Exhaust systems
johnlong63(at)gmail.com
PostPosted: Sat May 16, 2009 4:05 am    Post subject: Exhaust systems Reply with quote
In the building stage and near to ordering my engine, 200HP IO-360.  Does anyone have opinions, (I know, that is a dumb question Smile, on 4 to 1 versus Vetterman crossover exhaust systems.  Which would be a better choice?
Lake Wylie SC
Dale Ensing
PostPosted: Sat May 16, 2009 5:34 am    Post subject: Exhaust systems Reply with quote
Don't know about better but I can tell you that my neighbor's 4 into 1 is louder than my Vetterman crossover. Both on O-360.
Dale Ensing
RV-6A
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
Larry Bowen
PostPosted: Sat May 16, 2009 6:22 am    Post subject: Exhaust systems Reply with quote
I looked into it briefly.  Once I saw the price, it was easy to decide to go with the standard Vetterman.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
Sent from Welcome, NC, United States
On Sat, May 16, 2009 at 9:33 AM, Dale Ensing <densing(at)carolina.rr.com (densing(at)carolina.rr.com)> wrote:
[quote] Don't know about better but I can tell you that my neighbor's 4 into 1 is louder than my Vetterman crossover. Both on O-360.
Dale Ensing
RV-6A
Larry Bowen
RV-8 SOLD,
RV-7QB in progress...
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
Site Admin
PostPosted: Sat May 16, 2009 8:25 am    Post subject: Exhaust systems Reply with quote
Lake Wylie SC
Hi John,
I ordered the new Vetterman 4 into 4 system for my RV-8 with an Lycoming IO-390. Haven't tried it yet, but its another option to consider. Larry claims the maximum HP output with the 4 into 4 setup. I've attached a couple of pictures of it.
RV-8 #82880 N998RV (res)
Carpet CAD Layout Continues...
 Filesize:  315.3 KB
 Viewed:  4347 Time(s)
 Filesize:  231.78 KB
 Filesize:  165.19 KB
l-fussell(at)comcast.net
PostPosted: Sat May 16, 2009 11:27 am    Post subject: Exhaust systems Reply with quote
I used a Sky Dynamics' 4 into with which I am very happy. On the down side it take a lot of glass work on the bottom cowl to accommodate the collector. photo of the header attached and you can see it in this shot from the ground as well.
Larry
RV7A
 Filesize:  69.29 KB
 Viewed:  4346 Time(s)
 Filesize:  285.56 KB
bill(at)repucci.com
PostPosted: Sat May 16, 2009 12:58 pm    Post subject: Exhaust systems Reply with quote
John,
When I was racing and testing and changing exhaust to get the most power I could, I found that the four 4-1 was good for max torque and HP at the red line. The 4-2-1, equal length exhaust provided max torque & HP in the mid RPM range. Granted, that was on a car with a very different engine (1.8, dual overhead cam, fuel injected, with a high red-line, and tuned w/in a breadth of its life.) than the big slow turning things we use on our planes. In my application I went with the 4-2-1 (or tri-Y as some call it) because I needed mid range torque.
With that little bit of knowledge, I would probably select the Vetterman’s crossover, thinking that you are going to run it in the mid-range RPM’s unless you are into racing.
It is all about what you are looking for and where you want your power peak.
From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of John Long
Sent: Saturday, May 16, 2009 8:00 AM
To: rvsoutheast-list(at)matronics.com
Subject: Exhaust systems
Lake Wylie SC
