Sam
Posted: Tue Apr 28, 2009 4:38 am Post subject: Grounds & noise |
This is a re-post from the Rotary Engines list, by Tracy Crook, owner of Real World Solutions, in response to a builder whose ECU seemed to reprogram itself. It is very interesting to me because I am half way through trouble shooting a magneticly induced noise problem (see www.samhoskins.bolgspot.com).
[quote]My experience so far indicates that electrical noise in various parts of
the electrical system is the cause of the 'spontaneous' programming errors.
This is a long subject that I am going to have to address. It has to do
with the physical arrangement of the aircraft electrical system, not an
error in connections. There is no one simple fix for this kind of problem
which is caused by builders having no guidlines on how to avoid this kind of
thing. Bad radio installation practices or poor antenna design or
installation can also be a nightmare to explain or fix.
I talked to a number of vendors of aircraft systems at SnF that are having a
hell of a time addressing this. Everything from auto pilots to Glass
cockpit makers are having this problem. Builders always conclude that we
are passing the buck when we say that electrical noise is the problem. And
that's just a polite way of saying that "Your electrical system and layout
sucks". Even very knowledgable builders can fall into this problem. Mike
Wills made a technically perfect system with a Single Point ground scheme
which is theoretically the right thing to do but the single point ground had
a very high noise impedance due to the long distance between it and the main
noise damper (the battery).
Here is a VERY abreviated guideline. If you do a single point ground
system, make it at (or very near) the negative terminal of the battery and
ground the airframe close to it. Have independant power feeds from the
battery positive terminal for the noise producing things and the noise
sensitive things. Do these two things and noise problems will be rare.
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
Posted: Tue Apr 28, 2009 11:17 am Post subject: Grounds & noise |
. . . Even very knowledgeable builders can fall into this problem. Mike
Here is a VERY abbreviated guideline. If you do a single point ground
ground the airframe close to it. Have independent power feeds from the
I wish it were that simple. The battery's ability to shunt bus
voltage perturbations to ground is very limited. I recall seeing
a shunt impedance versus frequency plots of various batteries
over the years and recall noting meager noise mitigation effects.
If I can find some of those plots, I'll post them.
I'd be willing to bet that the vast majority of antagonist/victim
situations encountered by the OBAM aircraft community can be
solved by an investigation of the DO-160/Mil-STD-704 characteristics
of the major players.
704 says . . .
(1) The bus is loaded with certain kinds of crap.
(2) Learn to control it at practical levels consistent
with state of the art . . .
(3) and live with the rest of it.
160 says . . .
(1) the electrical environment (conducted and radiated)
(2) Control thy emissions to practical limits established
by our state of the art . . .
(2) Expect a certain amount of smelly stuff to be left
over . . . learn to live with it.
While there may be many an anecdotal report of success
for the re-arrangement of wires, ground locations,
filters, shields, etc. etc. they are seldom if ever
joined by a qualitative and quantified description
of the noise, propagation mode and the simple-ideas
that led to an artful recipe for success. Most often,
there's a sort of "swaptronics" approach to stirring
the stew of ideas and parts until the problem goes away
or at least becomes tolerable.
I'm not suggesting that folks should not experiment
to what ever amount of $time$ they're willing to
spend. I will suggest that apparent successes that
fall out of random experiments are at risk for not
becoming recipes for success. I.e. repeatable
experiments. I will also suggest that if your system
is assembled per the recommendations of any of the
Z-figures that the probability of having a "704
issue" is small. This leaves newly discovered victims
with their "160 shorts" down around their ankles.
I'll see if I can find that data on batteries-as-filters.
( -Thomas Paine 1776- )
