icubob(at)gmail.com Guest
Posted: Tue May 05, 2009 2:23 pm Post subject: attaching wing wiring |
hi all,
any recommendations for ways/ materials to attach the wiring in a wing to the wing structure that will last as long as the covering?wire ties seems like a natural but will they last 20 yrs?
any comments would be appreciated.
bob noffs
Lynn Matteson
Posted: Tue May 05, 2009 2:42 pm Post subject: attaching wing wiring |
The only wire I have in my wings are the shielded and insulated wires
for strobes and position lights. I ran them through the rear spar
tube where they just lay...hopefully content to live out their lives
without chaffing....fingers crossed.
Lynn Matteson
Jabiru 2200, #2062, 644.7 hrs
Sensenich 62x46 Wood prop
Status: flying
On May 5, 2009, at 6:22 PM, bob noffs wrote:
| Quote: | hi all,
bob noffs
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
kirkhull(at)kc.rr.com Guest
Posted: Tue May 05, 2009 4:24 pm Post subject: attaching wing wiring |
I ran mine down the rear spar. If there is any problems I can just tie on a new piece and pull it through. However I have had no issues in over 200 hours
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of bob noffs
Sent: Tuesday, May 05, 2009 5:23 PM
Subject: attaching wing wiring
hi all,
bob noffs
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Float Flyr
Posted: Tue May 05, 2009 5:28 pm Post subject: attaching wing wiring |
Coraseal won’t cut your hands if you have to reach inside the wing through an inspection port. There are also padded Adel clamps. But for small planes that overkill and heavy.
Noel
Sent: 05 May 2009 07:53 PM
hi all,
bob noffs
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
lcfitt(at)sbcglobal.net Guest
Posted: Tue May 05, 2009 5:33 pm Post subject: attaching wing wiring |
I did the same thing with a length of heat shirnk where it enters and exits
the spars. 900 hours in nine years.
Lowell
Posted: Wed May 06, 2009 2:59 am Post subject: attaching wing wiring |
i am building a wood wing and need a way to fasten the wire to the wood structure. noel, what is coraseal? where can i get it ? small plastic wire ties would work but i dont know about their life expectancy.
bob noffs
On Tue, May 5, 2009 at 8:28 PM, Lowell Fitt <lcfitt(at)sbcglobal.net (lcfitt(at)sbcglobal.net)> wrote:
[quote] --> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net (lcfitt(at)sbcglobal.net)>
I did the same thing with a length of heat shirnk where it enters and exits the spars. 900 hours in nine years.
Lowell
Tom Jones
Posted: Wed May 06, 2009 5:57 am Post subject: Re: attaching wing wiring |
| Quote: | | i am building a wood wing and need a way to fasten the wire to the wood structure. |
Adel clamps and lacing tapes. Here's the tapes at aircraft spruce, includes Koroseal.
http://aircraftspruce.com/search/search.php?query=11-02012&searchsubmit=Search&search=1
AC 43.13-1b has good instructions and pictures of attaching the wire with "Offical" wrapping and knots along with the adel clamps. Electrical is Chapter 11. Wiring is in the "environmental section (section 9) It starts on page 11-51 and the lacing techniques start on page 11-61. Here's chapter 11. http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2011.pdf
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Posted: Wed May 06, 2009 6:43 am Post subject: attaching wing wiring |
I think we were unaware of your wing when we all gave our advice. I
recently strung the wires for trim and aft position lights up the fuselage.
I used wire lacing tape spaced about every three inches along the stringer.
It can also be used where there is no attachment to a structure to bind the
bundle together for strength. Do a google search on lacing tape. There are
numerous sources. I used a "clove hitch" knot with a square knot to secure
it. The material is very light, wax coated so the knots don't tend to
loosen while working on them and will last forever.
I drilled small holes in the stringer every nine inches or so. This way, I
could attach the wire without the wrap creating a lump under the fabric. I
don't think I would be drilling any holes in a wing structure, though. If
there aren't internal structures you can tie to, you might try what the
Lancair guy did stringing his wiring. he got those flat adhesive backed zip
tie attachments available at Home Depot, etc. He ground off the adhesive,
drilled several holes through them for a mechanical lock and glued them to
the fuselage or wing skin with structural adhesive, then used the lacing
tape. Not as light as lacing tape alone, but strong and long lasting
Lowell
Guy Buchanan
Posted: Wed May 06, 2009 7:52 am Post subject: attaching wing wiring |
At 03:58 AM 5/6/2009, you wrote:
| Quote: | i am building a wood wing and need a way to fasten the wire to the
wood structure.
When I was designing / building boats and masts, we never fixed wires
or hoses to structure in such a way that it would be difficult to
replace later. There are several techniques available to minimize
slop while still leaving the installations replaceable.
1. For straight runs you can run a tension wire to which the
electrical wire or hoses are affixed at intervals. They are attached
so they will not translate, but will slide. That way new wires can be
slid on while the old is slid off. This would work well in either
wing spar of a Kitfox wing.
2. For crooked runs we often used conduit, which restricts lateral
movement while allowing replacement.
3. If you are careful you can use bulls-eyes at intervals, but you
have to be really careful that things don't get hung up when pulling
new hardware. The eyes have to be placed so the pulled hardware runs
naturally from one to the next. You also have to be careful that the
bulls-eyes won't chafe through the wire or hose over time.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
Posted: Wed May 06, 2009 7:53 am Post subject: attaching wing wiring |
i think the lacing tape is just what i need. i have plenty of ''geodetics'' in the ribs to attach to. thanks to all who helped on this one. bob noffs
On Wed, May 6, 2009 at 9:24 AM, Lowell Fitt <lcfitt(at)sbcglobal.net (lcfitt(at)sbcglobal.net)> wrote:
I think we were unaware of your wing when we all gave our advice. I recently strung the wires for trim and aft position lights up the fuselage. I used wire lacing tape spaced about every three inches along the stringer. It can also be used where there is no attachment to a structure to bind the bundle together for strength. Do a google search on lacing tape. There are numerous sources. I used a "clove hitch" knot with a square knot to secure it. The material is very light, wax coated so the knots don't tend to loosen while working on them and will last forever.
I drilled small holes in the stringer every nine inches or so. This way, I could attach the wire without the wrap creating a lump under the fabric. I don't think I would be drilling any holes in a wing structure, though. If there aren't internal structures you can tie to, you might try what the Lancair guy did stringing his wiring. he got those flat adhesive backed zip tie attachments available at Home Depot, etc. He ground off the adhesive, drilled several holes through them for a mechanical lock and glued them to the fuselage or wing skin with structural adhesive, then used the lacing tape. Not as light as lacing tape alone, but strong and long lasting
Lowell
Float Flyr
Posted: Wed May 06, 2009 5:39 pm Post subject: attaching wing wiring |
My bad, it’s called Koroseal Lacing… something like an elastic tie wrap. I think it’s available from Leavens In Canada or Aviall south of the 49th. It can be used to protect parts to bind wires to structure. It’s a bit on the expensive side for bundling wires… For that I like wax cord. Someone said dental floss would work as well for bundling and I think they’re right. Properly used it looks a lot better then nylon and there is no chance of the stuff ever rubbing through insulation on a wire.
Noel
Sent: 06 May 2009 08:28 AM
Subject: Re: attaching wing wiring
bob noffs
Lowell
Kitfox III-A
andynfultz(at)bellsouth.n Guest
Posted: Wed May 06, 2009 5:42 pm Post subject: attaching wing wiring |
A diameter just, large enough for your wiring, of plastic tubing from your local hardware store will make a good conduit for your wiring. Secure it to the wood structure with a few wraps of rib lacing cord. Doesn't add much weight but does add a lot of protection for the wiring.
Andy F.
[quote] --
