		lucien
				 Posted: Sat May 09, 2009 6:52 am    Post subject: Harmonics problem - solved |
				Just FYI for anyone who might be interested in the prop harmonics story,
 Solved my harmonics problem completely by going to a Powerfin F model 3-blade (70"). Took it around the patch last night and it was like scratching an itch - nice smooooth wobble-free power. Harmonics gone.
 As far as the numbers, performance was exactly what I was expecting as I've flown a bunch of powerfins over the years - better climb, narrower speed range, very happy engine/gearbox. Climb slightly better than the WD, 10mph now missing off the top end (90mph indicated at 5100 rather than 100, but it's smooth now so I don't care. I can do anything I want at 90mph).
 I'm going to fly a little more before I make the logbook entry. After that I'm probably going to put my WD up for sale as it's a perfectly good prop and would be perfection on a 912 equipped Kolb.
 Ah, sweet relief......
 LS
  _________________ LS
Titan II SS |
		JetPilot
				 Posted: Sat May 09, 2009 7:30 am    Post subject: Re: Harmonics problem - solved |
				Very good information Lucien !   I'm sure there will be many people interested in your report and solution to this problem.   I fly a Powerfin on a Trike, they are very nice props.
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		lucien
				 Posted: Sat May 09, 2009 8:08 am    Post subject: Re: Harmonics problem - solved |
				 	  | JetPilot wrote: | 	 		  Very good information Lucien !   I'm sure there will be many people interested in your report and solution to this problem.   I fly a Powerfin on a Trike, they are very nice props.
 Mike |
 Yeah, shame it had to be such a brute force fix tho (i.e. brute force on my wallet).
 But I've always thought the powerfin was a little underrated and I'm not really sure why. I've flown a couple powerfins, my last was my 66" F 2-blade I ran on my trike and then later my powered parachute. I just love them. On the trike, it gave me 1800fpm sustained with the 503/2.58 B box. Same combo on my PPC gave the highest climb rate of the other props I tried (including another PF C model). Stuart was surprised by that when we were talking about it over the phone, because the C model is his main PPC prop and he didn't expect the F to outperform it.
 The F model does have enormous amounts of blade area so it tends to have a narrow speed range (which I can definitely confirm with a near 10mph drop in top end over the WD). But it's the strongest pusher/climber on the market (which I also reconfirmed last night).
 Stuart did change the construction of the blades slightly. The newer ones weigh a little more and I suspect that was for strengthening. It's still significantly lighter than my WD confirmed by a heft test, and far lighter than the IVO medium.
 I'll see if Daryl will take my WD back, tho I won't object if he doesn't want to take back a perfectly good prop. If not, I'll probably put it up for sale once I'm done confirming everything's fine with the PF.
 LS
Titan II SS |
				 Posted: Sat May 09, 2009 10:38 am    Post subject: Harmonics problem - solved |
 Glad Lucien found his problem.
 Did he inform the Titan List?
 Ted Cowan must still be waiting on his new blades.
 I just got in from flying my 71" Warp Drive.  Same as always, since 1993.
  _________________ John Hauck
Titus, Alabama |
		lucien
				 Posted: Sat May 09, 2009 11:49 am    Post subject: Re: Harmonics problem - solved |
				 	  | John Hauck wrote: |
 mkIII |
 Yeah I know this was mostly not Kolb related, so didn't mean to drag it out, my apologies to the list on that.
 Hopefully the prop info is of general interest, tho.
 LS
Titan II SS |
				 Posted: Sat May 09, 2009 12:55 pm    Post subject: Harmonics problem - solved |
  LS
 Just a wild guess, but I think your's and Tom Cowan's problems with the Warp
 Drive Prop are isolated to your individual airplanes.
 I have flown Sling Shots with 912ULS and 3 blade WD which had no problem.  I
 know of several Titans that fly with 912ULS and Warp Drives with no
 problems.
 Air flow can make a prop do some funny things, in the case of Ronny Collins
 Sling Shot/582/Warp Drive that suffered harmonic problems that sounded and
 acted just like Ted Cowan's.
 Not much fun when your airplane does not perform like you want it to, no
 matter what the problem.
 My ANR power supply that converts 12VDC to 9VDC filtered power quit working.
 Discovered this on my flight yesterday.  This afternoon I pulled the power
 supply and wiring out of the mkIII.  Soon as I got it out I discovered a
 cold solder joint had pulled out of the circuit board.  Bugged hell out of
 me until I got it fixed.  It happened just prior to spending 3 or more weeks
 living out of and flying the mkIII.  That is when most stuff breaks, just
 prior to time to go on a long trip.
 jpohn h
Titus, Alabama |
		lucien
				 Posted: Sat May 09, 2009 2:06 pm    Post subject: Re: Harmonics problem - solved |
				 	  | John Hauck wrote: |
 problems.
 I'd say that jives with my findings as well. I've talked to 2 other owners of my model plane, both use the WD 3-blade. One has the exact same problem I do, the other has no problems. Go figure.
 My FSII had  a 68" WD on it, totally smooth operation with excellent performance, quiet, etc.
 And then there's all those bajillions of other planes out there that run the WD with no problems. Can't see how it's anything other than an interaction twixt the plane and prop peculiar to this model plane. There's only 6 or 7 of the big titan flying in the world at this point, and the changes to the cabin height and width are signficant. doesn't surprise me that with a newer design there could be a new oddity with what's otherwise one of the best motor/prop combos available that we just hadn't seen yet.
 Well in my case, it's not a defective prop I know that for sure. That was the annoying part, if something was just broke all I had to do was fix it.
 Like I said, guess that's why these suckers have that big ol experimental pasted on the side.......
 LS
Titan II SS |
