jason(at)trek-tech.com Guest
Posted: Thu May 07, 2009 7:07 am Post subject: Engine angle on the airframe mounts on a MKIII |
Hello All,
I have checked the archives extensively and found some useful information but I would like to take a poll.
In reference to the engine mounts on the airframe of a MKIIIC, what angle does your engine sit at. Does the engine sit flat (parallel) on the mounts? Are there any spacers or engine mount holes that make the front of the engine sit higher or lower on the airframe mount. I Know the effect that engine angle has on yaw trim, I just wanted to see where other people landed on the engine mount.
Jason
MKIIIC
BMW engine
Posted: Thu May 07, 2009 7:49 am Post subject: Engine angle on the airframe mounts on a MKIII |
Jason:
Over the years I have experimented with changing engine attitude in pitch and yaw. I did this with my FS and MKIIIc.
Results indicated it was not worth the effort of screwing up good engine mounts.
I believe the stock engine position is as good as it gets.
I have also experimented with off setting the leading edge of the upper vertical stabilizer in order to help control adverse yaw. Again, was not worth the holes I had to drill in the tailboom to conduct my experiment. I found the best solution was to use the appropriate size rudder trim tab set at the correct angle.
Interesting to note, the new Kolb MKIIIx I tested last year ended up with an identical size and shape rudder trim tab as on my much older MKIIIc.
I do like to get the engine as low in the mounts as I can to help offset some of the adverse pitch down caused by a high thrust line on a pusher.
The leading edge of my horizontal stabilizer is somewhat lower than what the plans called for. Where I have mine set now is where my mkIII flies best. Up or down from this position causes the mkIII to act like it is trying to balance on a ball. Was difficult to keep it in a good cruise attitude. Nose would either want to drop or climb. Would be hard to fly all day in that condition.
[quote] In reference to the engine mounts on the airframe of a MKIIIC, what angle does your engine sit at. Does the engine sit flat (parallel) on the mounts? Are there any spacers or engine mount holes that make the front of the engine sit higher or lower on the airframe mount. I Know the effect that engine angle has on yaw trim, I just wanted to see where other people landed on the engine mount.
Jason
_________________ John Hauck
Titus, Alabama |
Jason Omelchuck
Joined: 07 May 2009 Posts: 120 Location: Portland Oregon
Posted: Thu May 07, 2009 9:01 am Post subject: Re: Engine angle on the airframe mounts on a MKIII |
Thanks John,
Can you tell me if the "stock" position is with the engine parallel (or the prop perpendicular) to the mounts on the airframe or does "stock" mean that the front of the engine is raised or lowered some per the factory instructions.
Jason
Posted: Thu May 07, 2009 9:08 am Post subject: Engine angle on the airframe mounts on a MKIII |
instructions.
Jason:
On my mkIII the line of thrust is parallel with the stock engine mounts, and
as low as I could get the 912 and still have a little clearance to keep from
hitting the large root tube during flight.
Titus, Alabama |
Posted: Thu May 07, 2009 9:51 am Post subject: Engine angle on the airframe mounts on a MKIII |
Jason
I have played around a bit on engine positions and I agree with John, it
doesn't seem to make any difference. From a purely theoretical view it would
seem the best thrust line would be having the line of thrust pushing
straight forward in cruise. Allowing for a few degrees of angle of attack
for the wing to maintain altitude, I set my line of thrust 2-4 degrees down
from parallel with the bottom line of the wing. Or 2-4 degrees prop up,
front of engine down. I had to do this because I had cut to stock engine
mount off the airframe to be able to lower the engine. Yes the lower the
thrust line the better. This makes a real big difference.
Rick Neilsen
Redrive VW powered MKIIIC
by0ung(at)brigham.net Guest
Posted: Sat May 09, 2009 4:45 am Post subject: Engine angle on the airframe mounts on a MKIII |
Jason
MKIIIC
BMW engine
Parallel on the mounts for me.
Boyd Young
MKIIIC
Utah
