cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Thu May 07, 2009 5:44 am Post subject: help with finding a bolt |
Hi. If someone would have some extra time (which I seem to be lacking this week) could I get some help finding a bolt? A friend of mine discovered that one of the six bolts holding my prop on was broken as he was looking my plane over.
The company that makes my wooden prop is no longer in business or I would call them. We can't find the bolt at any local stores here. My friend measured it and says I need 8m x 90mm long with standard 1.25 thread. The bolt needs 25mm of thread.
I won't even be able to get to the airport until Saturday and was hoping to get a head start on finding a replacement.
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
Posted: Thu May 07, 2009 6:00 am Post subject: help with finding a bolt |
> Cristal Waters
I'm probably not going to be much help.
Waycross should have a "fastener" store that carries nuts and bolts,
washers, pop rivets, etc.
If you have time take one of the good bolts with you to match the new one.
I get all my 8mm prop bolts from a fastener store in Montgomery, AL.
_________________ John Hauck
Titus, Alabama |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Thu May 07, 2009 6:05 am Post subject: Re: help with finding a bolt |
| cristalclear13 wrote: | Hi. If someone would have some extra time (which I seem to be lacking this week) could I get some help finding a bolt? A friend of mine discovered that one of the six bolts holding my prop on was broken as he was looking my plane over.
I won't even be able to get to the airport until Saturday and was hoping to get a head start on finding a replacement. |
Heh, I just got through with an exercise like this.
First, before you do anything else, try to find out why the bolt broke in the first place? Broken prop bolts are a dangerous symptom (why I've been so worried about the harmonics problem I've been having with my WD).
Next, try a Fastenal if there's one in your area, you probably need something like this:
http://www.fastenal.com/web/products/detail.ex?sku=39128&ucst=t
Don't bother trying to find an aircraft grade metric bolt in the US - no such animal. Generally, grade 8.8 (which corresponds to grade 5 in English sized bolts) has the ductility you need for prop bolts.
5/16" are virtually the same as M8 diameter-wise, but the normal national coarse thread won't work in a 1.25 threaded 8mm hole (so if you attach to the flange with backing nuts only, 5/16" are a suitable substitute).
LS
_________________ LS
Titan II SS |
cristalclear13
Posted: Thu May 07, 2009 6:08 am Post subject: Re: help with finding a bolt |
| John Hauck wrote: |
mkIII |
Thanks John. Maybe I can break away from work for a bit and try that. We do have a store called Fastenal.
Looks like you are getting some pretty good storms this morning? Which day do you plan to leave for MV?
herbgh(at)nctc.com Guest
Posted: Thu May 07, 2009 6:08 am Post subject: help with finding a bolt |
Advanced Auto stocks some Metric bolts..and they likely can have them
in overnight.. Herb
At 08:57 AM 5/7/2009, you wrote:
> Cristal Waters
Checked by AVG - www.avg.com
05/06/09 17:58:00
aslsa.rng(at)gmail.com Guest
Posted: Thu May 07, 2009 6:13 am Post subject: help with finding a bolt |
If you can't find them locally, McMaster Carr has them. Part No. 91280A560, but you have to buy a lifetime supply (25) at about 50 cents each.
Rick
On Thu, May 7, 2009 at 8:44 AM, cristalclear13 <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)> wrote:
[quote]--> Kolb-List message posted by: "cristalclear13" <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)>
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p=243011#243011
le, List Admin.
Posted: Thu May 07, 2009 6:22 am Post subject: help with finding a bolt |
Cristal Waters
Fastenal will have exactly what you are looking for.
I don't think you need to be too alarmed with a broken prop bolt on a 503.
I remember breaking my share of them on my 447 with wooden prop. I have
also broken a couple over the years on the 912 engines. Never have found
out why, except the will break occasionally.
We have been getting beat up with thunderstorms, heavy rain, and wind for
three days. Hoping it will all blow out of here by next Tuesday morning
when I leave for Sherman, TX.
Looks like we will have four mkIII's and a J5 Cub meeting at Sherman for the
flight out to Los Lunas, NM, and Monument Valley. From MV we intend to fly
up to Oregon and spend a few days with Larry and Karen Cottrell. We will
pick up Mike Marker and his RANS S-18 for that part of the flight. There
are some other folks that may fly if they can get their work schedule and
aircraft problems sorted out.
Looks like we are going to have a good Unplanned/Unorganized Kolb Flyin,
Monument Valley, for the seventh consecutive year. Wish all of you could be
with us next week.
Titus, Alabama |
lcottrell
Posted: Thu May 07, 2009 8:19 am Post subject: help with finding a bolt |
Cristal,
The only place that I could find metric bolts of that size was at a John Deere tractor supply.
Larry C
lucien
Posted: Thu May 07, 2009 8:57 am Post subject: Re: help with finding a bolt |
| John Hauck wrote: | > Thanks John. Maybe I can break away from work for a bit and try that.
Cristal Waters
with us next week.
mkIII |
I may have too much time pressure to make the trip, but if I do it'll probably be crack of dawn Fri. morning then return crack of dawn Sat.
I'm not optimistic about the winds either, we've had a late spring here and 15G25 is a pretty calm day......
Get-back-itis may be the main hazard (have to be in office Mon. morning or else), so my plans are tentative at this point.....
LS
Titan II SS |
cristalclear13
Posted: Thu May 07, 2009 2:12 pm Post subject: help with finding a bolt |
Fastenal had the equivalent of the fabric rivets when I was building
my (left) wing. Nice to walk in and walk out with what you need today.
BB
On 7, May 2009, at 2:29 PM, cristalclear13 wrote:
<cristalclearwaters(at)gmail.com>
Thank you all for your responses. Fastenal will order them and get
them here by Monday.
Thanks!
Cristal Waters
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p 43050#243050
Dana
Posted: Thu May 07, 2009 2:40 pm Post subject: help with finding a bolt |
At 09:44 AM 5/7/2009, cristalclear13 wrote:
McMaster <http://mcmaster.com> has it.
Q: Why is it that New Jersey got all the toxic waste dumps and California
got all the lawyers?
A: New Jersey had first choice.
