dlm46007(at)cox.net Guest
Posted: Tue May 05, 2009 7:13 pm Post subject: HID lights |
Just in case the new builders have not considered HID lights. See the difference on my 10.
http://www.planelights.com/index.php?id=661
partner14
Posted: Tue May 05, 2009 7:43 pm Post subject: HID lights |
So the power requirement is < the stk Van's lights? If true, then the wiring already in the wingtip for the existing landing light should work just fine. Soon as I get the first flight in, I'll consider the change out. Thanks for the info.
Don McDonald
--- On Tue, 5/5/09, David McNeill <dlm46007(at)cox.net> wrote:
Subject: HID lights
Date: Tuesday, May 5, 2009, 8:06 PM
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
et=_blank>http://forums.matronics.com
40636 |
hotwheels
Posted: Wed May 06, 2009 6:52 am Post subject: Re: HID lights |
How did you mount your balasts? Photos?
Jay
[quote="dlm46007(at)cox.net"]Just in case the new builders have not considered HID lights. See the difference on my 10.
Posted: Wed May 06, 2009 7:23 am Post subject: HID lights |
The install pictures are available on a click from the original link or
http://www.planelights.com/index.php?id=685
rv10rob(at)gmail.com Guest
Posted: Wed May 06, 2009 7:54 am Post subject: HID lights |
Here's what I did:
http://kochman.net/N819K/wp-content/uploads/2008/09/img_4685.jpg
On Wed, May 6, 2009 at 8:19 AM, David McNeill <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
[quote]--> RV10-List message posted by: "David McNeill" <dlm46007(at)cox.net (dlm46007(at)cox.net)>
Planelights
Posted: Wed May 06, 2009 9:57 am Post subject: Re: HID lights |
Hi guys, Steve here from Planelights.
Power draw:
On any HID system you will have about a 10sec warm up. During that 10sec they will be pulling about 7a(80w) (at) 12v. After they are warmed up, they will pull about 4.5a(54w) (at) 12v. Your stock lights should have been 75w halogen bulbs, the wiring should be adequate to handle the HID's.
These lights will work fine with a wig wag system. You will need to be able to wire the lights to stay on for at least 1 minute prior to flashing. That allows the xenon gas inside the bulb to stabilize prior to flashing.
If you look at our website you will see the RFI comparison charts. http://www.planelights.com/index.php?id=702 You will see that our ballast should not interfere with any Nav or Comm equipment. We have had a few people say that a strobe light causes more intercom interference than our lights.
Steve
