Posted: Wed Apr 29, 2009 11:19 am Post subject: Jabiru Powered MKIII |
Yes Quiet.
I have flown in Kolb MKIIIs with a Rotax 503, 582, 912(80hp), 912 (100hp), Jabiru and my VW. The two stroke Rotaxs were open out the back and my ears are still ringing from them. The overworked air-cooled 503 was far and away the worst on my ears. Fat Albert with the 80hp Rotax, open cockpit was also noisy and its high RPM engine just gets to you more. John H. has the 912 100HP and it was the most quiet. It is likely that his big fuel tank between the engine and your ears tends to dampen the vibration/noise. My current VW is somewhere close to a open cockpit 912 but the lower frequency is easer to deal with. My VW high mount that had real soft vibration dampers and it was the most quiet MKIII I have ever flown in. The Jabiru has a much slower turning engine even slower than my VW and it would appear that the vibration dampers were well tuned to stop quite a bit of the noise producing vibrations. The lower frequency noises produced by the Jabiru are also much easer to filer out with available ANR headsets. It is a airplane and noise is a normal condition so yes the Jabiru is a close runner up for the most quiet Kolb MKIII.
I have been looking for softer vibration dampers (bushing) for my VW but haven't found anything yet. This appears to be the most noticeable element in a quiet cockpit. It also reduces the stress on the airframe.
Rick Neilsen
Redrive VW powered MKIIIC
zeprep251(at)AOL.COM Guest
Posted: Wed Apr 29, 2009 4:17 pm Post subject: Jabiru Powered MKIII |
Rick,
You know how sensitive the squelch was on the intercom? Well after talking to David Clark,I was informed that there is a mic gain control on these old headsets.After removing the foam mic cover
the adjusting screw was visible .A half turn made so much difference I couldn't believe it.Even take off power can't trip the vox and the cockpit com is much improved.I'm a happy camper!These headsets are 29 years old!
You are gonna take some heat on that Quiet claim,but thanks for the effort!
G.Aman MK-C Jabiru 2200, now comfortably in touch with the right seat!
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Wed Apr 29, 2009 9:00 pm Post subject: Re: Jabiru Powered MKIII |
What??? Am I reading this right??? lol What about the JABIRU??
chris ambrose
M3X-Jabiru
N327CS
pj.ladd(at)btinternet.com Guest
Posted: Thu Apr 30, 2009 1:53 am Post subject: Jabiru Powered MKIII |
The lower frequency noises produced by the Jabiru are also much easer to filer out with available ANR headsets.>>
Hi,
thanks for the input but its not the noise in the cockpit , it is the noise outside which is the problem.
Noise problems are probably more important in Europe than they are in the US. All microlights have to pass a noise test and have a certificate issued and the Kolb, and my old Challenger with the 503, only just squeaked in.
Most complaints from groups trying to get airfields closed, and there are a lot of them, are based on the noise factor.
Were it not for the fact that I have been flying from the same field for 20 years I am sure that the farmer who owns it would have asked me to move out. I never do circuits. Fire up and fly away is the rule.
I would love to have enough spare weight allowance to cowl the engine completely.
Pat
zeprep251(at)aol.com Guest
Posted: Thu Apr 30, 2009 4:23 am Post subject: Jabiru Powered MKIII |
Pat,
I think your observations on pushers being louder is obviously accurate.The Lake amphibian,the Seabee and and the Cessna 337 can all be identified by a blindfolded librarian at 5 miles range.
G.Aman,still happy about the com.
Posted: Thu Apr 30, 2009 4:26 am Post subject: Jabiru Powered MKIII |
Well Chris,we get our 15 minutes of fame! Are you happy with the Jab?
G.Aman
russ(at)rkiphoto.com Guest
Posted: Thu Apr 30, 2009 5:11 am Post subject: Jabiru Powered MKIII |
PatDoes your 'spare weight allowance' refer to empty wt. or gross wt?
Russ
On Apr 30, 2009, at 8:20 AM, zeprep251(at)aol.com (zeprep251(at)aol.com) wrote:
[quote] Pat,
Posted: Thu Apr 30, 2009 7:28 am Post subject: Jabiru Powered MKIII |
Pat & Chris
You need to get out more. Yes our Kolbs are all noisy but in comparison,
Gary's was a bit quieter than some other Kolbs. Seems like Gary has a
barrier right behind the cockpit and his Senrich prop must also help.
Again I'm talking about inside the cockpit. If there were thousands of
planes circling a island all the time I'm sure we would introduce noise
limits too.
As for performance I flew with and watched John W's Jabiru powered Kolbra
fly in and out of a short strip in Michigan's UP. It was noisy and very
under powered, very scary. I know there is 5 more HP in the newer model
Jabirus but that doesn't explain the improvement I have seen in two newer
Jabiru powered MKIIIs. Not 912 level performance but good. The only thing I
can think of is the prop. Now this going to piss the Warp Drive guys off but
it has to be the low performance of the WD prop that John W was using. Sure
do miss John Williamson.
Rick Neilsen
Redrive VW Powered MKIIIC
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Thu Apr 30, 2009 8:51 am Post subject: Re: Jabiru Powered MKIII |
| NeilsenRM(at)comcast.net wrote: | Pat & Chris
limits too.
Rick Neilsen
I'd be more inclined to think it was the lower diameter myself. I think the typical prop diameter for the jab is 60" or perhaps even less, definitely not a good climb configuration for the flight characteristics of the Kolb.
Despite the vibration problems I'm having with my WD, the performance is nothing short of spectacular. And the WD worked really well on my FS II also.
Too bad the jab doesn't have a good gear reduction, a-la the old continental GO-300. It'd be a monster of a motor for slower climbers I'd be willing to bet.....
LS
_________________ LS
Titan II SS |
Posted: Thu Apr 30, 2009 9:50 am Post subject: Jabiru Powered MKIII |
Lucien
It is tip speed, turbulence and a bit of black art of prop design that
determines how much HP is turned into noise. The Jabiru turns its prop at a
higher RPM so it has to turn a smaller diameter prop to keep its tip speed
down. My direct drive VW with a 60" prop would go supersonic at the prop
tips in a heart beat and noise that would wake the dead.
Yes I know your WD is spectacular but you might be surprised just how much
better performance could be had with a more efficient prop. You have so much
extra power with your redrive Rotax that you can be real happy with lower
prop efficiency.
Redrives in airplanes when done right are wonderful. The continental engine
probably did more to hurt the reputation of redrives than anything. Redrives
aren't just great for the slower airplane group. The RR Merlin, and most of
the big radial engines in WWII airplanes had redrives and they were not what
I would call slow airplanes
This is a good rainy day discussion.
Rick Neilsen
Posted: Thu Apr 30, 2009 11:08 am Post subject: Jabiru Powered MKIII |
| Quote: | it has to be the low performance of the WD prop that John W was using.
Sure do miss John Williamson.
Rick Neilsen
Rick:
Me too.
John W had to use a very tiny two blade prop with the Jab powered Kolbra.
When he installed the 912ULS, he also added a 68" 3 blade fast taper prop.
I have said many times before. Cruise speed with John W's Jab was about the
same as my mkIII with 912ULS. However, there was absolutely no comparison
between take off and climb between our two airplanes. Took John W forever
to get off the ground and get some altitude.
All that changes when John W upgraded to a 912ULS. He out climbed and out
ran me bad.....
mkIII - Ready to fuel up, load, and head West.
_________________ John Hauck
Titus, Alabama |
lucien
Posted: Thu Apr 30, 2009 11:18 am Post subject: Re: Jabiru Powered MKIII |
| NeilsenRM(at)comcast.net wrote: | Lucien
prop efficiency.
Rick Neilsen
Well next week I'll be fitting the strongest pusher on the market to my plane (powerfin F model) in an effort to debug (hopefully fix) my harmonics problem with non-IVO props. So I'm expecting the "up" to be very good, tho I'm guessing (and expecting) it won't do as well in the "forward" department (if it runs smooth, I won't care).
But yes the WD is a compromise. It has the widest speed range you can get in a fix pitch so sure it has less thrust at very low speed regimes. But it really works well overall performance-wise.
When operated right, the geared continental is a fine engine that pulls the 170 and 175 around real well. Back in TX, one of the locals had a 175 with that motor in it. It was lugged a lot like most of them and had to be given a top somewhere midway to TBO. But after that, once she learnt how to run it (spin it up to the 3200 rpm range), it gave her no trouble and the performance of the plane was fine. But you're right it got a bad rap because of poor training in its use.
I appreciate the Jab's simplicity with the direct drive for sure, but with a redrive it'd compete pretty well with the 912 series as far as performance on a wider array of planes, IMO. The 3300 would just be a monster........
LS
Titan II SS |
Posted: Thu Apr 30, 2009 11:21 am Post subject: Jabiru Powered MKIII |
much
| Quote: | better performance could be had with a more efficient prop. You have so
much extra power with your redrive Rotax that you can be real happy with
lower prop efficiency.
How did you come up with this earth shattering bit of info.
I am devastated, having flown so many hours with an inefficient prop.
Guess the other wooden props I flew with were even more inefficient.
Damn, you have ruined my day. How will I ever fly to MV with a WD.
Last year at the Kolb Homecoming, Steven Green challenged me to a flat out
top speed race. We started side by side and stayed that way until I
eventually went full throttle and left Steven, his mkIII, his 912ULS, and
his big Ivo two blade prop.
Still looking for something better, but haven't found it yet.
Wonderful blue bird afternoon at hauck's holler, alabama.
Titus, Alabama |
Posted: Thu Apr 30, 2009 12:03 pm Post subject: Jabiru Powered MKIII |
Really didn't want to ruin your day but I know you are just joking.
The first bit of info came from Steve Bennet at Great Plains Aircraft. He
did a apples to apples comparison test as close as he could with Warp Drive,
PowerFin, and IVO props. The IVO gave the least thrust, then Warp Drive,
then PowerFin giving the most.
The second comes from my not to scientific observations of Warp Drive and
Senrich props on Jabiru powered Kolbs. The performance is considerably
better than John W got with his Kolbra and that 5 extra HP wouldn't account
for all of it. Again a redrive on a Jabiru would help a bunch more.
I also know first hand that wood props can be turned into real expensive
tooth picks. It is also worth knowing that you can put objects through the
prop and still fly home.
Have a great safe flight.
Rick Neilsen
HShack(at)aol.com Guest
Posted: Thu Apr 30, 2009 12:12 pm Post subject: Jabiru Powered MKIII |
Well, If you expect anything to go thru the Powerfin & still fly home-good luck [not saying anything about performance].
Howard Shackleford
FS II
SC
In a message dated 4/30/2009 4:03:40 P.M. Eastern Daylight Time, NeilsenRM(at)comcast.net writes:
| Quote: | I also know first hand that wood props can be turned into real expensive
Access 350+ FREE radio stations anytime from anywhere on the web. Get the Radio Toolbar!
Posted: Thu Apr 30, 2009 1:26 pm Post subject: Jabiru Powered MKIII |
Howard
I had a 9/16 X 2.5 in bolt go through my PowerFin and it got me the remaining 400 miles home. I had the damaged blade at the Kolb Homecoming a few years ago. In all honesty it hit mid span and did put a big ding in the blade so I guess I had your "good luck".
Rick Neilsen
Posted: Thu Apr 30, 2009 2:42 pm Post subject: Jabiru Powered MKIII |
| Quote: | did a apples to apples comparison test as close as he could with Warp
Drive, PowerFin, and IVO props. The IVO gave the least thrust, then Warp
Drive, then PowerFin giving the most.
I wouldn't bet all my apples on a "static" test. It tells only how much
force is applied to a scale, not what the prop is actually doing in a flying
situation a a specific airplane.
My WD will pull 5400 rpm static, the way it is set now. Soon after I start
my takeoff roll it pulls 100 rpm off the engine. Probably because the air
is getting cleaner and it is getting a better bite. How important is that
in comparison? I haven't the slightest idea, but it does it.
I am not an engineer. I get my info from getting in the air and flying. ;-
Titus, Alabama |
captainron1(at)cox.net Guest
Posted: Thu Apr 30, 2009 3:37 pm Post subject: Jabiru Powered MKIII |
We just had a big discussion on the FlyGeo list, to include a fellow that some empirical testing. I personally was not happy with the methodology but his very careful analysis of props and settings concluded that any criticism of major brands is groundless, and if there are any performance issues with props they are a result of nothing more than either pilot technic or proper settings or propeller for the HP.
That some fellow that has some vested interest in selling props rigged the test to give the results he wanted is not new or news.
rest assured that any of the major props will deliver the same performance and any deviations will be the result of something other than the prop itself.
Now if old Yehoopetz built a prop in his pig barn overnight which performed no better than pig slurry, and then said X-prop was so much better than his 2x4 Bladed Pig Barn Special, I would hold from concluding anything about the excellence of X-prop.
Ron (at) KFHU
---- Richard & Martha Neilsen <NeilsenRM(at)comcast.net> wrote:
Rick Neilsen
rowedenny
Posted: Thu Apr 30, 2009 4:05 pm Post subject: Jabiru Powered MKIII |
Its my understanding that the new Jabs have 10 to 15 more hp than John Ws early model, not 5 more.
So maybe its not just the props that make a differance.
Dennis Rowe
herbgh(at)nctc.com Guest
Posted: Thu Apr 30, 2009 4:17 pm Post subject: Jabiru Powered MKIII |
I notice that Culver Props recommends 56 to 62 inch dia props for
Vw's and Jabiru engines.. This is a big efficiency hit ... Redrive
those engines and one can likely turn a 68 to 72 inch prop... Herb
At 07:05 PM 4/30/2009, you wrote:
| Quote: | Its my understanding that the new Jabs have 10 to 15 more hp than
Dennis Rowe
