patreilly43(at)hotmail.co Guest
nebchmp(at)suddenlink.net Guest
Posted: Wed Apr 22, 2009 9:29 am Post subject: Tool Kit |
FWIW: I needed to make a solder repair on my two meter hand held in a
confined area. I bought one of the battery soldering irons and it
worked. This one is made by Weller, (BP645) 4.5 volts, 6 watts,
purchased at Lowe's.
Norm.
Float Flyr
Posted: Wed Apr 22, 2009 2:09 pm Post subject: Tool Kit |
It may be a little light for rib lacing but it would be more than enough to temporarily repair a small tear in a wing or fuse.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of patrick reilly
Sent: Wednesday, April 22, 2009 12:09 PM
To: kitfox matronics
Subject: RE: Tool Kit
Noel, If rib lacing cord can be used for dental floss, how about reversing that and using dental floss for rib lacing in a pinch?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> From: noelloveys(at)yahoo.ca
> To: kitfox-list(at)matronics.com
> Date: Tue, 21 Apr 2009 20:58:23 -0230
> --> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
> Great idea. Wax chord could also be used to start a fire or floss your
> teeth. Seriously wax chord was used extensively in aircraft before the
> advent of nylon tie wraps. I have a beef with the tie wraps and that is
> when cropped if not rounded they will gash open hands reaching into an
> engine compartment tugging on things to check they are solid.
> Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Wed Apr 22, 2009 2:38 pm Post subject: Tool Kit |
I've done soldering with a match in desperate situations.
Noel
Kitfox III-A
