High Fuel Pressure - Extreme Rich
jkreidler
PostPosted: Sat May 09, 2009 5:48 pm    Post subject: High Fuel Pressure - Extreme Rich Reply with quote
Fired up today for our first short taxi test. The engine would not run over 1350 RPM WOT. Fuel pressure was 48 PSI. After shutting down we pulled the plugs, they were all black, way black. Indicating the engine was very rich. The air box had raw fuel in it. We have an Airflow Performance injection.
We didn't have this problem during our last test run. Since then we have performed the service bulletin on the mags, I double checked the timing. I did not try to lean the engine using mixture, I think the richness may be caused by the excess fuel pressure, and not the actual mixture setting. I could be wrong but I don't think the mixture would be that far off.
Any thoughts??
Jason Kreidler
4-Partner Build
N44YH - #40617
rene(at)felker.com
PostPosted: Sat May 09, 2009 6:39 pm    Post subject: High Fuel Pressure - Extreme Rich Reply with quote
There is a service bulletin on the RSA fuel injection systems. I don't have
it here to get the numbers, but if I remember right, that is the failure
mod......you lose power. There is a screw on the side of the controller
that needs to be checked.....
Just an idea.
Rene'
801-721-6080
gengrumpy(at)aol.com
PostPosted: Sat May 09, 2009 6:41 pm    Post subject: High Fuel Pressure - Extreme Rich Reply with quote
You gotta lean this engine on the ground. Sounds like you had it
flooded to have the fuel in the air box.
Did it run right on the first runup (ie, confirm your tach is correct?)
grumpy
Any thoughts??
Jason Kreidler
4-Partner Build
N44YH - #40617
http://forums.matronics.com/viewtopic.php?p 43333#243333
jkreidler
PostPosted: Sat May 09, 2009 6:52 pm    Post subject: Re: High Fuel Pressure - Extreme Rich Reply with quote
Seemed to run OK on the first run up, we had normal fuel pressures around 30. I understand the theory behind leaning while on the ground, but if the idle mixture has been set correctly leaning on the ground is not required (for 'standard' conditions). This is according to the folks at Airflow Performance. The manual provided with our fuel controller goes through this procedure.
Leaning also does not explain the high fuel pressure......
Thanks, Jason
Kellym
PostPosted: Sat May 09, 2009 6:53 pm    Post subject: High Fuel Pressure - Extreme Rich Reply with quote
He has AirFlow Perfomance injection, not RSA, so should not have that
issue. I'm still trying to figure how he gets fuel pressure 50% above
redline.
Just an idea.
Rene'
801-721-6080
Kelly McMullen
KCHD
nicholscatoauto(at)aol.co
PostPosted: Sun May 10, 2009 11:33 am    Post subject: High Fuel Pressure - Extreme Rich Reply with quote
Jason,
I am not real familiar with mechanical fuel injection but on a car high fuel pressure is usually caused by a blocked return line and the pump putting out max pressure.
Jeff
#648
