DanM
Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
Posted: Wed Apr 29, 2009 1:17 pm Post subject: Rc Allen Turn Coordinator Install |
Hello all, I purchased a used RC Allen Turn and Bank indicator PN 82a-11 for a good price I might add ,to install on my Kitfox IV. Trouble is I didn't get the installation instructions so I'm kinda stuck. I called the factory (Kelly) and they said no instructions are available which seems kinda strange to me. Any way, my main problem is the type and size of wire to use, circuit breaker size and how the wire connects in the connector. Any help would be appreciated.
_________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
clint_bazzill(at)hotmail. Guest
Posted: Wed Apr 29, 2009 1:37 pm Post subject: Rc Allen Turn Coordinator Install |
Hi C
Only 2 connections and it is marked on back. Kind of hard to read C you will have to probably buy the Cannon connector or Amphenol. Number 20 ga wire is more then enough 3 or 4 am would be my guess C its only to protect the wire anyway. I am in my motor home working on plans for home in Mazatzal Airpark C Payson C Az.
Clint
[quote] Subject: Rc Allen Turn Coordinator Install
Date: Wed C 29 Apr 2009 14:17:42 -0700
--> Kitfox-List message posted by: "DanM" <djmc4344(at)sbcglobal.net>
Hello all C I purchased a used RC Allen Turn and Bank indicator PN 82a-11 for a good price I might add Cto install on my Kitfox IV. Trouble is I didn't get the installation instructions so I'm kinda stuck. I called the factory (Kelly) and they said no instructions are available which seems kinda strange to me. Any way C my main problem is the type and size of wire to use C circuit breaker size and how the wire connects in the connector. Any help would be appreciated.
Dan Mc Intyre
Kitfox IV C Ready for Inspection
Jabiru 2200 C 1.5 hours
Sensenich 62x46
N443DM
http://forums.matronics.com/viewtopic.php?p=241975#241975
_==========
Lynn Matteson
Posted: Thu Apr 30, 2009 2:06 am Post subject: Rc Allen Turn Coordinator Install |
I would think that the least they could do would be to send you a
wiring diagram.
Lynn Matteson
Jabiru 2200, #2062, 635.2 hrs
Sensenich 62x46
Status: flying
On Apr 29, 2009, at 5:17 PM, DanM wrote:
appreciated.
Dan Mc Intyre
Kitfox IV , Ready for Inspection
Jabiru 2200 , 1.5 hours
Sensenich 62x46
N443DM
http://forums.matronics.com/viewtopic.php?p 41975#241975
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Thu Apr 30, 2009 4:57 am Post subject: Rc Allen Turn Coordinator Install |
All the instructions you will need are in AC43.13 1b/2a download it form
the FAA site....Free!!
Sections to check are the sections on wiring and panel installations in
respect to being able to sustain G forces without wrecking your panel.
Fuses/breakers should always be as close to the buss as possible. Most
certified jobs actually have one post of the breakers actually on a buss.
That way everything downstream is protected. I have seen guys who put more
than one thing on a breaker. For instance they may have the T.C. wired
with the radio. If the ever get into a situation where they have to load
shed they may have to shut down their radio to preserve the battery.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
mikeperkins
Posted: Fri May 01, 2009 6:00 am Post subject: Rc Allen Turn Coordinator Install |
I looked around for current specs on your particular T/B but could find nothing. However, it is a relatively modern one, which means it is probably very efficient. Even my noisy old T/B draws only 1/4 amp. Therefore I would advise using a 2A circuit breaker and either 22 or 20 gauge wire.
AC43-13V requires some interpretation and it certainly doesn’t tell anyone how much current your T/B uses. However, it’s the Bible. You will find table 11-3 is most useful. The AC can be downloaded from http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/key/AC%2043.13-1B
(One very common misconception is that a CB should be rated to for the expected load. This is not right. But because of the misconception, some guys will go through all kinds of trouble to find a 1.5-amp circuit breaker for a piece of equipment that has a nameplate rating of 1.5 amps when they’re actually using a wire capable of carrying 10 amps. In actuality, the CB should simply be sized to the wire gauge. This is because a CB is meant to protect the wire, not the equipment. If the equipment is going to smoke, a CB won’t stop it.)
Mike Perkins
