job with
a piece of loose cloth.. if the cloth grabs an where it is fixed so not to.
Even the cotter pins they install are done in such a way so you can wipe
them down without hooking the cloth.
Noel
Kitfox III-A
Fox5flyer Guest
Boilermaker2000
Joined: 14 Apr 2009 Posts: 11 Location: West Lafayette, IN
Posted: Wed Apr 22, 2009 3:36 am Post subject: Re: Tool Kit |
| Fox5flyer wrote: | | Nah, Guiness. |
Not a bad idea. It meets the duel purpose criteria;drink and/or motor oil.
