Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sat May 16, 2009 8:23 pm Post subject: green loctite |
While I was finishing my fuel tanks, my friend stopped by to watch me. He asked me what happens if they leak? I told him about the green wicking loctite that is commonly used for leaks. He then began to tell me at his work they work on 1000psi fuel pumps which are tested for leaks. If they leak, they use the green loctite. He told me it works great for the high pressure leaks. That made me feel a lot better if they leak in three weeks when I test them. It also made me believe it would make others out there who are working on the tanks or will work on the tanks feel better about fixing leaks on the fuel tanks.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
