Discussions about the 601XL
lwhitlow
PostPosted: Thu Apr 23, 2009 5:11 pm    Post subject: Discussions about the 601XL Reply with quote
I realize that all of engage in Armchair engineering and by posing some of these questions, answers are going to com in all over the lot but.....
Lets get the talk going here. I'm not tryin to second guess the engineers and Zenith while they work the issue but I think some opinions and observations could do us all good to understand the implications of any change or fix
So My first question is, Almost every one notes that the 601XL is sensitive to very sensitive in pitch, and per a revised drawing from Zenith we have an elevator stop now.
But why not just change the cable geometry to decrease overall movement of the elevator (think moving the cable attachments closer together either at the elevator end or the sticks end or both)?? If this was done would you still have enough control throw at the slow end of the speed range?? This would make it less likely to create a large input that could damage structure.
Secondly Has a 601XL wing been static tested to destruction?? Are there pictures??? Where were the failure points?? I'm not saying simply beef up that point but it would help all of us to understand what the failure mode looks like so we could start to understand the forces at play here.
Enough questions to start with Lets all play nice with our answers.
Larry Whitlow
601XL N69102 (reserved)
Flying this Summer COUNT ON IT!!!
jaybannist(at)cs.com
PostPosted: Thu Apr 23, 2009 5:33 pm    Post subject: Discussions about the 601XL Reply with quote
Larry,
I think you have the geometry wrong. Moving the cable attach points closer to the hinge line would make it MORE sensitive, not less. However, I really don't think there is enough room to move the attach points further out, either at the forward bellcrank or at the elevator horns. I would settle for something that would make it progressively harder to move the stick the further you move it from neutral. That wouldn't reduce the elevator effectiveness, but it would make it harder to move the stick to extreme positions, fore or aft.
Jay Bannister
notsew_evets(at)frontiern
PostPosted: Thu Apr 23, 2009 5:38 pm    Post subject: Discussions about the 601XL Reply with quote
Like a parallel of bungees ?
lwhitlow
PostPosted: Thu Apr 23, 2009 5:42 pm    Post subject: Re: Discussions about the 601XL Reply with quote
Thanks Jay Its tough to picture the geometry in my head I should have drawn it out
But if you moved them all in at both ends wouldn't the travel be less??
Larry
jaybannist(at)cs.com wrote:
Larry,
Jay Bannister
psm(at)att.net
PostPosted: Thu Apr 23, 2009 8:20 pm    Post subject: Discussions about the 601XL Reply with quote
Hi Larry,
I think the answer to your elevator question is that it brings in the
"Law of unintended consequences".
While reducing the likelihood of a pilot induced wing separation your
change would also reduce the effectiveness of pilot control of pitch
- particularly at low speeds. One of the Zodiac's really great
features is that it doesn't lose control authority at near stall
speeds like most of the spam cans (part 23 planes) do.
I believe there are ways to fix the stick gradient problem without
impacting the low speed control authority. That seems like the ideal
choice to me.
Paul
XL grounded
