After market Tach
shinden33
PostPosted: Sat May 09, 2009 4:44 pm    Post subject: After market Tach Reply with quote
On that note, anyone use an aftermarket tach? Any recommendations?
S
The Defiant Company
www.defiantco.com
viperdoc(at)mindspring.co
PostPosted: Sat May 09, 2009 7:51 pm    Post subject: After market Tach Reply with quote
Look at the Dynon EMS system for one. JPI also has one with a bunch of bells
and whistles. It reports as rpm though not as % rpm. I have talked to tech
support at Dynon about this. According to them, it is a simple software
change but not enough people have asked for it for them feel it might be of
benefit.
Also check with West London Aeroclub in England. I thought I saw a tach
drive generator on their website.
But before you press off buying a new generator, have you looked to see if
you have a broken wire in the sim plug? That is the most common cause for
Tach Drive Generators to fail.
Viperdoc
The web URL for them is http://www.wlacrussianeng.co.uk/main.asp?ID=5
Viperdoc
pfstelwagon(at)earthlink.
PostPosted: Sat May 09, 2009 10:17 pm    Post subject: After market Tach Reply with quote
Check out the HORIZON tach. They can set it up for what ever you want.
Fran N23021
dsavarese0812(at)bellsout
PostPosted: Sun May 10, 2009 5:28 am    Post subject: After market Tach Reply with quote
Doc suggestion is a very good choice. If you're looking for JUST a tach, take a look at the Horizon Instruments P-1000 tach. You can order it configured to you needs. Just installed one in a CJ with an M14.
Dennis
shinden33
PostPosted: Sun May 10, 2009 9:08 am    Post subject: Re: After market Tach Reply with quote
Doc - already tried the cannon plug. I pulled the tach gen off and the shaft no longer turns the guts.
Dennis & Fran - The horizon can be set up for %?
S
The Defiant Company
www.defiantco.com
barryhancock
PostPosted: Sun May 10, 2009 9:54 am    Post subject: Re: After market Tach Reply with quote
I was first introduced to the Horizon Tach several years ago when I installed an M14P in the "Super Pickle". Since then I have come to know the company pretty well as they have programmed a couple of 337 tachs for the stock Housai for us. It's a great product with super customer support. It is a good diagnostic tool, very readable, and very reliable. The gauges are STC's for other applications.
For a stand alone replacement, I'm not aware of a product that comes close. And for about the same money as a tach generator, you get a solid state replacement that is dead nuts simple to wire (off the P-leads at the mag switch).
FWIW,
Barry
Barry Hancock
Worldwide Warbirds, Inc.
(877) 869-6458
www.worldwidewarbirds.com
PostPosted: Sun May 10, 2009 11:13 am    Post subject: After market Tach Reply with quote
Yes. The factory will do that for you.
Dennis
Yak52w(at)aol.com
PostPosted: Sun May 10, 2009 11:14 am    Post subject: After market Tach Reply with quote
I second that suggestion. I have the Horizon tach in my 52 and have been very pleased with it. a digital indication for mag drop and you can get the indicator lights set for max continuous which provides a good "idiot" light for rpm while flying formation.
Tim Stevens
In a message dated 5/10/2009 1:55:44 P.M. Eastern Daylight Time, bhancock(at)worldwidewarbirds.com writes:
--> Yak-List message posted by: "barryhancock" <bhancock(at)worldwidewarbirds.com>
FWIW,
Barry
Barry Hancock
http://forums.matronics.com/viewtopic.php?p=243406#243406===============================================
_-= e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
The Average US Credit Score is 692. See Yours in Just 2 Easy Steps!
PostPosted: Sun May 10, 2009 6:56 pm    Post subject: After market Tach Reply with quote
West London Aero Club Russian Engineering has them listed on their website
if you want to stay orginal.
I have a mix in my pane. The Dynon and the steam gauges mixed. In the 50,
the AS indicator is perfect for snap shots on final as is the % RPM. For a
snap shot, the position of a needle on a dill works better for me than tapes
and digital printouts. Now if I had the bucks to project the info on Beveled
Glass on the windscreen AKA HUD, well then the steam gauges would be gone.
Doc
