msm_9949(at)yahoo.com Guest
Posted: Mon Apr 27, 2009 8:22 am Post subject: Paint question |
I'm painting the bumps on my cowling which had been previously painted with many coats of glossy Polar White Aerothane. I've masked and sanded the bumps to remove gloss. What should I use to clean or treat the surface before painting to insure good adhesion? Will regular Stitts enamel stick to Aerothane if surface is prepared as I've described?
Any advice would be appreciated.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
GSC
n85ae
Posted: Mon Apr 27, 2009 10:35 am Post subject: Re: Paint question |
Most enamel, or polyurethane paints should work as well as the the surface
has been sanded with 320/400 grit. It the suface is aerothane, then MEK
should work, however, if you get through to the poly underneath it'll
melt that. So you might cleanup with denatured alchohol instead.
Jeff
Kitfox Series 5, IO240B
Zenith CH-801 O-360 Builder.
