Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Apr 30, 2009 12:39 pm Post subject: random rivet hole in fuel tank |
I am working on the fuel tanks and noticed a hole on the fuel tank skin to baffle on the bottom of the wing. It is in line with the rest of the machine countersunk holes and is about in the middle on the bottom. I can't find in the plans what this goes to and if it gets riveted. I assume it does but it doesn't show it riveted in the plans. Anyone else know what this is?
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Thu Apr 30, 2009 1:08 pm Post subject: random rivet hole in fuel tank |
I don't remember if both the skin and the baffle have the extra hole,
or just one or the other. It just gets a normal rivet.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Apr 30, 2009, at 4:39 PM, Strasnuts wrote:
Cust. #40936
A&P, ATP
typed CE-525(s), CE-500
RV-10 FUEL TANKS
N801VR reserved
http://forums.matronics.com/viewtopic.php?p 42155#242155
Posted: Thu Apr 30, 2009 2:34 pm Post subject: random rivet hole in fuel tank |
Its not random, turn your skins until all the holes are lined up..
Rick S.
40185
Strasnuts
Posted: Thu Apr 30, 2009 3:09 pm Post subject: random rivet hole in fuel tank |
It is lined up with the baffle hole, I just thought it was weird that the
rivet diagram shows an open hole. I will rivet it.
thanks
780 Hours
Posted: Thu Apr 30, 2009 3:26 pm Post subject: random rivet hole in fuel tank |
Look on the other side of the baffle...you will see the "other" hole
Sent via BlackBerry by AT&T
rv(at)thelefflers.com Guest
Posted: Thu Apr 30, 2009 3:43 pm Post subject: random rivet hole in fuel tank |
Sean,
In looking at 18-5, I see what you are referring to.
Get use to it, it only gets worse as you progress. The plans start
assuming that you know what you are doing and start leaving out steps or not
totally correct illustrations. You'll find yourself having to read ahead
in the plans to get answers to some of things that aren't clearly
documented. The wing plans aren't too bad. I find that I'm spending
significantly more time with the fuselage plans studying things before I
actually start the task.
Yes, just put a rivet in it.
bob
Strasnuts
Posted: Thu Apr 30, 2009 4:05 pm Post subject: random rivet hole in fuel tank |
Thanks Bob,
I don't know what I'm doing, it's just a good thing I have this forum to
bounce questions off of.
Sean
780 Hours
vhicy(at)bigpond.com Guest
Posted: Thu Apr 30, 2009 4:21 pm Post subject: random rivet hole in fuel tank |
Yes you do Sean your building a magic carpet!
Chris
Posted: Thu Apr 30, 2009 5:55 pm Post subject: random rivet hole in fuel tank |
I know this may be a dead horse but if you look at the baffles you will see three very close holes on the bottom of the tank side of the baffle and only two directly above it on the top side of the baffle...the "extra" hole indicates the bottom of the baffle and the skins correspond accordingly....IIRC
Strasnuts
Posted: Thu Apr 30, 2009 6:19 pm Post subject: Re: random rivet hole in fuel tank |
Yep,
I definitely realized the top and bottom of the baffle to the skin and the three close holes. The problem was the plans had no rivet in the middle of the three close holes. I thought maybe I shouldn't be countersinking this hole but realized it was missed in the rivet layout. You have to look extremely close at the rivet layout to notice the hole without a rivet designation.
Thanks for responding though.
780 Hours
evmeg(at)snowcrest.net Guest
Posted: Fri May 01, 2009 6:38 am Post subject: random rivet hole in fuel tank |
I believe that is just there to let you kinow you have the baffle in the
right way...not upside down. Its only on the bottom. Machine and rivit it
with the rest.
Evan
