thesumak(at)aol.com Guest
Thruster87
Posted: Sun Apr 26, 2009 1:38 pm Post subject: Re: Cable gauge calibration |
Usually the tensiometer will have a calibration strip with which to check for correct operation but if you mean pulling the whole thing apart then no.You can also set up a cable with a bucket hanging from it and filled to a specific weight to test your gauge. Hope this helps
Gig Giacona
Posted: Mon Apr 27, 2009 5:11 am Post subject: Re: Cable gauge calibration |
When I spoke with the DAR that will be inspecting my plane for the AW certificate he said that he will be asking for two things (and aircraft log book entries to back them up) regarding cable tension.
1. That cables have been tensioned to design specs and what those specs are.
2. That the device used to check the cable tension was properly calibrated according to the instructions that came with the tension measuring device.
I specifically asked about people that build their own meter. He said they need to write calibration instructions for it as well.
601XL Under Construction
Juan Vega Jr
Posted: Mon Apr 27, 2009 6:08 am Post subject: Cable gauge calibration |
just hang 30lbs of stuff off the tensionometer, then take a photo or something to show it was calibrated.
Juan
