dfritzj(at)yahoo.com Guest
Posted: Sun May 17, 2009 8:23 am Post subject: Insulation on Welding Wire |
All,
I'm getting ready to buy my main battery cables and would like some advice on which insulation to choose. I've read the discussions that say welding cable is good to use for its flexibility and durability, but should I be worried about the temperature range of the insulation? The choices seem to be neoprene welding cable (good to 90C), thermoplastic rubber welding cable (good to 105C), PVC battery cable (good to 80C), and "SGX" battery cable (good to 125C). Any ideas/insight into which of these is the most desirable? The application is a 24V system in a Velocity (batteries in the front, engine in the back). Should I consider using some of the stiffer battery cable for the run from the batteries to the firewall-mounted starter contactor and then welding cable from the contactor to the starter motor?
Also, Waytek has some pretty good prices on these, but only sell in quantities greater than 100ft, does anyone know a good source that won't break the bank?
Dan
jaybannist(at)cs.com Guest
Posted: Sun May 17, 2009 8:50 am Post subject: Insulation on Welding Wire |
Dan,
I got my welding cable (~30') at Grainger for what I thought was a very reasonable price.
Jay Bannister
Posted: Sun May 17, 2009 8:55 am Post subject: Insulation on Welding Wire |
Hi Dan,
I think welding wire is a better product for the heavy cable at the
batteries. It's easy to join with silver solder and cupped ring ends.
It's flexible and doesn't
get brittle because of the fine wires.
*January 15 *The order for cable terminals from Wicks came in so the
battery contactor to starter was stripped, inserted and was crimped
once. Flanges were filed off. Silver solder was added to join cable and
terminal and shrink-wrap was added. After refastening it to the
contactor, tie-ties reattached the cable to bus support structures
through the plane. The instrument panel was removed to the worktable and
switches were placed thru the switch template panel to keep them in
order. Wires were revisited to shorten them, provide bundled protection,
and minimize motion.
see link:
http://www.macsmachine.com/images/electrical/full/chargebatteryconnection.gif
D Fritz wrote:
| Quote: | All,
starter motor?
Dan
Posted: Tue May 19, 2009 7:45 am Post subject: Insulation on Welding Wire |
Thanks for the replies Larry and Jay. Has anyone else got any input on the material of the insulation? Particularly, would I be buying into excessive risk using the "Thermoplastic Rubber" insulated welding wire that's rated at 80C or do I need to consider going to the 105C or 125C rated materials? I don't intend to have an electrical fire, but I like to plan for the worst and hope for the best..
Da
Posted: Tue May 19, 2009 7:59 am Post subject: Insulation on Welding Wire |
At 10:39 AM 5/19/2009, you wrote:
| Quote: | Thanks for the replies Larry and Jay. Has anyone else got any input
electrical fire, but I like to plan for the worst and hope for the best...
Don't loose any sleep over it. You're
not going to start an electrical fire
by heating a fat wire. Welding cable is
just fine. It's inexpensive and a joy
to work with. Wires that burn are the
itty-bitty fellers that should have fuses
and/or breakers protecting them.
Now, the insulation on your wires might
CONTRIBUTE to a fuel fed fire but this
is exceedingly rare . . . and if you've
got a gasoline or oil fed fire going, adding
a few ounces of insulation is the least
of your worries.
( -Thomas Paine 1776- )
Posted: Tue May 19, 2009 8:15 am Post subject: Insulation on Welding Wire |
Considering welding wire is subjected to temporary flame, molten hot
metal and much abuse, I'd think it's an ideal product to carry the heavy
currents
you'll be running thru it. The insulation doesn't want to burn unless
you've a really hot one going. By then, I doubt you'd want to be there
either.
I'd rate the risk as very low for welding cable insulation.
Da
frank.hinde(at)hp.com Guest
Posted: Tue May 19, 2009 8:21 am Post subject: Insulation on Welding Wire |
Yes and think of the abuse welding cable takes on the industrial job site or ship yard..I never seen a welding cable sparking to ground in 25 years of construction!
Frank
| Quote: | Thanks for the replies Larry and Jay. Has anyone else got any input on
of your worries.
Posted: Thu May 21, 2009 9:24 pm Post subject: Insulation on Welding Wire |
Thank you all for the responses on this, I feel a lot better about welding wire now.
Dan
